Question about HP DeskJet 950c / ScanJet 5370C InkJet Printer
Impresora presenta problema con cartucho me indica que no tiene cartucho y enciende el indicador de falta de tinta o cartucho
  • 53 Answers
SOURCE: tengo una impresora lexmark Z2320 recargue los
Lexmark no es compatible con los cartuchos rellenados.
Posted on May 18, 2009
toris
  • 29 Answers
SOURCE: tengo un canon mp140 y me pone e4 y e5.creo che
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prito-i-12
Posted on Sep 04, 2009
puertobori
  • 7733 Answers
SOURCE: el problema es que la impresora HP j3600 no
Trata este enlace HP Support & Drivers.
Posted on Oct 20, 2010
MUKHTAR
  • 2017 Answers
SOURCE: acabo de cambiar los cartuchos
You need to do some basic troubleshooting steps below and hope that it would fix the problem.
  • Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  • Open the cover of the product and remove the print cartridges.
  • Close the cover and wait for the Insert Ink Cartridges message to display.
  • Disconnect the power cord from the back of the product and the wall socket, then wait for one minute.
  • Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  • Open the cover and reinsert the print cartridges.
  • Close the cover. If prompted, print a calibration page.
  • Print a Self Test to verify product is functional.
  • Reconnect the USB cable, and try to print from the computer.
Try doing:
1. Unplug the power cord from printer.
2. Hold both o.k and Cancel simultaneously.
3. Plug the power cable while holding the buttons
Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on,
Hope this helps. Please rate my response.
Thanks.
Have a good day
Posted on Dec 27, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: impresora bloqueada y no detecta
    Trate de limpiar los inyectores de los cartuchos. Si estás utilizando Windows, vaya a Todos los programas o Programas y, a continuación, seleccione la carpeta de programa de la impresora de la> lista de la carpeta de la impresora, haga clic en Mantenimiento - Alinear cartuchos> haga clic en Imprimir> Siga las instrucciones en la pantalla del ordenador hasta el final.
    Si está utilizando Macintosh, desde el escritorio del Finder, haga doble clic en la carpeta de la impresora> haga doble clic en el icono de la utilidad de la impresora> En la ficha Mantenimiento, haga clic en Limpiar inyectores de impresión. Una página se imprime, la tinta pase por los inyectores del cartucho de impresión para limpiarlos. Imprimir el documento para comprobar que la calidad de impresión ha mejorado.
    Nota: Esto se traduce utilizando translate.google.com.
    Posted on Jun 21, 2011
    ES IMPRESORA Y SCANNER. NO PUEDO USARLA SOLO COMO SCANNER AUNQUE NO TENGA TINTA????
    Muchos de los lectores tienen una funci?n de copia que utiliza la impresora . Usted puede ser capaz de comprar cartuchos de tinta para que o tal vez rellenado de los cartuchos de tinta si el coste es un problema. Creo que ser?a necesario de tinta para poder utilizar el esc?ner debido a la funci?n de copia.
    Dec 31, 2014 | Office Equipment & Supplies
    Como soluciono el error B200 de la canon MP250
    De acuerdo a lo que lei en un foro esto se produce por recalentamiento del cabezal al imprimir con un cartucho sin abastecimiento de tinta, tienes que cambiarlo o prueba con desintalar la impresora del windows y lo reinstalas despues.
    Aug 30, 2012 | Canon Pixma Mp250 Allinone Inkjet Photo...
    Mi impresora canon mp280 me sale el error b200 que puedo hacer..la tinta ya no corre
    pruebalo con uno de los cartuchos afuera. si es que ves que tiene alguna reaccion diferente a lo que con los dos cartuchos tienes que cambiar ese cartucho que sacaste. yo tenia el mismo problema, lo cambie el cartucho de colores que era el que estaba mal y luego lo resetee y todo ok. mientras no lo cambias ese cartucho el reseteo no funciona.
    Feb 24, 2012 | Office Equipment & Supplies
    BANDA DE UNOS 4 CENTIMETROS EN LA QUE SALE MAS CLARO O NO IMPRIME.
    • Puede ser que el cartucho de toner se esta quedando vacio ( en este caso sacalo de la impresora y movelo un poco hacia los costados, insertalo en la maquina), tambien fijate si el rodillo de revelacion del cartucho tiene toner en toda la superficie.
    • Otro problema puede ser que el laser no se proyecte en el tambor de imagen (para este caso chequea que nada obstruya el paso del mismo)
    • Y por ultimo el Laser, estan sucios o empañados los espejos del mismo (limpiar con un trapo seco que no deje residuos).
    Sep 07, 2011 | Xerox Office Equipment & Supplies
    Mi impresora lexmar x5470 no reconoce el cartucho lexmark 34 negro rellenado como hago para que me lo reconozca y poder trabajar con la impresora sin ningun problema
    Lexmark no recomienda el uso de cartuchos rellenados. Usted puede haber tenido los cartuchos rellenados que trabajó con su impresora Lexmark, pero los que no tienen la calidad de un cartucho de Lexmark. Los contactos de los cartuchos negro # 34 pudo haber conseguido dañadas a lo largo del proceso de recarga. Lo mejor sería comprar uno nuevo - preferiblemente un genuino. Esta es también una manera de evitar daños en la impresora.
    Nota: Esta es translalated con translate.google.com.
