Question about GE Refrigerators
GE PSS26MGTBWW icE makear DoES NOT TRIGGER SOLONOID . DOOR FLAP OPENS ONLY PARTIALLY. LIGHT DIM. lOOKS LIKE LOW VOLTAGE. IT READS ABOUT 10 VOLTS. i AM THINKING OF ORDERING NEW CIRCUIT BOARD FOR DOOR.
  • 3 more comments
  • wleaddog Sep 28, 2009
    Your solution seems only to remove components not fix the problem. Also I am having trouble locating exactly what part of the ice maker you are referring to. The door? the ice maker? The ice dispenser?
    I have questions on exactly why I am doing some of the recommendations. For instance, why remove the ice crusher? The auger can easily be turned by hand, so I do not feel the problem is here. I feel the problem is between the circuit board and the solonoid. As the light is dim and the door opens slowly it seems as if the voltage is low. I assume this is the same voltage that controls the solonoid.
    Maybe you need more info. The ice maker makes ice OK. The door unit seems where the trouble is. The water dispenser works ok. Sometimes the ice crusher works but only very rarely. I need to know what voltages to measure on the circuit board. It does seem that the solonoid and motor that turn the
    auger does not work. Your instructions are far too complicated and don't tell me when I have fixed the problem.
    I just discovered an important point. When I remove the plug on the circuit board going to the door everything works including the solonoid and auger. The voltage reads 10+ volts. When the door solonoid is operae the voltage drops to 8 volts. This indicates that the door solonoid is drawing too much current. Why? What should I replace?
    I haven't heard from you lately. Are you still there? I believe the problem is in the board. The door solonoid seems to work but the voltage drops. The board has some type of timer associated with the door. When this is timing the voltage is low.
    Rylee, I believe you have recommended the wrong circuit board. The board that controls the ice maker is in the Ice door. I need to know how to order a new one. I have already removed it two times and have re connected it with the ice door connector removed. Everything is working except I have to open the ice door by pushing up on it. I would have to order a new board if you think that is the problem.
    I'm not sure.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Try removing the ice dispenser and also check the solenoid by following this procedure--
Ice Dispenser—
The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
1. Remove the upper ice bucket tray.
2. Slide out the ice dispenser assembly.
3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either
side of the ice crusher.
7. Lift the ice crusher out of the bucket.
8. Remove the ice crusher back cover.
9. Remove the locking ring from the ice crusher auger.
10. Remove the plastic nut with a pair of pliers by turning it clockwise.
11. Remove the spacers and blades. The blades are numbered for reassembly.
Ice Dispenser Auger Drive and Cube Solenoid—
The ice dispenser drive motor and cube solenoid are located in the upper rear of the freezer compartment. The drive motor moves the auger via a fork located on the drive motor. The cube solenoid allows cube or crushed ice to be dispensed on demand.
1. Remove 1/4-in. housing mounting screws (4) located at the four corners of the housing.
2. Slide the housing forward until the connector is visible, disconnect the connector, and remove the unit from the housing.
Note: Drive fork has reverse threads; turnclockwise to remove.
3. Remove the fork from the drive motor by turning it clockwise.
4. Disconnect the motor connectors and remove the ground wire.
5. Remove 1/4-in. mounting screws (3) and remove the motor.
6. Disconnect the cube solenoid wires.
7. Remove cube solenoid 1/4-in. mounting screws (2) and remove the cube solenoid.
Also check the connections with the control board.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 28, 2009
  • 1 more comment
  • Rylee Smith
    Rylee Smith Sep 28, 2009
    Hi
    I gave you disassembly instructions for ICE DISPENSER & Solenoid as you'll need to check these. To check you'll need to disassemble it. Also, check the voltage on Connector J7, pin 2 Silver colored wire—it is for Cube
    solenoid. The voltage is measured between connector J7 pin 2 to J7 pin 9, the voltage should read 120 Volts (AC). If it is less then there is an issue with the connector cables or the solenoid has gone bad.
    Thanks
    Rylee
  • Rylee Smith
    Yes, the problem is with the control board and not with the solenoid. The control board is located in the back of the unit.
