Question about Kodak EASYSHARE M1063 Digital Camera
Camera lens stay out don,t respond to on/off button,does not need to be recharged.
  • 101 Answers
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Posted on Sep 28, 2009
    Sergeant:
  • 151 Answers
For this problem try the following:
* Try removing the memory and the battery
* Try using the camera w/o the memory card
* If problem still persist call the Tech Number
1800 235 6325 op 12 op 2
Hope this will help
Thanks
Byron
WB610 Camera buttons & lens aren't working as they should?
As soon as the camera is switched on, the lens barrel will come out. Everything should be ready to shoot pictures. If it is not responding to the buttons, you could try to remove the battery for a few moments. It will cause the camera, to start from scratch. Call it a cold boot. But then after switching on, it should respond normal, like you used to work with it. If it stays frozen, visit your dealer or contact a Samsung certified repair centre.
Mar 10, 2015 | Samsung WB610 Digital Camera Black
Lens won't close and On/Off button doesn't work
Even though the battery appears to be charging it may be shot. Some batteries if they run down too far can not be recharged. You need to try a new battery in the camera.
Jul 25, 2012 | Nikon COOLPIX S6000 Digital Camera
When I push the power button, the lens cap comes out and on the screen is a very brief shot of what the camera is aimed at. The camera stays engaged for one second and the lens cap goes retreats back into...
Try to remove the rechargeable battery and use a battery of the same type but an alkaline like the energizer. Sometime rechargeable battery malfunctions that it seems fully charged but actually is not. If the camera continue to power on when you replace the battery it simply means that your problem is in the battery.
Nov 26, 2010 | Kodak EasyShare M1093 IS Digital Camera
My camera will not come on.
hmmm...if the lens in the front is stuck; take the batteries out, charge em (rechargable batteries), put em back in, press the power button once. the lens should come back in only. leave it for a while. hmm...if the green power does that then u need to charge ur batteries again for a really long time. it means the camera will not use the juiceless batteries.
May 13, 2010 | Samsung S760 Digital Camera
I click the on button on polaroid i834 digital camera, then stops
Sounds like the battery is too low. Replace/recharge batteries.
Oct 03, 2009 | Polaroid i834 Digital Camera
Optio s6 frozen
By recharging the battery, and then restart the camera, it may just work.
Because you were working on a movie in the camera at the time it quit, that file may be corrupted.
It would be interesting to see what has happened on this problem.
Jul 22, 2008 | Pentax Optio M20 Digital Camera
Camera won't respond
I just fixed it!, you need to use rechargable batteries, i had it set on rechargable and when i put alkalines in it it made that noise, but when i put rechargables back in it and gave it a slight pat against my hand to make sure nothing was loose inside it came back on and works fine!
Dec 25, 2007 | Samsung Digimax S730 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax S700 is frozen with lens open
I had this same problem, and all i did was pop out the SD card, and tried turning it on without it in there.  It powered up just fine.  I then replaced the SD card and all was well.  Possibly a problem with teh SD card.
Nov 30, 2007 | Samsung Digimax S700 Digital Camera
Battery problem
It probably lacked the power to retract the lens. I'd start with recharging the battery and see if that corrects the problem.
Sep 19, 2005 | Nikon Coolpix 5400 Digital Camera
Kodak EASYSHARE M1063 Digital Camera Logo
54 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
