Question about Bosch Axxis WTL 5410 Electric Dryer
The condensation hose is missing from my bosch 5410, what is the correct size of the hose and what material, thanks.
  • Bosch Master
  • 3,463 Answers
I assume you mean the vent hose, they are usually 4" in diameter,, measure the opening to be sure, you can usually buy one from a supermarket in the plumbing department.
Please rate my solution.
Thanks.
Posted on Sep 28, 2009
E1 code. water is being pumped out dry and start dryer and 3-5 min code comes back. cleaned everything inside checked all hoses and switch. everything looks fine
Cycle is interrupted and ''E1'' appears in display.
Condensate hose is blocked in some way. Turn off dryer and check hose.
Condensed water not pumped out (WTL 54 condensation models only). Pump failed.
25808741-gtkp3url2ghtdqenstp5bokb-1-0.jpg Dado
Aug 04, 2015 | Bosch Axxis WTL 5410 Electric Dryer
WTL 5410 getting E1 error message. Condenser hose seems unblocked. Pool of water behind the heat exchanger
Dado
Jul 02, 2015 | Bosch Dryers
My dryer WTL 5410 electric condensation dryer is cutting on and off.
this is normal operation it turns the drum one direction then the other this is because of the way it condensates
Apr 06, 2014 | Bosch Axxis WTL 5410 Electric Dryer
My WTL 5410 dryer (electric condensation) has hot air coming out of the low rear duct opening (where the condentate hose connection is located. The hose is properly connected and occationally has water...
Welcome to FixYa.
You are correct, the unit being a condenser model doesn`t require any additional venting or exhaust to outdoors, that is the purpose of condensing the moisture internally.
As to the issue of air flowing out of the unit I`d suspect perhaps the heat exchange may need cleaning, if it is plugged it will cause the air to be directed elsewhere.
I`ve attempted to attach below the procedure for cleaning, if unsuccessful for whatever reason, too small for example, you or your landlord can email me at macmarkus@live.ca and I can send you the "pdf" guide for your Bosch dryer.
Keep me posted on your findings and I`ll try to assist you further if need be.
Thanks for choosing FixYa today and good luck.
Please take a moment to rate the info presented and leave a testimony if you feel it warranted.
Regards,
Macmarkus :)
Sep 28, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Dryer not starting
Check your lint filter first, and then try to restart it. Also, make sure the door is completely shut. If this doesn't do it, check your condensation hose for blockage. These dryers are very sensitive to lint build up, so make sure to change your lint trap after each load. It's not only a good practice, but it's necessary with this machine
Feb 27, 2010 | Bosch Axxis WTL 5410 Electric Dryer
WTL 5410 BOSCH AXXIS CONDENSATION ELECTRIC DRYER
the thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Feb 02, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Error Code
open the thing up and locate the service manual. once located it should list what that error means. alternatively call bosch and ask them.
Aug 25, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Water builds up behind heat exchanger
I don't know if there is a cure for this. Bosch never answers my calls or my e-mails, but I have found that by blowing in the hose to disengage the lint collecting there and then sucking out the line will remove nearly all of the build up amd drying will resume.
Jul 08, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis WTL 5410 Electric Dryer Logo
136 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
