Question about Danze Plumbing
Danze kitchen faucet spout difficult to move from one side to the other in a double sink.
  • Anonymous Mar 13, 2014
    prescott 4720
  • 127 Answers
O-rings in the spout need to be greased or replaced...use silicon grease if you are greasing them....not petroleum based product.
Posted on Oct 18, 2009
Water Ridge kitchen faucet model FP4A4107NP does not swivel between sinks. I thought they all could be directed into either side of a double sink?
Did you install the faucet without using the top mounting plate? This could cause no spout swivel.
Dec 26, 2014 | Plumbing
Faucet leaking at tee where hot and cold connect to spout
The designs of the Kitchen Sink Faucet mainly exhibit differences in its handles and spouts. Differently curved spouts and handles diversify the range of products. Some have long spouts and some are with short ones. The spouting of water may also give different flow patterns with the external fixtures. The handles are mainly in single or double.
source Best Kitchen Faucets
Feb 03, 2012 | Kohler Fort© Widespread Lavatory Faucet...
I have an American Standard kitchen faucet aqua source model no. 5913100075. It comes with the sprayer hose inside the faucet. I have a double sink. I would like to know 'do you hold on to the faucet...
pull it out as far as you need. You will not hurt anything just dont try to wash the car its not that long
I have my spout in the middle and I pull out all I need to clean out both sidees it works just fine
Thanks Richard
Sep 07, 2011 | American Standard Plumbing
Our American Standard kitchen faucet has become hard to swing from one side of the sink to the other. What could be causing this? Is there a bad part?
Hi! If there are no leaks from around the spout, you can remove the spout and apply silicone lube to the spout o-rings and resemble. If it is still hard to move ,replace the o-rings.
Jul 15, 2011 | American Standard 4205.001.021 Reliant+...
Water is dripping out the back of the the Danza 61/9 kitchen faucet
Just in case you need to do so.
  1. Turn the water off. The water control knob is located under your sink and is connected to the drain. Turn it counterclockwise to turn off the water.
  2. 2
    Open the faucet to relieve any differences in pressure. Pull up on the faucet as you would if you were turning it on.
  3. 3
    Plug the drain of the sink with its stopper to prevent any parts from going down it.
  4. 4
    Turn the faucet handle sharply to one side to reveal a small cover plate. Pry the plate off carefully with a flat-bladed screwdriver.
  5. 5
    Unscrew the screw that is located behind the cover plate with a 4 mm allen key.
  6. 6
    Lift the handle off and remove the cap beneath it.
  7. 7
    Firmly grip the exposed cartridge with your hands and pull up to remove it.
Read more: How to Remove the Cartridge from a Danze D403412 ' eHow.com http://www.ehow.com/how_7640485_remove-cartridge-danze-d403412.html#ixzz1D76xWEgn I your case I think all you need are new o-ring seals on the spout. once you have the handle off and have gotten to the cartage grab the spout and turn back and forth while pulling up and remove the spout you will see the o-rings. I would get the repair kit before you start. The video below is not your brand faucet but the o-ring replacement is about the same. http://www.youtube.com/watch?v=AipEYoYiIhc
Feb 05, 2011 | Danze D403412 Melrose Single Handle...
We do not have book on the kitchen faucet which was purchased by a previous owner. Looks just like the Danze D306357BN. It is leaking from the first joint above the base. A plumber could only tell us that...
there are several O-rings inside the spout assembly. 3 that I know of from memory.<br /> <br /> here is a link to the PDF parts breakdown to show your plumber. also that faucet is for the bathroom sink.<br /> <a href="http://www.danze.com/product_details.asp?g=2&amp;mg=5&amp;id=D306357BN">http://www.danze.com/product_details.asp?g=2&amp;mg=5&amp;id=D306357BN</a><br /> the link to the PDF is at the bottom of the page "illistrated parts list" <br /> <br /> here is the link to the kitchen faucet. just click on the "illistrated parts list" to get the breakdown.<br /> <a href="http://www.danze.com/product_details.asp?g=1&amp;mg=1&amp;id=D414357">http://www.danze.com/product_details.asp?g=1&amp;mg=1&amp;id=D414357</a><br /> <br /> if neither one of these is your faucet, just continue looking through till you find yours, and call a different plumber.<br /> <br /> hope that helps<br />
Aug 31, 2010 | Danze Plumbing
I have a Danze Melrose collection Pullout kitchen faucet that is very stiff to turn from one sink side to the other. How do I get it to loosen up?
shut the water off take the spout off some times dirt gets between the base and spout clean and if you have a gasket i would change it
Aug 08, 2010 | Danze Home
What makes the faucet bind?
I'm just installing the exact same faucet and I found that the side to side motion was binding if I tightened the tap too much from the bottom with the nut & "c" shaped clamp with the 2 set screws. Not sure what it could be if yours was fine & started having trouble.
They have support contact info on their website that you may want to try: http://www.danze.com/customer_support.asp
Good Luck,
-David.
Apr 10, 2010 | Danze Plumbing
I have a Mico 7777 Kitchen faucet that was purchased in 2001.It has become difficult to move from side to side. Do we need to replace the cartridge in the faucet and if so how much does it cost and how...
it may not be nesesary to replase the cartridge you could just have some lime or sediment build up in the faucet a bad cartridge would effect your handle not your spout turn the hot and cold water off under the sink,pull the bonnet or cap off and the spout should just lift up take care not to damage o-rings pulling and reinstalling spout check for debris clean and replace spout to insure not damaging o-ring try putting a little vaseline on them 1.it will help go on easier 2.it will help to lubricate the swivel of the spout replace the cap turn your water back on. if your cartridge is bad your faucet will drip or constantly run
Apr 07, 2009 | Plumbing
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
676 people viewed this question
Top Danze Plumbing Experts
john h
Andrew Bugbee
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
