Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Need to remove pulley from spindle to replace shaft on craftsman driving mower 42'' deck
  • 437 Answers
If you do not the facilities to use an impact wrench, you will need to find to hold the pulley and you a breaker bar with a socket on it to get the pulley nut loose. I would use either"PB Blaster or Deep Creep" penetrating oil and spray it on the nut before you try to take it apart.
Or you may find a professional shop, take the deck to them and may may take the pulley off for a small fee.
Posted on Sep 28, 2009
  • ranman948
    ranman948 Nov 06, 2012
    Thanks bbreton. I have impacts and breakers as well as torches ect... I had no problem removing the nut with the zurick fitting and large washer above the pulley. The 3 new replacement pulleys show thet slide on to a gear tooth shaft and have no set screews or pins and are only held in position by the above washer and nut. I sprayed PB Balster and waited a couple days and attempted a wheel puller but it only bent the old pulley. Maybe heat?
How do I remove the spindle shaft from the spindle shaft assembly on a Craftsman 917.28907 mower deck blade pulley?
On most you cant. Some are pressed in so on those you need a press to get them out. Usually the spindle assembly is not that much more than just the spindle...and since it's assembled you don't need to worry about bearings and grease either.
Aug 23, 2016 | Craftsman Garden
Model # 917.289072 19.5 42" When i engage blades it is very noisy like metal on metal It seems to cut ok but I don't want to mess it up more I changed blades and changed oil
Did you check the spindle assembly. I had one that cracked on my mower and had to replace it.It could be broken at one of the corners and this makes the blade spin off balance or not turn at all.Or a pulley could be worn or bent and the belt makes it rotate against the other metal parts.This happened because I hit some stones. They can damage other parts of the mower deck as well as ruin the cutting blades.You can do an online chat with SEARS parts too and their tech may have more info which may hepl diagnose the problem. Good luck,
Jean
May 27, 2015 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
HEAVY VIBRATION OF MOWER DECK (CRAFTSMAN17.5 HORSE TRACTOR?)
Even new blades can be out of balance, but my guess would be either the other blade spindle, or the tensioner pulley bearing.
Apr 05, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Shaft problems
un hook l/h and r/h lift pins from both lift arms , remove front draft arm from front of deck ( it attaches under the muffler on the chassis )
discoonect the blade engage cable from arm if it uses this type or pop the deck belt off the electric pto if the tractor uses this type
you could just spin each spindle without the blade on ( but leave the top pulleys on ) if spindles bent you should see a wobble , if hard seeing it refit both blades and re-spin each spindle and check for quite a noticable variation in blade tracking when each blade is turned through a rev or two
remove deck , remove both mandrell pulleys from the top of thier shafts
remove both blades and use block of wood and knock the blade spindles out of their mandrells from the pulley side
here is website for parts
http://www.outdoordistributors.com/AYP/AYP_Main.html
just click on 917 the select 288280 from the list
it should show parts breakdown
cheers hope it helps
any problems let me know
paul
Aug 01, 2010 | Craftsman Professional 24 hp 42" Yard...
Need to replace drive belt.Never replaced. 42' Craftsman riding lawn mower. How difficult is this. How do you access rear drive pully
Take a look at how the belt is installed. Then you will have to remove the mower deck and belt from the pulley on the engine. There is probably something by the engine pulley that you will have to remove so the belt will come off. It might be a shoulder bold or a rod with a bolt holding it on. Same with the rear pulley. Then you just have to put the belt on one pulley and watch your fingers so you don't pinch them and turn the other pulley and the belt should go on. reinstall any bolts you removed and install the deck.
Oct 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to replace the drive belat on craftsman 917273280, 21hp, 48 in cut?
you remove shield from engine remove belt, remove deck from mower and remove pulley guards and install belt replace guards , reinstall deck, put belt on engine pulley replace guard
Jul 07, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do I remove the spindle from the deck of a Craftsman mower.
Put your blade back on so you will have some backup on the nut. Wedge a piece of 2x4 between the blade and deck to hold the shaft while you take off the nut. You should do that before unbolting the spindle. If you are just replacing bearings, you don't have to unbolt the spindle at all. Just remove the pulley on top and the shaft with blade attached will slide out the bottom. The botton bearing, however, will be on the shaft and is difficult to get off. I use a bearing splitter to get it down far enough to drive off the shaft.
Jun 15, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Removing pulleys from 42 inch Craftsman mower deck
Put the blade back on the star on the shaft and tighten it down. Now you have some backup for the pulley nut. You may have to wedge a 2x4 between the blade and deck. THe EASIEST way is get an impact and zip it off. :-)
Replacing parts on mower deck
I did sign up for the preminum plan but got no response.
Jun 10, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Loud screech noise from deck area
This can be due to a belt slipping or a bad spindle bearing.
And on the difficulty scale,10 being extremely difficult, The belt would be a 1 or 2 and the spindle about 6 or 7 (because the deck usually needs removed for this job)
Apr 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
347 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
