Question about Frigidaire ATF6000ES Front Load Washer
Mold and mildew in door. washed, cleaned, ran
Mold and mildew in door. washed, cleaned, ran bleach through cycle, etc. no avail.
  • 1,531 Answers
The only thing you can do now is replaced the door boot seal. after replacement usually you have to leave the door open till completely dry or dy it with a towel after each wash
Posted on Sep 28, 2009
I have a Whirlpool top load washing machine. lately it really smells. I ran several cycles with bleach to try to get rid of the smell...but it doesnt help. Help...my house smells like a sewer.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa
Jan 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Mold odor not helped using bleach
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!##$$
Sep 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Mold and mildew and a musty odor. I can see black mold around the door seal, primarily at the lower side of the door seal. Can I attempt to clean by using bleach? What are your recommendations to correct...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((^^&&
Sep 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Softner bin is still full after cycle is complete" . i put 1 cup of cascade powder into drum then 1 cup bleach in dertergent bin , ran on HOT , short cycle , Did anutha wash , softner bin was still full...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&*&
Aug 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
Mildew odor. We have followed directions in the manual and the problem persists. We removed the front panel of the machine and cleaned the white tube that was filled with "gunk," removed and washed the...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Apr 29, 2010 | Kenmore Elite 45986 Front Load Washer
Towels smell sour. while cleaning noticed small "hole" (factory made) in bottom of boot in front of three "notches". seems like a drain hole? stuck q-tip in there and stinky black muck discovered. ran...
I think you are talking about the door gasket. Use a mixture of bleach and water in the gasket and also in the drum. Most front load washer are notorious for mold and mildew. Run the washer in a rinse cyle to clean drum. Also clean your drain filter.
Jan 06, 2010 | LG WM2688H Front Load Washer
Constant mildew smell in my front load washing machine Have tried running bleach thru an entire cycle , also have cleaned door seal throughly
Dec 08, 2009 | Kenmore Washing Machines
MILDEW ODOR IN MY HE3 MACHINE
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
Jun 29, 2009 | Kenmore Elite 45986 Front Load Washer
Foul odor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*&^%4
Aug 26, 2008 | Kenmore Elite 45986 Front Load Washer
Mildew
all front loads all brands have same issue with mold people today tend to use less bleach CHLORINE BLEACH that is ..allow machine to fill with hot water normal wash pour 2 cups CHLORINE BLEACH in water allow to wash a few min to mix open door and with cloth wash inside of door gasket be sure to roll gasket back and wash underneath lip allow to finish complete cycle should remove most of mold try to this every few months..also leave door open between use to allow moisture to dry out as much as possible like i said YOU ARE NOT ALONE
Jun 27, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
223 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
