Question about Cell Phones
I have recently installed a Panasonic KX-TG8321E with six handsets but find when I call home with my Apple 2G iphone the system does not ring and the iphone gives out an engaged tone after one ring. Unplug the system and the hard wired phone rings normally as does my other line not connected to the Panasonic system. I have tried with other phone system without a problem. Help me please!
  • 1 more comment
  • rknott Sep 28, 2009
    I have just changed from a NTL dect system which worked fine. I have not touched the wiring before installing the Panasonic
    The system receives all calls perfectly except from my iphone. All outside calls and other mobiles including my wife's work perfectly. The system is set to 7 rings to give us the best chance of answering from any location in our rather large house.
  • rknott Sep 29, 2009
    I will try to see if this solution is possible.
  • 615 Answers
I do not know how far you been working with others but I would like to ask if you checked to see if your phones can be changed to different frequency? in every wireless phone you can select different frequency so see if this one has the ability to do that and if it can change it and test your system again it is just a matter of selecting the correct frequency that match your 2G as it sound that it is not getting the signal from it so keep changing the frequency tell you get one that recognize yours.
Let me know how this worked for you and please do not forget to rate my service so we are able to improve on it. The rating as follows 1 the service was not related to the post. 2 the service was related but not did not help at all. 3 the service was to the point and somewhat complete. 4 the service was excellent and to the point.
Posted on Sep 28, 2009
  • Norman Al-Anbar Sep 29, 2009
    I noticed that you addressing wiring etc. with another tech I believe this issue does not have anything to do with wiring. You stated that everything work but for your 2G and that is why I asked you to check the frequency if both systems could not find a meeting ground they will not be able to communicate. Do not waste your time troubleshooting something that does not make sense.
    President:
  • 1,653 Answers
You can change the number of times the phone rings “Number of Rings” before the unit answers a call. You can select 2 to 7 rings, or “Auto”. The default setting is “4 Rings”.
“Auto”: The unit’s answering system answers at the end of the 2nd ring when new messages have been recorded, or at the end of the 5th ring when there are no new messages. If you call your phone from outside to listen to new messages, you know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call. Do the following to set the number of rings. Each [xxx] represents a button – unfortunately the graphics are not printable on this forum.
1 [Menu Display Button] [Answer System]
2 [Up Arrow or Down Arrow] [Settings] [OK]
3 [Up Arrow or Down Arrow] then display [Number of Rings] [OK]
4 [Up Arrow or Down Arrow] to set the number of rings [OK] [Off/ Power]
  • 11,896 Answers
It may be the system itself. Double check for crossed wires, disconnected wire connections. Make sure system is not interfering with another system. Two system on one machine may do this. Otherwise try a different system
Can I get replacement phones (3) for Panasonic KX-TG6843B 6.0 3-Handset Cordless Telephone? This phone blocks up to 250 calls. If I keep the base, will I keep my blocked numbers.
The stored block numbers should be saved. The database is in the base's memory. Since the KX-TG6843 base can support a total of 6 KX-TGA680S handsets, you can purchase and register 3 new handsets. If needed, you can de-register the old ones from any working handset and then add even more. See page 35 of the manual, ftp://ftp.panasonic.com/telephone/om/kx-tg6841_mul_om.pdf . Additional handsets are available from Panasonic, http://shop.panasonic.com/support-only/KX-TG6843B.html , Scroll down to the Accessories section and expand it. Amazon.com also has the handsets: https://www.amazon.com/Panasonic-KX-TGA680S-DECT-Accessory-Handset/dp/B00BS4D2CU .
I hope this helps.
May 30, 2017 | Panasonic Lands Phones
Set up answering system
Follow the instructions beginning on page 57 of the manual at ftp://ftp.panasonic.com/telephone/om/kx-tg7622_mul_om.pdf
May 26, 2016 | Panasonic KX-TG7622B DECT 6.0 Plus...
Where can I get an instruction manual?
Panasonic kx-tga600b handset manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tga600b cordless extension handset manual. Panasonic kx ...Panasonic kx tga520 5.8 ghz fhss cordless expansion handset manual. Panasonic kx ... Panasonic kx tg6071 operating instructions manual pdf download. Panasonic... Need manual for kx tga600b so i can turn off voice mail dont need. Panasonic ...
