My Computer case has to integrated USB ports, I have lost my AGP Moonwalker shuttle motherboard manual, and need assistance how to hook up USB ports to motherboard. I have red, green, white and black wires, but motherboard has 5 pins. Need to know how to configure
    Problem Solver:
  • 16 Answers
It is better to buy an usb-card its only cost rs-225/-
Posted on Sep 28, 2009
Hi anyone know what graphics card i can use in a hp P4SD-LA (Stingray
Hi patto1974, this is a good Model Graphics Card, for the ASUS Motherboard that you have. ASUS is one of the leading Manufacturers in "Gaming Computers; so you want to have a Graphics Card to compliment the system.
This is the (Model):
Radeon HD 4670
IceQ
Video Card
1GB GDDR3
AGP, DVI, VGA,HDMI
Item#: H231-4678 '
Model#: H467QS1GHA."
You can find this "Model at Tiger Direct, along with other models.
Use AGP x8 as the reference search!
Click here: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6076197&CatId=318
Hope you are satified, paul7of9
Jan 09, 2012 | ATI Computers & Internet
Where is the video card?
The video card is either on a riser card from your motherboard or integrated into your motherboard.
you can easily find out as it is the place your monitor plugs into your computer usualy with a blue 15pin D shaped plug.
or a larger white plug.
Aug 09, 2011 | Computers & Internet
My motherboard has fried: Albatron KM18G Pro 2003. It no longer seems to be available. For the computer to be exactly as it was before disaster struck, do I need exactly the same motherboard?
Well you do not need exactly the same motherboard. You need a motherboard that has the exact CPU socket, DDR slots and AGP or PCI slot.
Here are the specifications for the motherboard: Processor
- AMD Athlon/Athlon XP/AthlonXP Barton/Duron Processor
- FSB 200/266/333MHz
Chipset
- North Bridge: NVIDIA nForce2 IGP
- South Bridge: NVIDIA nForce2 MCP
- I / O Chip : Winbond W83627HF
Memory
- 3 DDR Sockets:
DDR200 to 400 non-ECC DDR SDRAM up to 3GB (Single Channel) or up to 2GB (Dual Channel)
Expansion Slots
- 1 x AGP 8X/4X slot (1.5V Only)
- 3 x PCI slots (PCI 2.2 compliant)
IDE Connectors 2 ATA133 channels (up to 4 ATA 133 IDE Devices)
Onboard I/O Connectors
- 1x Floppy Connector
- 2x USB 2.0/1.1 header (4 ports USB cable optional)
- 1x CD_IN header
- 1x COM Port header
- 1x S/PDIF in/out header (S/PDIF in/out cable optional)
- 1x CPU fan header with fan rotation detection function
- 1x System fan headers with fan rotation detection function
- 2x 5 pin system panel header (Intel spec)
- 1x 3 pin Power LED header
- 1x 4 pin Speaker header
- 1x Front audio header (Intel spec)
- 1x Case Open detection header
- 1x Wake on LAN
- 1x 4 pin TV-Out header
So you have to buy a motherboard that has Socket A, that support DDR I memories and has an AGP slot (for the video card).
If you need further assistance, just leave a comment. Thank you for using FixYa.
Apr 19, 2010 | Albatron nForce2 KM18G Pro (KM18G PRO 2.0)...
Shuttle mv43v v7.3 AGP card won't work
Go in the BIOS and disable the onboard video.
