Question about GE Quiet-Aire Ductless Mini Split System Air Conditioner
Brand new equipment compressor work 5 minutes,
Brand new equipment compressor came defective, it was replace,and was working during the charging procedures, until it reaches 150 psig of r410 a . starts working for 3 o 4 minutes. then it stops. then it starts againg for the same period of time. the brand is L G. it reaches 7,5 amps. it`s designed amps, is 9,2. the compressor when is working gets hot.what could be the problem?
  • 22 Answers
Sounds like your slugin oil back to compressor and its over working itself especially cause you have low amprage,you need to pull a vacum on the systemm and bring it down to -25 psi and hold that vac.charge for a good 2 or 3 hrs and then recharge with new freon not the freon that was pull out of system,dont flip jug or try to put any liquid in even know the system will act like it wants liquid just add the gas slowly and it will eventually recoop it charge and amprage should rise to 8.9 to 9.2 depending on the outside temp.note: if this unit is under warranty by manufacture they should replace it due to the fact of a brand new unit that has never ran properly since installed call manufacture for complete waranty details heres the basic warranty this unit comes with and phone # - WARRANTY
Labor Warranty Limited 1-year entire appliance
Limited 5-year sealed refrigerating system Parts Warranty Limited 1-year entire appliance
Limited 5-year sealed refrigerating system Have more questions? Please contact 1-800-626-2005.
hope this helps
Posted on Sep 29, 2009
Iconia w5 wont turn on battery wont charge
Try to connect charger and power on tablet by pressing power button during 5/10 seconds.
If that doesn't work, since it's a new device, I would recommend you use the service of ACER.
Apr 01, 2013 | Computers & Internet
Just had ac charged on 1995 Chevy Suburban after replacing, nearly, the entire ac system last autumn. Told there were no leaks (vaccum check). However, got the truck home and it still blows warm air and...
you can run the compressor for a few minutes to see if you get cold air with the low pressure switch crossed out. if you don't have cold air after about 5 minutes then you still have a leak somewhere.
Jul 30, 2011 | Chevrolet Chevy Cars & Trucks
Hi I have a goodman MSG-18HWN1 heating and cooling mini-split unit. The unit keeps going on and off on a cycle of about 5 minutes. 5 minute, unit not started, unit starts for about 5 minutes, stops for...
Due to abnormal temp of out door.Check outdoor fan motor and compressor and also sensor.
Fan motor not working- rectify/replace fan capacitor.
Sensor defective-Replace it
Compressor high amps-Replace running capacitor.
Sensor misplaced or defective-Place correctly or replace it.
Jan 05, 2011 | Heating & Cooling
It's a brand new Air conditioner, shuts off after about 3-5 minutes of being on then it restarts and continues this cycle. What should I do? Delonghi penguino 10,000 btu
Sounds like it is either low on Freon (factory defect) or the thermostat needs adjustment or is bad. This unit is "short-cycling". There is always a delay between shutoff and restart in A/C systems. This allows the pressures to equalize in the system so that the compressor does not try to pump liquid Freon (doesn't work and almost always fatal for the compressor). If it is this new, return it for replacement. I am assuming that it is a portable or window unit.
Jul 16, 2009 | DeLonghi PACT100P Portable Air Conditioner
A/C works in 5-7 minute intervals
compresser usually has low charge when this happens make sure its not leaking refrigerant get r134 with uv dye to locate leak
Jul 15, 2009 | 1999 Dodge Ram
Frigidaire side by side
My first thought is a compressor not running from your description of the clicking.
Compressor problems can be:
Could be a Relay, stiff compressor/motor assembly, low voltage, run, or start capacitor if so equipped.
You will need a voltage (amp meter would help) meter to check the voltage (amp draw) at start up on the compressor to determine if you are making headway on finding the cause.
You will have to verify the voltage for sure and during start up 1st unplug the refrigerator let it sit for 10 to 15 minutes. 1st During this time check the voltage at the wall plug. 2nd AT the compressor relay (2 wires to the compressor) when it first try's to start meaning while someone plugs it in. The reading can be up to 10% lower during this time. continue to watch the volts as it runs until it clicks again and cuts off. The voltage then should return to where it was at the plug-in. If not We now have a problem outside the compressor area. If so we are on the right path.
A replacement relay and overload (with the run and or start capacitor if equipped) replaced as a whole at the same time will either confirm its one of these components. With them replaced and correct voltage range during start of the compressor it will either work or your compressor is out.
Mar 16, 2009 | Frigidaire FRS26R4A Side by Side...
Goodman Heat Pump GSH 130601 5 ton unit - Compressor seized
Tell them you want a whole new outside system or a new compressor . Around here, the compressor change out should be around 5--$800.00 and the unit change out , around $400.00! OKLAHOMA.
Aug 02, 2008 | Goodman CLQ36AR49 Air Conditioner
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Oct 26, 2007 | Heating & Cooling
The compressor only works about 15 minutes
This unit could very well be over charged with gas and when the unit runs for about 15 mins. the pressure gets too high and cuts off on high pressure if your system does that so many times the compressor will get hot and shut off on internal over load, And will not come back on till it cools down. .... Or you may have a kink or restriction in your refrigerant lines somewhere... this would cause your compressor to also run hot and cut off on internal overload.
Oct 15, 2007 | Heating & Cooling
Won't charge!
HEADPHONES AND SPEAKERS Hi There Try this, VOLUME Try Adjusting the vlume on your PC first. Check the volume on the Headphone too if there is one. CLEANING Using a dump clothe. Wipe the plugs with a twisting motion. WIRELESS\BLUETOOTH Check your battery if it is drained. Try replacing them witha new one or charge them if they are rechargables. If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester. Hope This helps =============================================== If you are having trouble with a Newly bought items then return them a demand a replacement or a refund!You may have purchased a reconditioned\repaired\factory defect product.
Sep 19, 2007 | Motorola Mobility H500 Wireless Headset
GE Quiet-Aire Ductless Mini Split System Air Conditioner Logo
61 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
