Question about Nintendo Rock Band for Wii
The blue drum head won't work - Nintendo Rock Band for Wii
  • 32 Answers
Take set apart.wire should only need to be soldered or reconnected
Posted on Oct 24, 2009
Disable the blue "No signal" screen from showing up?
There is no Blue screen disable option on the camera.
Since the blue screen caused by the video heads, try to clean it up by running a cleaning cassette.
The cleaning cassette helps only for minor clogs of the Drum(video heads)
Jan 18, 2015 | Sony Handycam CCD-TRV608 Camcorder
I over heated,the serpentine belt snapped. Opened the hood to find steam rapidly coming out of both the antifreeze and out of the engine right by the head gasket. It wasn't smoke not blue or black jus
Perform a compression test on your cylinders. One unfortunate result of overheating is the blown head gasket. Without compression your motor will not run. Tester are not super expensive or some stores will lend tools.
Jul 09, 2013 | Cars & Trucks
Stihl fs 55r head won't turn
Check drive shaft. Some models have a flexible cable drive shaft that is prone to breaking. also make sure the drive shaft is engaged in the clutch drum and in the gear head end.
Mar 25, 2013 | Stihl Garden
Bluetooth won't connect
I'm going to assume..you've got an iPhone.. Simply because apple seems to have a "list" of approved blue-tooth items.
Unless your "JailBroken" (google only, please do not ask), if the said bluetooth device will not connect, consider updating your iOS to 5.1.1. or 6.0, or simply deal witht thefact..it won't work... Older deviices (3gs and prior) don't support things like A2DP (blue-tooth bi-direction communication, like a head-set)... and unless (jailbroken..see above about google). will simply not work.
If your NOT talking about an iPhone..you've got me.
Apr 08, 2012 | iPhone Apps
WON'T TAKE PHOTO PAPER NOW, ALWAYS BEEN ALRIGHT BEFORE
sir,i buy a epson T-60 printer,i month ago,i use refil ink drum,but now i need daily head clining,blue ink print dont clearly,if daily head clean my printer can damage? i am bangladeshi ,what refil drum is best?what is name?pls. anser me ?
Sep 21, 2011 | Epson TM-T60 Printer
The copies print with 2 white streaks where print should be
pull the toner/drum unit out of the machine. on the top of the drum unit there is ether a blue or green slide lever. move the slide back and fourth 10-15 times. if you have canned air blow out the area where the slide is. reinstall the drum unit see if this works
Good Luck
Jan 29, 2009 | Brother IntelliFAX 2800 Laser Fax
Sony vx2100...blue playback screen
in either case the head condition is bad.. pls inspect the tips on the head whether it is not damaged in the cleaning.inspect the drum hours also..
Nov 08, 2008 | Sony Handycam DCR-VX2100 Mini DV Digital...
Try to playback the tape and the screen is all blue
your heads motor ( drum ) cable may have have come loose or is dirty - since the cleaning tape made some difference the heads were dirty or almost worn out ( cleaner tape is abrasive ) so now there isn ' t enough signal ; if your date and time display worked only in play ? ( still works for camera record video ) your guides were out of alignment - and the cleaning tape took your guides even further out of alignment ( alignment here starts at $ 50 + shipping )
Jan 24, 2007 | Panasonic PV-GS2 Mini DV Digital Camcorder
Nintendo Rock Band for  Wii Logo
125 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
