Question about Cisco IP PHONE 7941 CH W/ LIC *2% DISCOUNT COD/WIRE Sys
My phone, (7941) only works in speakerphone mode. I can call someone via speakerphone and all is well. However if I pick up the handset it seems to go to mute. When I put the handset back down I can continue with my call. I'm sure it's just a setting but I dont know how to correct it.
    Problem Solver:
  • 5 Answers
Dect phone manual
Standby mode is when the phone is not on a call, you're not dialing one, and you're not doing anything with the menus. It's standing by, waiting for you to call or for someone to call you.
Aug 09, 2014 | Panasonic KX-TG4022N DECT 6.0 Single-line...
My phone is stuck on speakerphone. When I pick up...
There are two things to check that you can fix. First, try replacing the handset (curly) cord. A broken wire in the cord can make this happen. If that's not it, watch the hookswitch. That's the plunger that goes down when you put the handset in the cradle, and pops back up when you lift the handset. If it's stuck down, you will only get speaker and no sound in/out of the handset.
May 21, 2010 | Nortel Norstar 16-Line PBX Speakerphone
Doesn't answer calls or answers with speaker only
This is happening because your "Self-Cleaning" hookswitch is going bad. Since it's a carbon contact design, this will happen more and more frequently. I recommend sending your Cisco IP phones to IdacomUSA for repair and refurbishment. If you are the DIY type of person, we are also selling the pad and assembly for the Cisco hookswitch at $15 each (w/minimum order)
Jun 04, 2009 | Cisco 7940 IP Phone
Handset
I guess its time to get new batteries
Sep 23, 2008 | Sony SPP AQ600 Cordless Phone
Misplaced one of the phone
I looked up that model and they are equipped with intercom service.
What good would an intercom function (I ask myself) without some way to ring another handset? It wouldn't make sense to have to holler for someone else to pick a handset ;-)
The phone's control layout is identical to ours (it is 2.4 gHz instead) so check the lower right-hand corner for a button perhaps marked Hold & below it 'Intercom' printed.
Using that function, you choose the station # and it will ring the remote (lost) handset until someone picks it up and presses Talk or speakerphone button. .
Sep 03, 2008 | Panasonic KX-TG1033S Cordless Phone
AT&T 926 Corded phone
check for a button or sliding switch on the side,top,or bottom for the ringer on/off, [ some phones even have this switch on the back ] as for the speakerphone, you may have to push the speakerphone button, then put the handset back on the cradle for the speakerphone to work.
hope this helps.
wg
Feb 13, 2008 | AT&T 962 Corded Phone (A21076)
Speakerphone
Sounds like the mic is turned off. Try "FEATURE - 1". You may have to do it twice.
Feb 05, 2008 | NEC DTU 16-1 Corded Phone
Handsets bypassed; need to restore (follow-up)
These phones have a horrible problem with the hook switch. If you can only get the phone to work in speakerphone mode, most likely the hook switch is shot. If nothing happens when you lift the handset a bad hookswitch is likely. If the hook switch works but the talk path in the handset does not work, there may be a cut jumper wire. The wire is cut when a headset adapter is installed and if that adapter was later removed it will effect the talk path for the handset. If you take the back of the phone off you can see the jumper (visible from the back of the circuit board through a notch next to the speaker) If you can use a soldering iron, a cut jumper can be repaired easily by bending the wire back so there is only a small gap and soldering it. -Ben
Feb 23, 2007 | Toshiba DKT-2010 Corded Phone
I found some old notes of mine you could try, but they're involved: 1. [Spkr],#,603,500,[Speed Dial],[Redial],[Spkr],pick up hand set, hang up. 2. [Spkr],#,656,9,phone extension,[Redial],[Spkr],pick up hand set, hang up. 2. [Spkr],#,657,#,phone extension,[Redial],[Spkr],pick up hand set, hang up. Were you able to find a free manual online? Pat
Feb 20, 2007 | Toshiba DKT-2010 Corded Phone
Computers & Internet Logo
1,249 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
