Question about Sharp AR-BC260 Color Copier
Black lines through printed pages have cleaned unit and replaced black drum unit.....still have black lines
  • Sharp Master
  • 1,294 Answers
Clean the charge corona wire/charge corona roller and the charge corona wire gride,and the transfer/separation corona wire/roller.After clean the units and clean the optical section perform the auto image adjust mode.
Posted on Sep 28, 2009
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Mar 04, 2015 | Brother HL-2040 Laser Printer
Getting a black line on paper when printer warms up...
Black lines on copy come from toner cartridge, or drum unit, or fuser unit which is in the back. check drum and see if you can see line, back of machine with flash light you may be able to see line on fuser roller. Be carefull Fuser is hot.
A copy that is good and then starts to get lines usually the drum unit...
Mar 26, 2017 | Brother MFC-9840CDW Laser Printer
How do you know when drum needs to be replaced I
It is possibly the drum unit.
If you have printed around 10.000 pages with the drum, you should consider replacing it.
Take a look at the black cylinder. (Where the toner connects to the drum) It should also have the same line on the right side.
You can try cleaning the cylinder with a soft kitchen roll or tissue. After that the printing should be normal. If the printing is still not normal, or is normal for just a couple of pages, you should change the drum unit.
If that also does not help, then the fuser unit within the printer is defect.
Mar 05, 2011 | Brother HL-2040 Laser Printer
Black lines when printing brother 9320cw
Vertical black lines means the printer requires maintenance or a new drum. Horizontal lines means a circuit board with problems.
I do recommend maintenance every 6 months at least.
I hope this helps.
Nov 23, 2010 | Brother MFC9320CW All-In-One Printer
Vertical lines printing on one side of the page
9 times out of 10 this is coming from one of the two drum (photoconductor) units. Just open the right side door, release the waste toner box, and remove the 2 drum units. The larger one is the color drum unit and the smaller one is the black. Look down thru the slot in the top of the unit (3 slots in the color drum) and look at the green colored drum surface. On one end or the other you should be able to see the same lines on the drum surface that you are seeing on the paper. One of the 2 drum units should have the lines and that will tell you which one will need to be replaced. Hopefully it will be the black drum unit as they are relatively cheap. The color ones are $350 to $400
Good Luck and Thank You for using Fixya.
May 12, 2010 | Ricoh Aficio CL3500N Laser Printer
Problem for print by photo copier
sounds like the charge grid is not set properly in the drum unit..did you et up the drum unit properly and run the new dev and drum set up..if youy are getting black the charge is not working correct as the charge of the drum help to keep the toner from adhering to the drum surface when copying .. I would take the drum chrge unit out again and check it is set in the right way when you put it back on also check the contacts arent put out of line.
Aug 05, 2009 | Kyocera Copystar CS-1820 Black and White...
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
Brother printer that prints a black line down center
probably a bad drum cleaning blade, It's part of the drum unit
Feb 02, 2009 | Brother MFC-7820N Printer
Printer is printing BLACK PAGES
Solution from brother
Jul 11, 2008 | Brother HL-2040 Laser Printer
Sharp AR-BC260 Color Copier Logo
437 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
