After trying the default code it will except 3 buttons, when pushing the 4th button the red light flashes
SOURCE: i need to change the
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The
back plate of the keypad side of the lock on the exterior of the door
has a sticker which includes the serial number, six digit programming
code and two pre-programmed four digit user codes. The lock must be
disassembled to a point the exterior of the lock can be pulled away from
the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
SOURCE: I have followed the instructions on how to change
Here is a very useful link to a video on reprogramming the BE365 lock:
SOURCE: I lost the manual for
Go to this page for downloadable instructions and videos:
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
SOURCE: Lost instructions on how to
This link will take you to the page you need, to get started:
Then scroll down to this heading on that page:
Electronic Security-Keypad Entry Flex-Lock...
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number ( the programming code) that you need to reprogram the lock. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! A battery should last about three years under normal usage.
The ninth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
Good luck--and please provide feedback if this helps!
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
