Question about Fuji DS-300 Digital Camera
Canon SD300 - When I want to view my pictures, the screen goes
When I want to view my pictures, the screen goes into a scrambling mode, not allowing me to see anything. How do I repair the problem?
Mac (OS 10.5.8) does not recognize SD 300?
Skip the installing of drivers and software. Simply buy a card reader/writer. This is a great way to get your pictures downloaded from the camera. Remove the card put it in a card reader, download the files to where you want them, then edit or view as you please.
Apr 18, 2010 | Canon PowerShot SD300 / IXUS 40 Digital...
Scrambled image in shooting mode-Canon A85
It is problem of bad CCD Imager in your Canon A85 camera and ccd imager will be replaced to get correct picture in live view/ shooting mode.
Canon will repair your camera free of cost. Click Canon CCD Imager Advisory for details.
Thanks.
Sep 08, 2009 | Canon PowerShot A85 Digital Camera
Canon camara was dropped and now it reads e18. Camara still shows pictures on the display screen
Hi
The Canon E18 error happens when the lens gets stuck while trying to extend. When your camera was dropped the lens mechanism was damaged resulting in this error for a jammed mechanism.
If the camera is still under warranty you should see if Canon are willing to repair it. If not you can view this link which is a very good walkthrough with pictures on how the error was resolved with a Canon SD300.
As you can see from this the process is intricate enough and involves opening the camera so should only be attempted if you feel confident about taking it on.
http://members.shaw.ca/gregs_space/Canon_E18_repair_guide_for_SD300.pdf
Hope this helps. Please remember to rate my answer. Many Thanks.
Jul 28, 2009 | Canon Cameras
SD300 LCD Display Shows Same Image
Sounds like it needs service. Call Canon tech support.
May 28, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
A whole new problem...
Did you fix the previous problem? If so, was it a missing or loose screw?
As for your current problem, you may have accidentally pressed the LCD display on/off button (it manually turns off the LCD display to save battery life). Turn on your camera and press the DISP button once. It's located on the back of your camera in the lower left corner.
May 27, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Viewing Pictures
I need more information to help with this problem. What model is the camera? Is it a single-lens reflex camera, or a camcorder? The more details I can get, the better I will be able to research and recommend solutions. Thanks.
-lizwb
Nov 13, 2007 | Canon PowerShot A85 Digital Camera
Canon Power Shot SD300 Broken Screen
pretty easy to replace the screen, i suggest buy SD300 from ebay that has lens problem, but it is known for sure that screen is working, you might find one for $20-30, also look for SD200 you might find it cheaper and it uses the same screen as your SD300
Aug 19, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
View screen sticks on view mode when switch to take picture mode
This is a button/firmware problem Canon Customer support will advise on your next move -depending on the age of the camera
Jun 28, 2007 | Canon PowerShot A75 Digital Camera
Fuji DS-300 Digital Camera Logo
22 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
