Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Paper jam light on when there is no paper jam
DX4050 paper jam light on when there is no paper jam, how to get rid of it.
  • hastcdf May 11, 2010
    Here is some great PRINTER solution by Some FIXYA EXPERT.
    Get any kinds of PRINTER solution from bellow.
    » Brother Printer Solution
    » Canon Printer Solution
    » Epson Printer Solution
    » HP Printer Solution
    » Lexmark Printer Solution
    » Xerox Printer Solution
    » Other Printer Solution
2 Suggested Answers
SOURCE: My Epson DX4050 keeps showing
Having had a similar problem, I can say that you almost certainly do have a paper jam in that the paper clear sensor is being prevented from dropping into a small recess under the paper path, by debris of some kind. You cannot see or access this sensor without dissembling the whole printer and lifting the mechanism clear of the plastic case. Once you know where all the fixing screws are, this can be done in a few minutes, but it is not a job that should be undertaken unless you have a fair degree of mechnical dexterity and are used to disconnecting very small plugs and ribbon assemblies. The secret to getting the printer apart is the removal of the control panel underneath which are more holding screws. This is done by lifting the rear of the panel with a small screw driver in the notch provided, and firmly pushing the panel to the rear of the printer. Once clear a small ribbon connector needs to be detached.
Posted on Mar 28, 2011
Epson dx4050
Hello gemma almond,
Welcome, and thank you for using FixYa!
To answer your question: Your printer will need to be cleaned inside and checked for small shards of paper jammed within the paper feed path.
If you look inside of the printer, you will see small, rubber, feed tires (wheels) that pickup the paper. These tires also ensure that the paper feeds entirely through the printer. These tires can become dry and coated in clay off of the paper you use. Once they become coated, they slip on the paper.
Use a paper towel with Windex or Rubbing Alcohol to clean up these tires and an access ink you see inside of the printer.
This should fix your issue.
Have a great day!
Oct 27, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Brothers HL-5370DW. Yesterday, I printed about 20 sheets with no problem. Then I set up to print more pages and the yellow paper light started blinking and the red status light came on. I checked for a...
I had the misfortune of between two sheets of paper, out of the packet, there was a piece of tape that jammed the drum.
Nothing else for it with your, take the drum and toner out and check for bits of paper.
Mar 11, 2017 | Brother HL-5370DWT Laser Printer
My Epson DX4050 keeps showing a paper jam and will not feed paper. there are no evident blockages and I have hoovered out the internals to clear any dust. The printer has been low usage.
Jan 04, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How do you get rid of error light with no obvious paper jam on HL2140
the eror is probably caused by dust or paper slivers somewhere or a open door or the paper trat not being in right. Open everythign up look for dust and stuff then makre sure it is all closed and the tray in in right. It should then reset and the error goes out.
Usually this is from dust on sensors or a tiny sliver or paper jammed somewhere. Can be quite annoying to find and get rid of.
Mar 23, 2010 | Brother HL 2140 Laser Printer
Rear Paper Jam - No paper present.
Look for a small piece of paper that may be stuck in the switch indicating a paper jam.
Jun 01, 2009 | Canon PIXMA MP610 InkJet Printer
Paper jam error
there are sensors located in the paper cart area. try to check if there foreign objects obstructing your sensors.
Apr 18, 2008 | Canon I900D InkJet Photo Printer
Paper jam
here try this guide to clearing Jams supplied by HP
Clearing Paper Jam Guide
I hope this clears your problem :)
Apr 02, 2008 | HP Photosmart C4180 All-In-One InkJet...
Dell 924 Inkjet Printer False Paper Jam
Got rid of my problem!
In an act of despair I started to poke around the inside of the printer with a wooden match. Especially I found a small black lever mentioned on a Dell web site (general paper jam help page) that could be pressed a little. It is placed just a little bit right of center behind the carriage and just above the roll that feeds the paper beneath the printer heads. I'm not sure if this was what finally did it, but now the paper jam problem has gone away.
Another thing I noticed is that my carriage is now moving to center when I open the top. When the paper jam error was present it always moved to the far left (so I could remove any jammed paper, I suspect).
Mar 30, 2008 | Dell 924 All-in-One InkJet Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
127 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
