Question about Canon ImageRunner 2020i Copier
I can't figure out how to print labels using the stack bypass. Help!
  • 1,219 Answers
When you put lables into bypass the machine will autom. ask you for format eg. a4, then you press OK, next type of paper: LABELS and OK.
Place the paper so that the lables are face down
Posted on Jan 13, 2010
Sharp mx3110n printer won't use bypass tray? Trying to print on glossy paper using that tray and it won't, it automatically switches to tray 1. Or can I just put glossy paper in tray 1?
Hello Laura,
Here is the pdf that explains how to set up th bypass tray; http://support.appstate.edu/sites/support.appstate.edu/files/MX3110%20USE%20SPECIAL%20PAPER%20IN%20THE%20BYPASS.pdf
The text of it is as follows;
TO USE SPECIAL PAPER IN THE BYPASS
? Press either the picture of the copier or press
paper select
? Load paper in the bypass
? Make sure the correct size shows up under
bypass tray
? If paper is not just plain paper press type and
size
? Choose paper type
? If you are printing to the bypass from your
computer you must also tell the print driver
under the paper tab what type of paper is in
the bypass if its not just plain paper
? The copier and the PC must match paper
types
? Press the X button to Accept
Good Luck!
Rich Lilja
Feb 21, 2015 | Sharp Office Equipment & Supplies
I am trying to print labels on the Konica Minolta bizhub 250 from the bypass tray and my labels are printing in landscape on my label sheet
Its not in the copier. Its on whatever program your printing from. Try playing with the settings. Don't forget, you can use regular paper until you figure out your correct orientations.
Oct 20, 2014 | Konica Minolta bizhub C250 All-In-One...
HP OfficeJet Pro 8600 tray can't be inserted all the way. Stops with 3 inches of tray sticking out.
  1. Grasp the handle on the front of the input tray, and then pull the tray towards you to open it.
    Figure 1: Pull out the input tray
  2. Slide the paper width guides out as far as possible.
  3. Remove all paper from the paper tray.
  4. Inspect and remove any foam or tape packaging materials in the paper tray.
  5. Insert a stack of unused, plain white paper (with the print-side down) in the center of the tray.
    Figure 2: Load paper into the tray
    CAUTION: Do not load any paper above the solid red lines on the sides of the tray. Do not use torn, wrinkled, perforated, wet, or folded paper. Make sure to remove all paper clips and staples before loading the paper. Figure 3: Stack label height
  6. Slide the paper guides in so that they rest against the edges of the paper, and then insert the tray into the product and push it forward until it clicks into place.
    Figure 4: Slide the paper guides in and reinsert the tray into the product
  7. Pull out the tray extender on the output tray.
    Figure 5: Pull out the tray extender on the output tray
Step two: Load paper in optional Tray 2
Tray 2 is an optional accessory. Follow these steps to load paper in Tray 2.
NOTE: Tray 2 supports only plain letter or A4 paper.
  1. Grasp the underside of the tray, and then pull out the tray from the bottom of the printer.
    Figure 6: Pull out the tray from the bottom of the printer
  3. Load a stack of unused, plain white paper (print-side down) in the center of the tray. Make sure that the stack of paper aligns with the engraved lines in the tray.
    NOTE: Load Tray 2 with only U.S. Letter or A4 plain white paper.
  4. Slide the paper guides in so that they rest against the edges of the paper.
  5. Carefully reinsert the tray into the printer, and then push the tray forward to close it.
    Figure 7: Reinsert the tray into the printer
  6. Pull out the tray extender on the output tray.
    Figure 8: Pull out the tray extender
Load specialty paper Follow these steps to load specialty paper such as card stock, envelopes, photo paper, or labels.
Before you proceed, verify that your printer supports the specialty paper on which you are attempting to print by viewing the product specifications . If the size, type, or weight of the paper is not available, the printer does not support printing it. Also note the tray loading capacity for the type of paper on which you are attempting to print.
