1994 corolla-I charged the air cond., and it was cooling fine. After about a mo., it was not cooling very good. I assumed it had a small leak. I put my guages on it and the low pressure was running 15 to 20. The high side was reading about 150.I put a can of stopleak and detector in it. Then I put a can of freon in it. While I was putting the freon in it the pressure started to drop on both the low side and high side. Now the low side pressure is running about 15 and the high side is running 0.What happened?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This has happened because of the low side pressure on your AC pump isn't kicking on, because when the pump is off, the pressures equal out and the low side shows a high pressure. But when you kick the pump on you should see the pressure drop. Check if your a/c pump clutch is kicking on. You can uaually hear it click when it is activated. Please follow this procedure to recharge the AC on your corolla--
Requirements for Recharging the system--
  • Look at the air conditioning system for damage or leaks. Leak detection kits that will help you to find leaks in the system and possibly seal small leaks should be available at your local auto parts store. If you see any visible damage, replace the components or repair the leaks before you recharge the air conditioning system with refrigerant.
  • Find the Low Pressure Side port. You can find this under the hood of the car. It is near the air conditioner compressor. The location will vary with engine size and year model. In most cases, the port is near the firewall. It has a black cap that is sometimes marked L. Remove this cap.
  • Figure out if your car uses R134 or R12 refrigerant. You will notice screw type connectors on the both the High Pressure Side and Low Pressure Side lines in models using R12 refrigerant. Models made in or before 1995 may use the old R12 refrigerant. If this is the case, you have to retrofit the Corolla air conditioning system to accept R134 refrigerant.
  • Check your air conditioning system pressure using an automotive air conditioning pressure gauge. Keep in mind that in order to get an accurate reading, the air conditioner has to be turned on the coldest setting with maximum blowing power.
How to Recharge the Air Conditioner---
  • Read all of the directions on the refill kit. Some kits may have specific directions that you must follow to ensure safe use.
  • Hook the refill hose up to the connector on the Low Pressure Side of the air conditioning system. The Low Pressure Side connector is smaller the High Pressure Side connector so, the refill kit hose should fit only on the Low Pressure Side port.
  • Hold the can of R134 refrigerant upright and allow the air conditioning system to suction the refrigerant out of the can. This may take as long as 10 minutes.
  • Use more than one can of refrigerant if the pressure is still low after the first can is empty.
  • Close the valve on the refill hose and release the hose from the connector when you have finished recharging the air conditioning system. Make sure that you put the cap back on the port.
  • Let the air conditioner run on the lowest temperature and highest speed for at least 20 minutes. The refrigerant will circulate throughout the entire air conditioning system during this time.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Sep 28, 2009
I need the list of codes for a 1994 corolla
1.6 GLi COROLLA
DTC NUMBER TROUBLE AREA 12 clip_image001.gifRPM signal 13 clip_image002.gifclip_image002.gifRPM signal 14 IGN signal 16 ECT Signal 21 Oxygen sensor signal 22 Water temperature signal 24 Intake air temperature sensor 25 Air / Fuel ratio lean 31 Vacuum sensor signal 41 Throttle sensor 42 Vehicle speed sensor 43 Starter signal 52 Knock sensor 51 Switch COND
Sep 29, 2014 | 1994 Toyota Corolla
How do i get my soleus air conding unit to blow cold air, its blowing cool air. can i recharge this unit myself -if so then what type of freon would i use.
most likely have to install a line tap valve to charge. look for oil residue on lines to indicate leak. the evaporator is the weak point on most a/c systems.
Jul 05, 2014 | Soleus KY-25U Air Conditioner
We have a 19954 toyota corolla and need to find
THE drain holes on your car are to the right and left of the grill under the screen and comes out either under bonnet or behind the front wheel on inside of gaurd a small rubber hose and could be blocked with dirt or mud
When you find it put water hose and blow it back up to the screen (not down) also your heater gets its air from the same grill and if to much water fills up in it the heater could also get water in it
DONT PARK UNDER TREES
Sep 22, 2009 | 1994 Toyota Corolla
2003 Toyota corolla airconditioning not coming on. It was running fine and then all of the sudden the air was blowing hot air out and not cold air. Checked our air filter it was not clogged as this has...
If it blows, but not cold, Either you have a leak in the system, the condenser fan isn't running (although it would cool on the highway forcing air through the condenser.. It needs a partial charge with UV dye so any leaks can be traced...
Sep 12, 2009 | 2003 Toyota Corolla
Re: air cond. should exhaust lever be open or closed to cool off?
Im not sure what type of unit you are speaking about but in general a window airconditioner unit will have an exhaust button. This button generally opens a small door that allows a small ammount of fresh air to mix with the conditioned air from the room. When it is closed all of the air is recycled from the room. To cool a room fastest, close the outside air inlet.
Jun 21, 2009 | Heating & Cooling
Air cond dash light works, compressor doesn't go on.
AC's have a low freon switch that shuts off the system to protect the compressor in the advent that you have a freon leak have the system checked for a leak
May 28, 2009 | 1996 Toyota Camry
Wont cool
1. try cleaning the condenser it's gotta to have some dirt.
(if it looks clogged, turn the unit off and spray the condenser with a water hose!) it should throw out some dirt
if you did step 1 and still no cooling suspect a small refrigerant leak.
most of the times if its r-134a, i go down to autozone and buy a stop leak for r-134a and charge it into system.
also if theres a refrigerant leak,i'd get a tech to check and correct leak (if he finds it) but that's worse case scenario :) I'd go with dirty condenser.... email me at hvac.tech7872pr@gmail.com if you need more info.
Apr 23, 2008 | Beverage-Air MT27 Beverage Cooler...
AC WON'T COOL
Sounds like you have a freon leak or your compressor has stopped working. You will probably need a service tech. If it is out of freon, don't let them just add more freon, make them find and repair the leak first. Good Luck.
Mar 27, 2008 | Intertherm P3RA-048K Air Conditioner
Rudd heatpump doesn't cool
Hi, Is the condenser fan running? If not, Check the circuit breaker inside the house and the quick disconnect at the condensing unit. Making sure the power is off, check for any bugs in the contactor. If it is running, check to see if there are any resets on a high pressure switch or control board in the condenser. Check the compressor capacitors and see if they are leaking oil or swelled up. are there any burned wires? Is the compressor hot? If the fan is running and the compressor is not hot it is probably off on Low Pressure and needs charged by a licensed Air Cond Tech. Hope I have helped. Let me know. kstfas
Sep 24, 2007 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
