Question about Digital Concepts 54782/54783 Digital Camera
Camera wont turn on when new batteries fitted
My cannon finepix S4200 camera wont zoom in or out I also get message "turn of camera and remove lens cap or obstruction from lens" but no lens cap fitted and there doesnt appear to be any obstruction...
The sensor or logic board in the camera must be fooled, or one of them is defect.
When removing and reinserting the battery does not change this, contact a Canon certified repair centre and ask what it will cost to repair this error. Then decide if you want to spend that money for repair or as a start for a new camera.
Mar 29, 2015 | Cannon Cameras
I was trying to view my pics on my computer. i plugged the usb in the computer turned the camera on and nothing happened. then i unplugged the usb frm the computer with the camera turned on and now my...
remove batteries. try and turn camera on, of course it wont work without batteries but this may clear any capacitors.now fit new batteries or just refit the old if you know they are good. and try again, does it work now?
Nov 09, 2011 | Fuji Cameras
Just purchased a finepix s1800 and fitted new batterys but it wont turn on . can anyone help. thanks nige
Many times these digital camera require photo lithium batteries or rechargeables. I recommend you Purchase these first and try it out. Many times the standard household batteries just do not have enough power to turn on digital cameras. If you are still experiencing problems after new batteries then return back to store for another camera because that model may have a problem.
Apr 03, 2011 | FUJIFILM FinePix S1800 Digital Camera
Wont turn on
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
Dec 31, 2009 | Kodak Easyshare C813 Digital Camera
Wont turn on used new batteries and still wont turn on
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
3. Without the memory card,turn on your camera.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 02, 2009 | Kodak Easyshare C813 Digital Camera
Cano powershot g 6 camera wont turn on
sometimes i found out if you take a pair of needle nose plyer and pull the turminal up alittle the battery fits tighter and makes a better connection. also if you are not using the right battery that calls for it that might help to good luck
Nov 29, 2009 | Canon PowerShot G6 Digital Camera
WONT TURN ON
you need batteries with a high voltage...combined over 3.3
Feb 02, 2009 | Samsung S860 Digital Camera
Total power falure
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Sep 19, 2008 | Fuji FinePix S5000 Digital Camera
Camera does not switch on, even though new batteries have been put in it
Is the new battery fully charged?
You mean no lights at all even a quick blink on any other light when you switch it on?
Did you plug the battery in correct way? (I guess it wont fit if its the other way around :-) but there are batteries that doesn't have keyway and they fit exactly even if they are plugged in incorrectly meaning their connectors doesn't reach)
Contact the vendor or manufacturer of your camera if its still under warranty.
May 05, 2008 | Cameras
Digital camera samsung 301
The camera has died Get onto Samsung Tehnical Support for their solution
Jul 14, 2007 | Samsung Digimax 301 Digital Camera
Digital Concepts 54782/54783 Digital Camera Logo
24 people viewed this question
Top Digital Concepts Cameras Experts
Robert
Tony
Are you a Digital Concepts Camera Expert? Answer questions, earn points and help others
