Question about Epson Printer
When i turn my printer on(epson photo4300) I
When i turn my printer on(epson photo4300) I get a message error service required from the printer monitor
jackboy
  • 2985 Answers
SOURCE: Printer stopped printing. Error message
Thjis is indication the Waste in collector pades need changing eventually.- but no now. you have plenty of warning
Reset Epson R300/200
press three buttons to reset the counters
The buttons are "STOP" "Maintenance" and "POWER"
or down load the epson utility www.ssclg.com and use the reset counter feature
The printer will sound like its going to blow up, but thats normal.
You can do this about 5 times before your printer starts to piss out ink over the table because the Waste Ink Ink Pad is full
To avoid eventual flooding go to rear of the machine- remove the little door and rake around for a small plastic pipe buried under some padding under the left side.
Fix to this a thin piece of ploythene tube[Fish tank air supply], extend it to our side the machine and place in a suitable container to collect the waste ink..
Posted on Nov 21, 2007
SOURCE: Epson rx 500 "service required"
Press on off, load expulsion, byw,color and stop all at the same time, wait until it is on. then press color and then shut down.
Posted on Jun 25, 2008
ChobPT
  • 220 Answers
SOURCE: Epson Stylus Photo R300 has error
You actually need to change the ink absorber.
Heres a video on how its done on the R800.
Please refer to your manual for proper localization of the ink absorber.
Doing this will get you to move on
Posted on Jun 20, 2009
aicaxz
  • 511 Answers
SOURCE: epson stylus photo RX680 error message says;
Yes you're right. Use SSC service utility or RX680 Adjsument program. Find at indoreset.blogspot.com. Don't forget to replace waste ink pad, or just extend outlet pipe of head cleaning mech to outside.
Posted on Aug 28, 2009
cns assoc
  • 677 Answers
SOURCE: epson stylus T10 printer stopped working
Found this on the web site., link below. If anybody find this information
Helpful, pls rate me.
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
Parts inside your printer are at the end of their service life “Today I had the joy of fixing an Epson Stylus C46 UX printer.”It had the following error: “Parts inside your printer are at the end of their service life. See your printer documentation.”
After a little searching I discovered that most people were saying that “It is simply not worth repairing”, however, I took that as a challenge, and decided that if I was going to throw it away anyway I might as well try to fix it first.
Before long I located a page on fixyourownprinter.com’s forum, which had plenty of details about similar issues. This is the process I used after reading details on that page:
  1. Unplug the power and USB cables from the printer.
  2. Prepare your work area by putting scrap paper down. Have some spare, just incase. You may also require tissue paper. It is also recommended you use protective gloves as the ink will stain your skin for quite some time.
  3. Unscrew the screw at the back of the printer.
  4. There are two or three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
  5. At the back of the unit you need to locate some white pads, or sponge type things, initially they will seem fine, but they will infact be full of ink. You need to grab a pair of pliers and pull them out one by one, there should be four, put them on your scrap paper.
  6. Take the scrap paper with the pads on to your sink, turn on the hot tap and hold each one under the tap using the pliers until the water runs clear. If you have protective gloves on it may be worth squeezing the water out also.
  7. It is recommended that once you have done this, you let them dry.
  8. Now return the pads back into the printer.
  9. Put the printer back together, (mind out for the paper alignment, and give it some force), not forgetting the screw at the back.
  10. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
  11. Download and install the SSC Service Utility for Epson Stylus Printers.
  12. Select your printer and model number (There is no Stylus C42 UX, so select Stylus C4x), then close the window.
  13. If it asks if you replaced with the pads; say “YES”. Then close the window.
  14. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
  15. A menu will appear, from here you can click on “Protection counter” (its a red cross), then “reset protection counter”.
  16. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
Done! Additional troubleshooting… If you have problems with paper feed, take it apart again, check everything is in place correctly, push things together tightly, and put it together again. If you have trouble with print quality, open the lid, clean any ink residue, use the SSC Service Utilitiy to clean the heads.
Thanks and Good Luck Please Rate Me
Posted on Mar 19, 2010
End of service for epson wf 7610
If your Epson WorkForce WF-7610 printer shows error message "The Printer's Ink Pads at the end of Their service life" and Epson WorkForce WF-7610 printer has a red light blinking problem: You should be download and reset Epson WorkForce WF-7610 printer Waste Ink Pads Counter with Epson WorkForce WF-7610 Resetter.
Go to this link, you should be able to download the resetter and follow the procedures step by step.
Reset Epson WorkForce WF 7610 End of Service Life Error message Wic Reset...
Jul 22, 2017 | Epson Office Equipment & Supplies
Tip
Epson Resetter website and update
The BEST website on where to download this Epson Resetter is:
http://www.ssclg.com/epsone.shtml
Their programmers or group is dedicated to help Epson users to fix the error message:
Epson printer Service Required Error...
*Old resetter will not work on new printer also.
Simple but annoying problem!
on Mar 29, 2010 | Office Equipment & Supplies
How do you set up an epson stylus photo4300
Once you have installed your printer by using the CD which came with your printer or using internet, you make sure that it print a test page and it should be ready for your use.
Nov 12, 2015 | Epson Office Equipment & Supplies
Epson t60 general error
For a lot of Epson there is a remedy:
1. Turn off the printer.
2. Press and hold both 'stop' 'maintenance' and 'power' buttons for about 10 seconds.
A message will appear on the screen.
3. Power off and back on for reset.
Jul 28, 2011 | Office Equipment & Supplies
Error Service required
Epson programmed their printer to monitor the waste ink counter andyour printer has reached the maximum value allowed, you have to resetyour printer to clear the waste ink counter.
You may read the information regarding "end of life" and "waste ink counter" here: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
To reset the counter, download re-setter program here, install and follow the instruction in the web site.
Good luck and thank you for using FixYa.
Apr 13, 2010 | Epson Stylus Photo R300 InkJet Printer
Epson 3800 won't work
you cant fix it of your own better to visit service centre.
this error require counter reset through software
Jun 10, 2009 | Epson Stylus Pro 3800 InkJet Printer
Screen says "service required" Printer will only turn on, that's it.
Its Epson design. It means it already reach it maximum reliable printing service. But you can extend its service using Epson resetter. Its a third party software utility program. It will reset its counter to zero count again. Counter resetting is on the printer itself not in the ink cartridge.
Leave a message
Apr 15, 2009 | Epson Stylus Photo R340 InkJet Printer
I received an error message reading: SERVICE REQ. EROOO3. I can't print any more and need to finish a manuscript today.
The message indicates a controller or print engine error has been detected. It's the internal electronic/logic board failing.
If power cycling or turning it OFF/ON does notclear the error message, service is required as the logic board needsreplacement.
here's a link for certified service center for your product.
Nov 17, 2008 | Epson Action Laser 1500 Printer
Epson Printer Logo
56 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