Feb 03, 2010 | Shuttle MV43VN Motherboard
What type of motherboard for HP Compaq dc5700
The motherboard that you have is : yale-UL6E,
  • view the manual:
    yale_manual.pdf (300 KB)
  • micro-atx form factor
  • Intel Pentium 4 HT processor
  • Intel Celeron processor
  • Socket 478
  • 800/533/400 Mhz front side bus
  • Intel 865-PE chipset
  • 4 DDR-DIMM slots for single or dual channel configurations
  • supports PC2100 (266 Mhz), PC2700 (333 Mhz), PC3200 (400 Mhz) DIMM modules
  • graphics: uses AGP card only
  • audio: integrated AC97 audio
  • lan: integrated 10/100BT ethernet
  • 1 AGP 4x/8x slot
  • 3 PCI slots
  • 8 USB ports (2 headers for 4 possible front I/O, 4 on back I/O) *
  • 2 IEEE 1394 ports (1 for front I/O, 1 on back I/O)
  • connectors for front headphones and microphone
Dec 14, 2009 | HP Computers & Internet
Motherboard installation
Hello mecompe,
If you installed an AGP graphics card before your fist boot of the system, you will not receive display. By default the onboard graphics is set to boot display. (If this is the case, remove the AGP graphics card & boot the system). The Asus P4SGX-MX can only use a 4x AGP 1.5volt (only) card.
There is an order of sequences to perform before installing/ adding an AGP graphics card on to the board when the board also uses an integrated graphics card.
First, shut down the system & unplug the power supply from the PC. Connect your monitor to the VGA port at the rear of the board. Remove the AGP card. Re-connect the power supply & boot the system. You should have display? Re-boot the system. As the system starts up press the delete key on the keyboard every 2 seconds. The bios main menu will load. (Open your manual). Go to
section 2.4.3, page 2-20 under Advanced, PCI configuration. Set Primary VGA bios to
[AGP VGA Card]. Save the bios & exit. The system will auto restart. Press & hold the power on/ off button on the PC case until the system shuts off. Unplug the power cord from the PC. Insert the AGP card into the AGP slot. Connect your monitor to the AGP card.
Check all internal data & power cables, (Incase something came loose). Re-connect the power cord & boot the system. You should have display! Install your video software.
If your using the integrated VGA PCI graphics card, go over the bios settings page 2-18 & 2-20.
Need the Asus manual? Click this link;
http://support.asus.com/download/download.aspx?modelname=P4SGX-MX&SLanguage=en-us
To view the manual you'll also need Adobe PDF reader, click this next link for Adobe.
http://www.adobe.com/products/reader/
(The green led (light), means standby. The board is receiving 5volts DC.
If you still do not have display just let me know.
Good luck mecompe!
Mike
Oct 28, 2008 | ASUS P4SGX-MX Motherboard
MV43V motherboard by shuttle
Here are your MB specs:
MV43V/N - Supports Socket 478 Intel Pentium 4, Celeron with 400/.533 MHz FSB
- VIA P4M266A + VT8235 Chipsets
- DDR 200/266 SDRAM, 2 x 184 – pin DIMM, Up to 2 GB
- 2 x ATA 133
- 4 X AGP device, 2 PCI slots, 1 CNR slot
- Onboard AC97 audio two channels
- Onboard S3 Pro-Savage 3D Graphics
- Onboard VIA VT6103 10/100 Fast Ethernet (MV43VN only)
- 6x USB 2.0
- Micro ATX Form Factor
The your motherboard has an ethernet adapter all you need to do is download the drivers for the ethernet adapter and install them. here is the link : http://members.driverguide.com/driver/detail.php?driverid=206328 do a free subscription first. cheers
T
YE
Feb 16, 2008 | Shuttle MV43N Motherboard
Video signal
If it worked fine before the AGP card was removed then the problem is probably related to your BIOS settings. The BIOS setting that controls the integrated video may be set to OFF.
  1. Insert an AGP video card
  2. connect the monitor to the card
  3. boot to BIOS
  4. check settings
  5. turn ON integrated video
  6. save and exit BIOS
  7. shutdown
  8. Remove AGP card
  9. connect monitor to motherboard video port.
  10. Reboot.
What happened?
Jan 26, 2008 | EliteGroup 661FX-M Motherboard
Video card upgrade
Needs specs of your board.. Model number
Nov 13, 2007 | Shuttle AV41P Motherboard
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
