Question about Archos 604 WiFi Digital Media Player
Archos 604 Wifi Recovery Code 2
Its shows up that my system is damaged
and ask me if i would like to Repair it options
"NO"
"Repair"
"Format"
I tried everyone and it didn't do anything....
Plus i can't update the firmware....BECAUSE! THE DEVICE DOESN'T EVEN SHOW UP ON MY COMPUTER! IT DOES NOT CONNECT AT ALL!
  • 1 more comment
  • shot_key Dec 20, 2007
    I have the same problem and no matter what I hit I cannot fix it. Can anyone help us!!!!
  • ohgeeizme_ng Apr 16, 2008
    me too but code 3
  • ken stofferahn May 07, 2008
    recovery (code 2) Someone else?
  • 4 Answers
Hello everybody, i had this same problem with my archos 604 wifi but thankx to someone on another forum i fixed it. it is really easy:
first you take the battery off, then you unscrew the 4 or 6 screw on the sides of the hard drive, then you lift the lid and then the hard drive, VERY CAREFULLY, Then you will see the problem : the little black plug conected through a ribbon to the hard drive is not plugged correctly or it is completely unpluged from the white socket. even if it is not un plugged just make sure it's tight, put everything back together and it should work just fine. ( IT IS A LITTLE DIFFICUL TO SCREW IT BACK TOGETHER BUT YOU"LL GET IT RIGHT) it is a weird problem. but it is easily fixed.
i hope that helps, bye
Posted on Apr 18, 2008
  • davchad2003 May 17, 2011
    my ribbon connection was on a skew, but no amount of poking would correct it - it was tightly connected. reassembled - no change.
    had another look - ribbon disconnected at harddrive. pushed it (gently) back in, reassembled, still no joy. doesn't register on my PC, but will attempt to follow "wristaction" solution 2. let you know if I get it sorted.
  • 33 Answers
I was watching a film on mine and it paused and I hade to hold in the power button to shut it off.
When I restarted it I get that error message too.
I did the same as everyone else with no luck, so I left it on thinking that maybe running the battery down and charging it again might help but no luck.
I left it for a week then decided to have another go at fixing it.
I removed the battery and used the reset button to set it to factory defaults.
I powered it up and got the error message and tried the USB cable again (Can't remember for sure if it was on or off when I connected it) and I got the option of connecting to my PC and copying a system update to it.
I downloaded the update and copied it to the harddrive and it then updated itself and restarted.
It booted up ok but when I restarted it I get the error message again.
I redid the first bit again and using the XP Disc Management I removed the partition, then redone it.
I restarted the 604 and formatted the harddrive and copied the update and it updated and restarted again.
The pointer needs to be calabrated again on it to work but it's back to normal now and working great.
I set everything up and copied all the folders into a folder on my PC so if it happens again I just need to fix the harddrive and copy the files over.
I checked the cable on mine and it is tight so that was not the problem with mine.
Posted on Jun 14, 2008
Also had the Code 2 error. Had a look at the harddisk and noticed the ribboncable in the pcb side was not completely in the socket on one side. Reconnected and started up normal.
Beware, the screws are very small, you need a very small (watchmaker) screwdrive or , as I did as my smallest screwdriver was still too big, a knive. As mentioned before, putting it back together can be fiddly but you should check this first before sending it for repairs.
Posted on May 31, 2008
Hello i have a problem my archos 604 30 gb is broken i dropped it and every time i switchting it on a following information is shown on the screen : Recovery (code 2 ) System is damage.Would you...
Sounds like the hdd has dislodged due to the knock...open it up pull off the hard drive...reconnect it..or reseat the connection..and try again...if that doesn't work...you could try removing the drive to run a chkdsk facility using Linux on a pc...or source another hdd off eBay with the correct file system and drivers...for that model.
Dec 16, 2017 | Archos 604 Digital Media Player
My archos 605 won't do anything but to show recovery code 102.
recovery code 102 screen - this error message means the the hard disk has failed - I am guessing that the unit has been dropped at some point - Sorry but it back to Archos - The UK number is 0207 949 0115
Jan 20, 2009 | Archos 605 WiFi Digital Media Player
Archos want work
Sounds like a disk problem. This might work for you ...
Power off the unit
[Optional step - remove battery and use a pen to push the reset button]
HOLD down the LOCK/TV-LCD button as you press the POWER button until the unit starts to come on.
You should should get options to recover the disk (try this first) or format the unit (try this last).
If that doesn't work i would follow the procedure of reseating the HDD connection - see solution for Recovery error code 2 problem.
Dec 25, 2008 | Archos 604 WiFi Digital Media Player
Archos 604 wifi corrupted
Did you try ?
- Using the reset button located under the battery?
- Holding down the LCD button as you press POWER to start up the unit and trying one of the recovery options?
PK
Dec 19, 2008 | Archos 604 WiFi Digital Media Player
Archos 605 wifi recovery code 107
Carbon Adsorption Solvent Recovery Systems
Oct 21, 2008 | Archos 605 WiFi Digital Media Player
Code 108 shows on archos 605
The archos 604 is a portable media player. It is not a PC. The Archos 605 WiFi runs embedded Linux on an ARM processor.
Here is a reprint of someone who solved this problem:
i just got my Archos 605 and when accessed the content portal it said i should update my firmware. when i said OK i got the message it faild connecting to the server and my archos froze.
after restarting it i'm getting the Recovery code (108) i tried to repair disk and format disk but both asking me to conncet to the PC and update the system. the problem i cannot conncet to the PC (i don't see the HD) and don't know what to do.
i managed to solve the problem, if you encounter same problem this is what i did:
1. connect the archos to the PC
2. click on repair
3. click on done and wait for a few seconds and you will see the archos as a drive in your windows (be patiant it takes some time)
4. once you see the drive, open it and make sure the System folder is empty, if not delete the file that exists there.
5. put the firmware update file directly on the root drive
6. click repair again on the archos and done.
now it should recognize the update file and perform the update
it worked for me
Oct 19, 2008 | Computers & Internet
Archos Recovery (code 2)
Send them back to Archos if they are still under warranty. If not, you're out of luck because they'll charge you about US$140 to repair the hard drive + postage.
Sep 10, 2008 | Archos 604 WiFi Digital Media Player
Hdd recovery 2 problem
I have the same problem with my Archos 605 Wifi.
I found out that my harddrive was broken. so i replaced it with a new one.
Formatted it, system installed the OS and Media Files.
I downloaded the firmware from the Archos website itself!.
Also this went well. Than i had to confirm with ''done''.
But still i keep cycling through a circle of ''rebooting'' and receiving the ''HDD_Recovery_2'' screen. With the only selectable options:
''USB'' and ''Format''
Please does anyone know the solutions???
Jul 13, 2008 | Archos 605 WiFi Digital Media Player
Archos 404 recovery code 2
i have an archos 404 the problem is that my archos show me the recovery code 4 to repair or format the disk so when ever i repair and format the disk the problem is solved. so please help me regarding this.
Mar 01, 2008 | Archos 404 Digital Media Player
HELP!
Can you hear HardDrive clicking?
Oct 03, 2007 | Archos 604 WiFi Digital Media Player
Archos 604 WiFi Digital Media Player Logo
269 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
