Question about Panasonic Microwave Ovens
Microwave heats intermittently
Hi......Panasonic Microwave in my RV heats intermittently.......when you set time and press start sometimes it heats OK.........then other times it DOES NOT heat even though it otherwise acts like like it does when it heats a measuring cup full of water
Need Panasonic Microwave Oven NN-S548BAV service manual.....Thanking You In Advance........Doug
    Sergeant:
  • 197 Answers
Doug, not not attempt repairs on your m/wave unless you have had training.
When you take off the cover even with the plug turned off, their is still charge inside the m/wave which could kill you!
sounds like the magnetron may be faulty, get your approved engineers to carry out a' power check' on the magnetron etc,
Posted on Sep 28, 2009
My microwave turns completely off... Touch pad and lights inside... I have to wait 10 seconds to 10 minutes and then it turns back on and will ask if you want to set the clock. Sometimes it will let me...
Hi Ben,
This has got to be an intermittent power to the control PCB problem. The control board asking to set the clock means that the CPU has been reset by losing power. First, make sure that the problem is not the outlet by plugging in a small lamp or digital clock to see if it works intermittently or resets. Leave it plugged in for at least 24 hours.
(If using a lamp, put in a small 20 watt light bulb or CFL).
It could also be a bad connection to or at the fuse holder in the microwave oven. If all of the wiring and connections look good, it's most likely a bad connection on the control PCB probably around the transformer on the board. Be careful.......
Oct 22, 2013 | KitchenAid KHMS2050SSS Microwave Oven
RV Panasonic Microwave cycling
The problem is in the keypad control board, eventually it will need to be replaced, also there may be a intermittent short in the keypad membrane this is where a professional will be needed to make that determination.
Jun 11, 2012 | Panasonic Microwave Ovens
My Sharp R-1870F microwave in our rv heats intermittantly and the turn table is stuck. Any advice?
Check the oven door if it locks up, the oven has an automatic feature that when it is not closed properly it won't initialize. Since it heats up intermittently I think the heating capabalities of the microwave is still good, and this problem might be just due to something that is preventing it to operate. which most likely the the locks of the door.
Jul 07, 2010 | Sharp R-1870 Convection/Microwave Oven
Our Panasonic 1350 microwave no longer heats food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ghdgh
May 13, 2010 | Panasonic NN-S963BF Microwave Oven
Microwave panasonic model nn 6358 about 10 years old
In most cases, you press Clock, enter the numbers for the time, then press Clock again, or possibly press Start.
Sometimes you have to press Clock, Clear numbers, then Clock or Start.
Or Clear, Clock, numbers, then Clock or Start.
In some older models, they had a very small mechanical clock button located at the top right corner of the controller near the display window. If yours has that, press it, then the numbers, then that button again or Start.
If this doesn't do it for you, could you post a clear photo of your control panel?
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 21, 2008 | Microwave Ovens
Microwave Ovens Logo
290 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
