Question about Canon Powershot SX110 IS Digital Camera 9.0MP
My camera has the canon ACK800 adapter , but sometimes, the camera turn off and its a real problem. What can i do or why is the camera turning off? Tks.
Can you get other forms of power than 2 x AA batteries for the Canon SX100 IS Camera
You can use the AC Adapter Kit ACK800, available as an optional accessory from Canon.
Mar 10, 2013 | Canon PowerShot SX100 IS Digital Camera
Will the ACK800 adapter kit charge my camera and allow me to use it without the kit being plugged into th camera?
The A495 does not charge batteries. The adapter merely allows the camera to run on external power.
Feb 11, 2012 | Canon PowerShot A495 Digital Camera
Which adopter i can use for DC
One item is the Canon AC Adapter Kit ACK800, as listed here.
Oct 04, 2011 | Canon PowerShot A410 Digital Camera
I have a Canon powershot A1100is dig camera. When I try to turn it on, it reads need new batteries. even if I change the batteries. Sometimes it wont even turn on. Help
Do you using Ni-MH batteries? Canon cameras judge the battery is low power by the real-time voltage of the batteries. And the voltage of Ni-MH batteries are lower than Li-ion ones, so the camera will notice low power even there are new batteries. Try Li-ion ones and see is anything help. best wishes!!
If you will use of a special battery, please come to our online shop for digital camera batteries
Feb 21, 2011 | Canon PowerShot A1100 IS Digital Camera
Brand new Canon EOS Rebel XS. Suddenly, image in the view finder is blurry. Auto focus seems to be working, and pictures are coming out fine. But sometimes, the autofocus focuses on the wrong thing, and so...
Next to the viewfinder ther is a diopter adjustment so you can change the focus in the viewfinder. this is so if you need glasses the camera can be set for you. Start by focusing the camera on something, then slide to turn the diopter adjustment until it looks sharp and try not to bump it.
Jun 21, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Canon eos rebel xsi not detected by mac (but it was for a long time, now out of no-where, it is no longer detected)
the same thing happened to me, maby the camera has experianced a knock, try getting it seen to by a real person
Apr 19, 2010 | Canon EOS Rebel XSi Digital Camera
Won't turn on
Make sure the battery is new or in good shape to hold a full charge. It may be a good idea to check the voltage the charger is putting out. Also test the voltage the battery is receiving and holding when not in the camera.
It may be possible to test this camera with an external voltage adapter of the correct voltage. If you can get the camera started, then go to the menus and set all to factory default settings.
If you still have no results, then I would suggest to call Canon at the repair department and ask questions, and also find how much a repair is. Canon also has a trade-up or trade-in program.
Go to canon.com and to the repair section.
This same thing happened to one of the cameras I had which is similar. The external power supply made it work, some problem is internally. Canon had checked it for me, and found internal damage due to water buildup on the circuit board.
Oct 04, 2009 | Canon PowerShot G9 Digital Camera
Is there any possibility of charging the camera(canon A400) directly than using the battery charger?
You can get an AC adaptor kit that will power the camera. It is called the ACK800 and costs $49. It's available directly from Canon here: http://estore.usa.canon.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10051&storeId=10051&partNumber=7897&langId=-1
Jun 16, 2009 | Canon PowerShot A400 Digital Camera
Attaching it to a Canon EOS 400D REBEL XTI
Totally different lens mounts, you might be able to get an adapter ring, but it wont function amazingly. Honestly, you're better off just selling this lens and buying a Canon 70-300 instead.
Apr 30, 2008 | Tamron 75-300mm f/4.0-5.6 LD Lens for...
Pro1 Lens tracking problem.
Have you looked through this list? http://www.fixya.com/support/p293975-canon_powershot_pro1_digital_camera/solutions But it will need pro repair . check Canon Website also
May 17, 2007 | Canon PowerShot Pro1 Digital Camera
Canon Powershot SX110 IS  Digital Camera 9.0MP Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