Sep 27, 2013 | HP Officejet Pro 8600
Printing labels
you may have to set the lables up on the bypass or manual feed input as the machine has to compensate for the thickness of the labels and slows the print process down. check the display on the copier it may be asking to load labels in the bypass
Nov 17, 2009 | Office Equipment & Supplies
C6180 will not print labels as set out in the avery template. will bunch up as they go down sheet
Step 1 : Change the print settings
The print settings of the HP All-in-One can be customized to handle nearly any print task.
Before changing the print settings, decide whether to change the settings for the current print job only, or to make the settings the default for all future print jobs. How print settings are displayed depends on whether to apply the change to all future print jobs or just to the current print job
Change the print settings for all future jobs:
In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Settings .
Make changes to the print settings and click OK . Change the print settings for the current job:
On the File menu in the software program, click Print . Make sure that the HP All-in-One is the selected printer.
Click the button that opens the Properties dialog box. Depending on the software program, this button might be called Properties , Options , PrinterSetup , or Printer .
Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Step 2 : Print with 210 x 297 mm (8.5 x 11 inch) labels
The HP All-in-One can be used with any software program designed for printing.
This document contains basic information about using the HP All-in-One to print on labels using a software program. For additional information, such as printing a poster, printing multiple pages on a single sheet, and more, see the onscreen Help that came with the HP software.
Follow these steps to print on labels:
· Make sure to load labels in the input tray. Always use letter or A4 label sheets designed for use with HP inkjet devices (such as HP inkjet labels).
· Make sure the labels are no more than two years old. Labels on older sheets might peel off when the paper is pulled through the HP All-in-One, causing paper jams.
  • Fan the stack of labels to make sure no pages are sticking together. Place a stack of label sheets on top of full-size sheet of plain paper in the paper tray, label side down. Do not insert labels one sheet at a time.
    1. On the File menu in the software program, click Print . Select the HP All-in-One as the printer. To change settings, click the button that opens the Properties dialog box.
    2. Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
    3. Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Aug 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
STACK BYPASS option causes LOAD PAPER message & no print
1-did you change to bypass instead of trays in the menu?
2-the sensor (black lever in the bypass that triggers the sensor) is missing or bad
Oct 09, 2008 | Canon imageRUNNER 400S Copier
Printing
There are 3 different locations where paper trays are selected.
1 is on the machine.
2 is in the print properties on the driver
3 is in Word itself, in differeing locations on the top tool bar depending on the version you are running.
I doubt you have to install anything, just one of those locations has your bypass selected. Maybe someone was running envelopes or labels and wound up selecting the bypass as the default tray in word, or again the driver properities.
This one is just searching through the driver and programs until you find the location that the bypass is selected as the default tray.
Just persistance, and yeah can be frustrating finding the exact location of the change.
Feb 22, 2008 | Canon imageRUNNER C3200 Color Printer
Labels will not auto feed
Have you gone into your print driver and changes the settings there?
I am not sure with your inormation if you have changed the settings on the printer or in the driver.
What it sounds like is happening is that there is a mismatch between the printer and computer.
It may even be set so that it is looking for lables in a bypass tray.
Somewhere there is a mismatch in information as to where the labels are loaded.
Start at the driver properties page and confirm every step in your setup.
Dec 31, 2007 | HP LaserJet 1022n Printer
Unable to print envelopes on Xerox WorkCentre Pro 123
Some thoughts.
Envelopes won't print from bypass tray. Cause:
Extended tray is not set up properly for envelopes. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Enter tools "Login" 1,1,1,1,1 Touch buttons with the following names in that order: System Settings System Settings Common Settings Other Settings Scroll down to "Extended Tray" Next to "Extended Tray" it may say "Inverter" if it does go to change settings then change it to "Offset Stacking" Close out tools.
Nov 22, 2007 | Xerox WorkCentre Pro 123 All-In-One Laser...
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
139 people viewed this question
old marine
old marine
