Question about Admiral AW22 Top Load Washer
Washing machine wont quit filling during rinse cycles
  • 1,531 Answers
If this is a top loading machine. turn it off the pull the drain hose up about six inches but do not remove it from the wall drain you should here water flowing out of the hose once the water has stopped restart you machine with the hose in the sam e position then it should fill up to the proper level and start washing. all this is provided it is not over flowing on the floor.
let me know how things go for and good luck
Posted on Sep 28, 2009
  • 113 Answers
SOURCE: Water won't shut off during wash/rinse cycles & overflows
the clear tube going from the tub to the pressure switch probably came undone or has a hole in it
Posted on Apr 24, 2009
  • 181 Answers
SOURCE: Washing machine is not filling with water on wash and rinse cycle.
sounds like the programme board has a fault
Posted on May 13, 2009
  • 744 Answers
SOURCE: Kenmore 300 washing machine does not leave rinse cycle
This sounds like a bad timer. If the machine is several years old, the timer could be in need of replacement.
If you are handy, you can replace this device yourself and you should be able to obtain the part from any local Sears parts store or from the internet.
If you are not familiar with this kind of work, it would be best to have a technician replace the timer.
Posted on Jan 05, 2010
jsrock516
  • 5911 Answers
SOURCE: Washing machine keeps draining during rinse
You may be experiencing a condition known as "siphoning". This is caused by the drain hose not being high enough off the floor, or not having a proper air gap at the standpipe in order to drain properly. This creates a suction and the washer will constantly drain as it tries to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Posted on Apr 08, 2010
jsrock516
  • 5911 Answers
SOURCE: My Kenmore Series 90 Washing Machine water will not stop filling.
This problem is commonly attributed to either a water inlet valve that doesn't shut off, or a pressure switch malfunction. The following links explain how to diagnose the problem and repair as necessary:
http://www.fixya.com/support/r3753517-whirlpool_top_load_washer_fills_when_not
If the washer is not overflowing, the likely problem is the water inlet valve. If the washer fills to the point where it overflows, the easiest and most common cause of this problem is the small plastic air hose on the pressure switch coming loose. It can usually be fixed by simply reattaching the hose. However, read through all the information provided and double check everything to make sure.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and have great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need.
Posted on May 02, 2010
WDSR2120J washer will not fill in rinse cycle
possible 3 solutions for this problem 1 could be the cold fill solenoid 2 could be brushes in motor 3 could be main pcb
Feb 20, 2013 | Washing Machines
Water won't quit filling and agitator does not engage into the cycle.
Did you solve this problem -have one doing the same-feed back -please!
Mar 22, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Not getting enough water during rinse cycle
In the rinse cycle it will use cold only to rinse with.
You need to see how fast the water is going into the machine on rinse
Things that can effect slow fill, low water pressure, Faulty cold valve
water hose & valve filters clogged, Kinked hose
Feb 21, 2012 | Fisher and Paykel IWL12 Top Load Washer
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
Washer not filling or agitating, during wash & rinse cycles
HI, this will occur if the timer mechanism has become unstable. you will need to replace this defective timer control module asap, if possible.
Jul 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
When my machine goes through the rinse cycle it will only fill with hot water. It fills with warm water during the wash cycle.
Your hoses are reversed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 30, 2009 | Washing Machines
My machine quits working during the rince cycle
the safety switch could be the culprit on this because anytime you open the door on top it triggers which turns it all off. so what i would start with is either bypassing that switch or replacing it.
Dec 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Admiral AW22 Top Load Washer Logo
83 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