    This card controls the operation of the unit. If a fan short has occurred,
    replace the fan prior to the card or the card will be destroyed.
    1. Secure power to the unit.
    2. Remove the 1/4-in. processor card panel screws and remove
    the panel.
    3. Disconnect the processor cable connectors.
    4. Remove the card by unlocking plastic locks located at the
    corners of the card.
    Thanks
    Rylee
  • Rylee Smith
    Hi
    The control board i referred is the main control board, this is the board that controls all the operations.Please see this picture, main control board (part #801) --
    You can order the parts for your refrigerator from this link--
    GE PSS26MGTBWW Parts
    Thanks
    Rylee
My GE refrigerator GDS18LBPWW with freezer on bottom does not cool in the refrig. section. Yesterday, I pd $239 to have the Evaporator Fan motor replaced. The freezer is fine and back down to 26, but the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The ideal temp for the freezer is around 10 degrees F.
Look at the evaporator coils behind the rear cover inside the freezer and check the ice forming on the coils.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} . Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM
Dec 29, 2009 | GE GDS18LBP Bottom Freezer Refrigerator
Our GE Profile Arctica will not make ice cubes.
You have 2 problems .
1 . the water valve is not letting enough water in . Pt # WR57X10032 . This is located on the back of the refrig , where the wall water line connects to , on the refrig .
2 . The dispensor flap door , is not closing completely , to seal off the warm outside air , thereby , causing frost on the inside dispensor area , and , on the bottom of the ice dispensor bucket . The usual cause , is the door flap solenoid , pt # WR62X10055 . The plunger , which comes with the solenoid , usually rusts , causing the flap not to close completely .
Dec 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Only 1/2 voltage to compressor. Also, low voltage
Your control board has failed and you will need assistance. Sea breeze
Nov 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My ice cube tray won't fill. water supply to the fridge is ok. water in the door works. new filter just installed. have taken hair dryer to inside and outside of where water line comes through back wall...
these are not pumps,
they are solonoids,
they open with applied voltage, and magneticlly close.
trace your water lines, the one closest to the back should be the water solonoid, the other would be the ice,
you can test it if you have a direct test cord,
or you could ohn it out...
if can find out if that actually opens when 110v is applied then you will know its the ice machine no calling for whatever reason....
Oct 12, 2009 | Refrigerators
Ice dispenser won't work, light won't work.ge side by side fridge
A GE uses a 12 volt bulb . It will not come on , if you went and bought a bulb with the same receptical end . HAS to be a 12 volt .
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser is not operating. will dispense ice occasionally. noticed the light in the dispenser opening gets dim. Water is dispensing normally.
When it doesn't dispense , do you hear the auger turning ? If so , then the dispensor flap is not opening completely . This is caused by a rusted plunger in the solenoid which opens the flap . If you use crushed ice often , then could be a build up in the ice shoot which has to be cleaned regularly .
Jul 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
Icemaker works fine, only dispenses water
make sure that the ice shoot is not clogged up with ice or the in the ice basket where the ice goes through. Sometimes the ice can be stuck together and jam and nothing will come out.
Nov 25, 2008 | GE GSS25JEMWW Side by Side
The ice flap in the door does not open when ice falls down the chute
The door is opened by a electrical solonoid, not by the ice itself. This solonid gets corroded due to moisture, To axcess the solonoid remove water tray remove three torx screws removing trim panel, remove 3 more torx screw holding dispenser module to freezer door two on either sides and one by paddle. Maytag has a kit called a fountain door kit that has everything to rebuild the ice door system,
Jan 10, 2008 | Maytag MSD2454G Side by Side Refrigerator
GE Icemaker flap door won't open causes ice jam in chute
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
Oct 02, 2007 | GE 17.2 cu. ft. Top Freezer Refrigerator...
Frost buildup on ice/water dispenser
Is the trap door flap closing properly where the ice comes through the door? If open, warm air would be coming in frosting and maybe iceing things up
Aug 27, 2007 | GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW...
Refrigerators Logo
79 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
