Sub-Zero 690 Side by Side Refrigerator
Problem for Sub-Zero 690 Side by Side Refrigerator
Light on refirgerator side doesn't come on unless I tap switch.
By gaillav on Sep 28, 2009
Sometime even manually pushing in and releasing the light mechanism doesn't work. Other times light comes on after a few seconds when fridge is opened. Sub zero 690 is 10 years old. Is there an easy solution?
Solution #1
posted on Sep 28, 2009
Not Rated)
woodchuck789
Rank: Guru  Refrigerators  Expert
Rating: 91%, 574 votes
I had to take my switch apart and clean and lube it and it worked fine. Or just replace the switch. It may have gotten some sticky ketchup in it like mine did.
Was this helpful?
Yes
No
Popular Solutions for Sub-Zero 690 Side by Side
Questions and Unsolved Problems for Sub-Zero 690 Side by Side
Do you recommend Sub-Zero 690 Side by Side Refrigerator?
Answer
Answer
brown liquid coming out of the bottom of my subzero side by side refrigerator/freezer. what is the... (More)
Answer
Sub Zero refrig has vacuum condenser indication even after I cleaned the coil and the unit seems to... (More)
Answer
when you open the refrigerator the inside light sometimes comes on and sometimes it dosnt. i... (More)
Answer
Where is the light terminator located in a sub zero 690 freezer?
Answer
I can't get at the light bulbs to change them in my Subzero side by side. Its any older model and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sub-Zero 690 Side by Side...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
