Question about Canon ImageClass D880 Copier
I just received an E003 error when running my Image Class 860 copier. Any suggestions? Thank you so much!!!
  • 37 Answers
Generally with canons this will be a fuser error.
Posted on Oct 17, 2009
  • Canon Master
  • 1,297 Answers
Please clean the fuser unit thermistors and thermofuses and verify the continuity the fuser heater lamp.
Posted on Sep 28, 2009
How to fix the Canon Image Class Printer 4750 error code e001-0000
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
for more details : www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
Jan 04, 2015 | Canon Office Equipment & Supplies
Canon Image Class D860 - Error message E003. How do we correct?
Under service mode ( MENU and # ) find CLEAR, and select ERR ( if you cant find err, select ALL ), and OK.
Restart machine.
If that does not help change the whole fixing assy.
E003 means that you have temperature problems in fixing assy.
If clear does not help, that means that you have bad thermistor or fixing ceramics.
Jun 29, 2010 | Canon imageRUNNER 400S Copier
System Error
Sometimes, this class of copier will "hiccup" and throw an "Exxx" error code; most of the time nothing is really wrong, it just needs to be reset. You can try the following procedure to reset the copier: First, you press the Additional Functions key, then you press the # key, next you press > until you get to #7 Printer Function, then you press Set, next, you press > until you get to #4 Printer Reset, once again, you press Set, then press <. After this is done, unplug the copier, then plug it back in and turn it on. The machine should reset and go back to normal functions. If the code appears again, there is a deeper problem and a Canon tech will need to be called. Good Luck!
Oct 21, 2009 | Canon Image Runner 1630 Copier Copier
Paper Jam but no papaer found Canon Image Class D860
Have you checked that the paper path is clean and free of paper fragments which sometimes get jammed in the sensors? Try blowing them with a compressed air bottle.
Aug 24, 2009 | Canon imageCLASS D860 All-In-One Laser...
Canon image writer 860 e000 error
E000 is a fuser error
Thermofuse (blown)
Lamp (blown)
Replace or repair them
Replacement would be a good option as its cost effective as compared to its repair and it would not create any issue in the next few years.
Thanks.
Mar 24, 2009 | Canon PC-860 Black and White Copier
Error E000
This is a reprint from another tech, he was right on with this...
okay lets shed some light on the E000 error code on the D680, D880, IR1300 family ( including the 1310,1330,1370,1630,1670)
The error code E00 is a memory threshold error what it means is your machine has logged 4 of the following errors, E001,E002, or E003. It is a lockout error and the machine cannot be used until the problem has been repaired or the errors cleared. First lets look at the errors:
E001 fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
E002 fuser temp dropout means the fixing assy has cooled below a set point during a copy session
E003 fuser no response means the fixing assy didn't even attempt to warm up at power on
How to fix, most common problem is bad power setting 4 E002's either brown outs of brief power failures.
To clear the error, Enter service mode by pressing additional functions then the # button, use the left or right arrow buttons to scroll to #7 printer press set. again use the arrow buttons to scroll to #4 printer reset press set. press the appropriate arrow key under the YES to clear the error. unplug the copier and reboot. At this time normal function should return if not and it resets a E00 the you can assume either the fixing assy is bad or either the power supply PCB or DC controller is bad and it is getting E001,E003 errors. At that point id call a qualified tech to research the problem to avoid spending money on excess parts
Hope that helps...
Lbcoaster
Aug 08, 2008 | Canon ImageClass D880 Copier
Canon copier image class D760 / system error E0003
Try this one from Canon:
Issue: ERROR LCD: System Error E003
Solution: Reset the unit-IC D/PC 1000 Series
Reset the unit
  1. Slide the platen to the left.
  2. Slide the platen back to the right until it locks in place.
Jul 03, 2008 | Canon imageCLASS D760 All-In-One Laser...
Canon PC-860 Black & White
ERROR MESSAGE ON MY CANON D 860 COPIER
Jan 30, 2008 | Canon PC-860 Black and White Copier
Canon ImageClass D880 Copier Logo
133 people viewed this question
old marine
old marine