Kx-tg6500 manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tg6500 operating instructions manual pdf download. Panasonic ...Panasonic kx tga650b cordless extension handset installation. Troubleshooting ...Panasonic kxtga651b dect 6.0 plus expansion handset black kx. Panasonic kx ...Can i register a kxtg6500 handset with a kxtg4500 base. Panasonic kx tg6502 ...
Panasonic KX-TGA650B ' Installation Manual - Page 3
Feb 09, 2016 | Panasonic KX-TGA650B (037988474806)...
How do I leave a message for my answering machine
Ask the service provider
Panasonic KX-TG6531B Digital DECT 6.0 1X Handsets Dual
www.fixya.com/.../p3148769-panasonic_kx_tg6531b_digital_dect_6_0...
Recent Panasonic KX-TG6531B Digital DECT 6.0 1X Handsets Dual Voltage Cordless Phones Integrated Answering Machine 110-220 Volts questions, problems & answers. ... Model KX-TG4021 - How do I put in a new answering message? ... Why won't my answering machine, Panasonic Easa-Phone KX-T1460 allow the ...
change amount rings panasonic kx tg7643 Answering ...
Jan 12, 2016 | Panasonic KX-TG6531B Digital DECT 6.0 1X...
KX-TGA660 handsets - 3 of 5 wouldn't ring (no sound)
sounds like who ever installed your service was an amateur, all points should be gone over by a senior tech, piece by piece!!
Nov 14, 2013 | Panasonic Lands Phones
NEED USER MANUAL FOR KX-TAG931S PHONE HANDSET What I really need is how do I make the incoming call go to Voice Mail without it ringing 4 times.
You may download the KX-TGA931 manual from http://shop.panasonic.com/shop/model/KX-TGA931T?support
The number of rings is controlled by the answering machine or voicemail system on your phone line. It cannot be changed from the handset. Please refer to the documentation for whatever answering machine or voicemail system you have.
If you require further assistance with the answering machine or voicemail system, please tell us the make and model.
Sep 23, 2013 | Panasonic KX-TG5210M GigaRange Supreme 5.8...
Will a panasonic KX-TG2257 cordless phone work with a KX-T6160 system?
I'm not familiar with a KX-T6160 system, so do you mean SIX-SIXTEEN-DEE(616d) or SIX-SIXTEEN-TEN (61610)? Either way, the cordless phone works. You need access codes, like 9 for an outside line, FLASH and dial an extension for transfer, 40 for ringing call pickup (on the 61610), and 58x (61610) to pick a line from hold. Your phone system manual has a single line telephone user guide in it.
Carl
Apr 30, 2011 | Panasonic KX-TG2257 Cordless Phone
How do access my panasonic kx-tga101s voicmail ?
First of all; Do you have the user guide manual? If not you can download it for free at...www.static.tigerdirect.com/pdf/panasonic_kxtg10325_manual.pdf
This manual addresses handset kx-tga 101s.
The unit lets you know when you have new voice mail, in the following ways; "new voice mail" is displayed on the handset; The message indicator, on the handset, flashes slowly if message alert is on. In order to listen to your voice mail messages, you must dial the telephone service providers voice mail access number. If the handset still indicates messages that have been listened to turn it off by pressing and holding "CLEAR" until handset beeps.
Do you subscribe to a service package that includes voice mail? If so, to use that service turn off the answering machine; And use the instructions provided by your service provider. If you want to use the answering system, call your service provider to deactivate your voice mail service. If service provider cannot do this then set the answering system "RING COUNT" so the system answers calls before voice mail. Check with your service provider to find out what the ring count of the voice mail service is , then make the answering system ring count so it answers first.
Let me know if this answered your question.
FixYa WIZ....saailer@att.net
Dec 05, 2009 | Panasonic KX-TGA101S Cordless Handset
Lost instructions for Panasonic telephone KX-TG8321E.
Hi, you can find a free download here...
http://www.panasonic.co.uk/html/en_GB/Support/Downloads/220239/index.html#anker_220239
Just type in your model number and it will bring up a link to download 'operating instructions' or a 'quick guide'.
Hope that helps?
Apr 30, 2009 | Lands Phones
Panasonic moddel kx-TG6021
Find a friendly neighbour an plug your cordless system into thier phone sockets and see if it works in another jack, if not take it back if its under warranty
Jun 19, 2008 | Panasonic KX-TG1033S Cordless Phone
Cell Phones Logo
55 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