    Jul 05, 2011 | Lexmark X5470 All-In-One InkJet Printer
    LA MÁQUINA INDICA ERROR E000805-001
    1) Desconecta el poder de la impresora. 2) Quita el ladrillo/bloque negro del poder por detr?s de la m?quina. (Puede ser un malvado peque?o de sacarlo la primera vez usted lo quita.
    3) Abre la cima de la impresora/multi unidad de funci?n.
    4) tira Suavemente la cinta para centrar el portador de cartucho de impresora.
    5) Abre o el lado de izquierda o derecha y quita el cartucho. (Depende de cu?l lado el error ocurre en, negro a la izquierda, el color a la derecha)
    6) Verifica que toda la tira pl?stica que cubri? los nuevos contactos en el cartucho tiene de hecho fue quitada.
    7) Toallita tanto los contactos de cartucho como impresora con una seco, hilas libertan tela.
    8) Enjuga el fondo del cartucho con una h?medo, hilas libertan tela para verificar que la tinta fluye y los vistazos corrigen.
    9) se Asegura de que no hay agua que queda en el cartucho.
    10) Reinserta el cartucho en el portador y se asegura de que es profundizado y es insertado completamente al trasero de la ranura de portador.
    11) Reinserta el ladrillo/bloque del poder.
    12) Conecta de nuevo el cable de energ?a el?ctrica de impresora.
    13) el Poder en la impresora y el error debe ser resuelto.
    14) Corre la alineaci?n de impresi?n e impresi?n o copia varias p?ginas para asegurar el problema ha sido resuelto.
    Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
    Dec 19, 2010 | Office Equipment & Supplies
    Trying to change colour cartridge but comes up with message " Remove and check colour cartridge"
    ok les cuento nuevamente tengo una impresora Hp photosmart C4180 all-in-one le instale el cartucho negro y el de color recargado o bien generico y me derramo por todas partes tinta incluyendo las tarjetas el problema que me esta dando es que no me enciede la pantalla ni mueve el carro donde van los cartuchos de tinta quesiera saber que puedo hacerle para resolver este problema ya que la desarme por completo la limpie todita y aun persiste el problema. me pueden ayudar por favor , Gracias
    Mi correo es Dennisemilianofloresolivares@yahoo.com
    Oct 11, 2010 | HP Photosmart 4180 All-in-One Printer
    TENGO UNA HP 4355 Y ME MARCA UN ERRO EN CART.
    Para empezar, quite el enchufe de la corrente como unos diez minutos
    Si sigue tenendo el problema quite los cartuchos y los vuelva a poner.
    Si todavia tiene el error limpie con algodon y alcohol la superficie del contacto de metal donde se pone el cartridge.
    Si sigue non funcionando el cartridge puede ser defectuoso, intente cambiarlo, posibilmente con uno original.
    Sep 06, 2008 | HP Officejet 4215 All-in-One Color Photo...
    LEXMARK X3550
    Quite los cartuchos. y asegúrese que las pequeñas cintas protectoras han sido quitadas de los contactos. Entonces examine donde los cartuchos caben en la impresora. ¿Es limpio en allí? ¿Hay allí alguna tinta secada o gotas de la tinta en allí? Si hay, usted puede apagar y desenchufar la impresora y usar una cantidad diminuta del alcohol desinfectante en un Qtip para limpiar la tinta.
    Si no sustituyen los cartuchos que se los aseguran adecuado cómodamente. Ahora continúes su computadora a - Principio> Panel de instrumentos> impresoras y faxes> chasquido DERECHO en su icono de impresora y elija preferencias> servicios. Cuando usted está en servicios abiertos y mira cada opción allí. Haga cualquier prueba o limpieza de los cartuchos a los cuales esto le pregunta. Cuando usted es terminado, apaga su impresora y reanuda su computadora. Si el problema no es ido, contestarme. Espero que mi español sea comprensible. Gracias.
    Aug 19, 2008 | Lexmark X3550 All-In-One Printer
    Pixma MP160 not faxing
    ERROR E27
    Hola gente no lo consigo ni por un lado ni por otro.
    Alguien lo ha conseguido ???
    Sigo las instrucciones al pie de la letra:
    Describo las teclas que he usado:
    parar -> tecla en roja que tiene un circulo y dentro un triangulo
    on/off -> tecla que pone on/off arriba
    1- Pulso y mantengo pulsá la tecla de parar
    2- pulso y mantengo "on/off" y suelto parar
    3- teniendo pulsada "on/off" pulso dos veces para y en la segunda suelto para y on/off
    4- la impresora se enciende y pone un cero en el contador
    5- pulso una vez la tecla parar se enciendo la luz de la izquierda que es naranja la que esta con el triangulo y un rayo dentro
    6- pulso otra vez para y la luz se va a on/off
    7- pulso para otra vez la luz pa la izquierda es decir triangulo y rayo
    8- pulso otra vez para (ya van 4 veces) y la luz pasa a on/off
    y ahora que....
    por que yo pulso ahora on/off y la impresora hace ruido pero la apago la vuelvo a encender y las luces de falta de tinta, es decir la de la B y la C siguen encendida
    no se que hacer he mirao por todos los foros del mundo estoy a punto de tirarla por la ventana y comprarme otra
    saludos
    Apr 01, 2008 | Canon PIXMA MP160 All-In-One InkJet...
    HP DeskJet 950c / ScanJet 5370C InkJet Printer Logo
    Seeker5211
    Seeker5211
