Question about Whirlpool Dryers
My gas dryer gets hot for about 2min.then the burnner shuts off HELP!
  • 67 Answers
You have bad valve coils
Posted on Sep 29, 2009
Ignighter workis and burner has flame but will not keep burnner lit. speed queen dryer. made by RAYTHEON
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Aug 06, 2011 | Dryers
Doesn't get Hot
You probably need a new regulator.
Apr 14, 2010 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Gas dryer get hot but than goes cold
This sounds like a problem with your fan motor. The dryer is getting too hot and the gas is shutting off until it cools down. That fan keeps the dryer cool by moving the heat to the clothes in the drum.
You can easily check this by feeling for air flow in front of the exhaust vent outside. No air movement = fan problem = heat shut off in 10 minutes. Good luck
Dec 05, 2009 | Dryers
Dryer doesn't stay hot, starts out getting hot, then the heat shuts off
gas coils part 12001349.are bad,most of the time when the coils are failing they work until they heat up,they are located on the top of gas valve
Dec 02, 2009 | Kenmore 73932 Gas Dryer
Dryer gets hot and shuts down for about 25 minutes b4 starting
The 'high limit' is tripping> Clean the lint filter and tube all the way in, it's full of lint and the hot air is restricted.
Jul 05, 2009 | Maytag Neptune MDG5500AW Gas Dryer
74672400 GAS DRYER WILL NOT HEAT
glow bar igniter ... - thermal fuse ( not all models ) ... - coil on the gas valve ... - gas valve ... - thermostats ... - motor heat switch ... - timer ... - selector switch ... - sensor ... All these will stop it from heating.
Mar 23, 2009 | Kenmore 74672 Gas Dryer
Dryer makes squeaking noise ,then dryer shuts off. mdl.#CYG4000AWW
Hello, sounds like the rear drum rollers are in need of replacement which is causing the motor to get hot and cut out on the thermal cut out. It can be tricky to service if you not handy. Good Luck
Oct 19, 2008 | Magic Chef CYG4000AWW Gas Dryer
2 dryers that run but have no heat
It sounds like the gas supply is not giving you any gas, as both have the exact same symptoms. You can see the glow coil getting red hot, then the safety shuts off after a it gets no gas. If you feel confident, shut off the valve in back coming from the wall, unscrew the line where it connects to the dryer. Turn the valve back on slowly, there should be gas pressure blow out of the line.
Dec 19, 2007 | Dryers
Whirlpool gas dryer
Did you check the coils for the gas valve with a meter for ohms resistance?
Aug 09, 2007 | Whirlpool LGR3624JQ Gas Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
