I need a replacement switching power adaptor HASU12FB, input 100-240v, 50/60Hz, output 12v 5.0A for DMTECH tv.I can't seem to find one anywhere could you help please. Melanie from England.
  • 834 Answers
Go to Bestbuy and buy a universal
Posted on Sep 28, 2009
AC input pin broken
If it is part of the plug side that goes into the wall then it is not worth fixing. You can replace this pretty easy. On the front or back it will tell you what the input and output voltage are as well as the amperage. It will be 120v input and most likely a 12v output. Could be less like a 9 or 6 but that is the number you need to match. You will also need to match the amperage as well. It will most likely be in the milliamps. There are many universal adaptors that would work for you available at Walmart, Target, Best Buy etc....
Apr 13, 2014 | Casio CTK-541 Keyboard power supply ac...
Need a ac adaptor for a Protron PLTV-32. MODEL LU32A1A3. INPUT 100-240V 50-60Hz 3.0A MAX.Output +24V-6A +12V-3A
I found one through Powerpayless.com at http://www.powerpayless.com/ac-dc-power-adapter-for-protron-pltv-32-pltv32-lcd-tv.html. It works great!
Mar 01, 2011 | Protron Ac / Dc Power Supply For Protron...
Ac adaptor on my 32 Protron inch LCD TV no longer work
What is the current output of the adaptor? If it is AC and you use only the 12v to 3v it is ok. But if the current output of the adaptor is DC and you use both 24v to 6v and 12v to 3v there is some danger if use the new one. Remember that DC current have polarity.
Aug 29, 2009 | Protron PLTV-32 Television
I need to replace the power adaptor for a Maxtor One Touch 4 500 GB. I need to know the volt and amp output for it. PN:9NT2A4-500
Power Adapter for Mactor OneTouch 4
AC Input : 100 AC - 240 AC (50/60HZ)
DC Output ( V/A ) : 12V / 3.5A
Output Power : 42W
Apr 17, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Powering tv
Read any information on the 240v to 12v adaptor. If the 12v is DC yes you can use the Battery direct. If it is 12ac no can do.
Mike
Mar 29, 2009 | Televison & Video
Where can I buy Dmtech AC Adaptor HASU12FB - Currys no longer stock the part
You might want to try a HASU05F. They are the same voltage, current, and connector and run cooler.
Aug 15, 2008 | Televison & Video
The original power specs
As I search the internet I found out no replacement for this kind of the adaptor model number 090-02180-13, there are some people looking for this kind of adaptor is a faulty a pervasive problem with the TV. There are literally hundreds of complaints on the internet. Most deal with a faulty AC Adaptor and the inability of the company to provide a replacement part.
I have a solution for this adaptor problem we better improvised the parts inside. The faulty parts of this adaptor arise in the transformer. This transformer is easily to burnt because of lower amperage. So we make it higher amperage so it can resist the load heat and cannot burnt easily.
Maybe you can do this for yourself, open the adaptor case, when open already look for the transformer, the visual picture of transformer is a bulky metal with many windings. Take this out and bring it to electronic shop that know how to rewind a transformer. Tell them to reworks or rewind the transformer, only the output voltage will be change input is the same. This is the
NEW SPECIFICATION:
  • INPUT 100-240 V
  • OUTPUT + 24VOLT DC AT 12 AMP
  • 12VOLT AT 6 AMP.
This is the result of new specification when the reworks or rewind is finish ,put it back to the adapter box,and then you can use it.This is higher amperage I mean it to you before,it can resist overheating.If ever happens that you can't find in your place know how to do reworks of the transformer here in philippines i do the rewind or reworks of the transformer ,but the problem is.very far to your place it needs shipment to carry this out .I price you 120 dollars including shipment and i assure it to you that adaptor will last long because of higher amperage .
When i search i found a site that can make an ac adaptor only you give the new specification and give where you are using the adaptor give the brand name PLTV-32 and they will make it..try this option also ..LCDPAYLESS.COM
Jun 23, 2008 | Protron PLTV-32 Television
RLT1520TV-RV(S)
HI Maxine you want adapter model LAD6019AB5 input 100-240 VAC 1.5A output 12VDC 5A ROGER T.
Apr 07, 2008 | Relisys RLT-1500 15" LCD Monitor
Televison & Video Logo
761 people viewed this question
Top Televison & Video Experts
