I have three phone lines and I want to be able to fax out specifically through the third line automatically. Also we can not receive any faxes. I am not even concerned about the printing functionality at this point. This SCX-4826FCN is replacing an existing machine that was working as described above.
  • Ronald Park
    Ronald Park May 11, 2010
    Do you have three seperate phone numbers or one number?
  • 317 Answers
SOURCE: receiving incoming faxes
# Press the button to enter Fax mode. # Press
. # Press the right or left arrow button to select [Receive mode settings], then press the button. # Press the up or down arrow to select the receive mode that best suits your needs(you probably want "FAX ONLY" When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only), then press . # Press repeatedly to return to fax standby mode.
Posted on Aug 07, 2007
bluegreenash
  • 661 Answers
SOURCE: Can't use the fax on my Canon MP 530
There are 2 ports on the rear, 1 for the incomming phone line, and one to plug in a telephone handset (passthrough) if the telephone line is plugged into the wrong port, the fax machine is unable to dial properly, So try plugging into the other port on the back, it's just next to the other port hope this helps
Posted on Aug 27, 2007
SOURCE: Fax problem
I had the same problem! You have to set your fax machine option to DRPD mode. Menu, to Fax setup, to DRPD mode, press ENTER, ENTER again, it should say waiting ring, you then have to call your fax line. Back to Fax Setup, Recieve Mode, press DRPD mode. This way your machine well distinguish a different ring for your fax.
Posted on Jul 14, 2008
  • 159 Answers
SOURCE: I can't send faxes on my Canon Pixma MP530 on digital phone line
They're telling you your hardward doesn't play nice with their hardware. A few suggestions:
Update your printer, and see if any improvement is found:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=13371#DownloadDetailAct
If that doesn't work, see if your computer has a fax modem that itself can be updated and can support the hardware. Your multifunction printer has a scanner; you can scan in the things you want to fax, then fax from the computer if the computer can fax. This is starting to look like a Dr. Seuss book.
You can also try to learn more about what the problems are and look elsewhere. Your "digital" phone is actually voice over Internet, something VOIP. If you Google for VOIP FAX you'll find some information, like this:
http://www.3cx.com/PBX/FAX-VOIP.html
Posted on Dec 05, 2008
  • 3 Answers
SOURCE: Problems with Samsung SCX-4216F All-In-One Laser Printer?
SCX-4216F could receive fax, but didn't print out faxes. Can anybody help me with this?
Posted on Mar 11, 2009
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
2. Remove any originals from the document feeder tray.
are documents in the document feeder, then receiving the fax will be
unsuccessful.
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Jan 30, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
How do I manually receive an incoming fax? I do not keep it on Automatic Receive because it is on my voice line, not a dedicated fax line.
When the phone rings, pick up the external handset. When you hear the fax tone come over the line press the Start button and hand up the handset.
Apr 14, 2009 | Xerox WorkCentre M15i Laser Printer
CANNOT RECEIVE FAXES ALL OF A SUDDEN
Check the phone line with a basic old phone plug it into the fax line do you get a good dial tone, and no noise on line. Also check the phone line call ATT and have them check the number move the fax machine to different plug. power off the wait tens second power on. check the phone line connector.
Mar 31, 2009 | Minolta Office Equipment & Supplies
No fax reception
Send will work on any phone lines
fax machines are often set to only answer 'secondary' ring tones, double triple or higher. When the line was repaired the phone company may have dropped the special tone off your secondary fax line number, fax will not answer without that tone.
Check in the fax answer settings, what the ring tone is, specific instruction on menu settings in your user guide,
Ring your fax line, and check the tone.
If single number fax/phone, check that the fax is set to asnwer all calls then pass on non faxes
Jul 11, 2008 | Brother IntelliFax-2820 Laser Fax
How to receive faxes automatically
First this is a good machine, I use the same one and have my fax setup for the same thing. If you have a (TAD) Telephone Answering Device first you have to set up your phone to pick up before the fax, do this by setting the phone to pick up on three rings and the fax to pick up on four. Go to Menu/Fax/Setup Receive/Ring Delay. While there make sure Easy Receive is on. The machine itself will distinguish between regular calls and facsimiles and will display this info at the time of the call on its LCD screen, make sure you are using the line connection and not the phone connection. Hope this helped.
Jul 01, 2008 | Brother MultiFunction Center MFC-440CN...
I can send a fax ok but cannot receive one Can you help?
You should verify two things:
  1. Is the phone line from the wall plugged into the correct jack on the fax machine. It should be in the one marked as "Line" or "L", NOT the one with the picture of a telephone or the letters"ext".
  2. Is the machine set to automatically receive faxes. These have different modes of reception. "Manual" receive is when the fax will not answer the incoming call unless you tell it to. This is for users who have an answering machine or phone hooked to the same line as their fax. "Auto" receive is when the fax answers the incoming call automatically after a certain number of rings.
If you only have the fax on this line, your fax should be set to auto receive. If you need instruction on how to set that feature, please let me know what the model number is and I'd be happy to provide that info.
If neither of these seem to be your problem, trying testing the phone line with a regular phone to insure there are no line issues.
Hope this helps!
May 21, 2008 | Brother Office Equipment & Supplies
Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Mar 27, 2008 | Office Equipment & Supplies
Receiving a fax when using the phone
you can not use the phone simultaneously while sending or receiving a fax. You do not need a separate line. especially if you do not do a lot of faxing. You just can not do both at the same time. You can set your machine to automatically receive faxes when you are not present. The machine will detect the sending tones of the senders fax and automatically receive your fax. You may want to order a users manual from brother to help you set up your fax for your specific needs. Their number is 1-800-284-4357. Another option is you can order the distinctive ring option from your phone company. This will allow you to give out a seperate phone number for your fax while only having one line. The machine can be programed to distinguish the distinctive ring and automatically pick up with out you wondering if it is a fax or phone call. But again you can not talk and fax at the same time. Good luck and let me know if I can be of further help! John
Sep 07, 2007 | Brother FAX-1960C
24 people viewed this question
k24674
