Question about Mitsubishi VS-60705 60" Rear Projection Television
Mitsubishi vs-60705 when ever a white background is displayed on this tv i see a hairline crack in something ive removed the diamond shield and its not in the wafer screen behind that so i was just wondering where the crack is being displayed from. and how i may fix it....any help would be nice
  • fata_error63 Dec 21, 2007
    kinda like a spider web... a friend of mine said thats probably what it is and they said i should open it up and clean it. do you have instructions on how to do that by chance.. thanks in advance
    Genius:
  • 1,153 Answers
Can you explain what the crack look like?
Posted on Dec 18, 2007
Diamond Shield for Mitsubishi VS45605
Unless you have small children it's better to just remove the diamond shield and throw it away. Less glare on the screen that way. But if you must have a new one go to a local glass shop and have a piece of plexiglass cut to the dimensions of the old one. We do that all the time and it works fine. Usually runs around $60.00.
May 27, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Vs-60705
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility that works on rear-projection TV's should be able to repair your set. I bought the set on Jan 1, 2000. Coming up on 9 years and the set works like new.
Jul 30, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Tv problemsMitsubishi VS-60705 60 in....
My Mitsubishi Model VS-60705 did the same thing a couple of years ago...A TV repair facility replaced the Video card. Any repair facility facility that works on rear-projection TV's should be able to repair your set.
Jul 10, 2008 | Mitsubishi VS-60705 60" Rear Projection...
Screen replacement
Post a email link and I will email you the page from the service manualshowing the disassembly proceedure.
Jan 27, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-60705
I have a Mitsubishi VS-60705 and the picture flutters vertically and horizontally i need to be fixed
Dec 04, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Diamond Shield Mitsubishi 55315
if either of u r close to michigan i have the above tv with no video possibly willing to part it out
Nov 11, 2007 | Mitsubishi WS-55313 55" Rear Projection...
Mitsubishi VS-60705 red lamp replacement
The part you are describing is actually the red picture tube, not a lamp. The tube will come dry and you will need to disassemble the lens assembly on the old tube, drain the coolant (antifreeze), reassemble the parts and seal on the new picture tube, fill with fresh coolant, install the new tube, reconnect all wires including the dangerous high voltage lead, then realign the yoke and entire convergence circuits. This is not something that should be attempted by anyone without experience. If you try it yourself and the seal is not working perfectly, the coolant will drip down on your main boards and the set will be ruined. If you slip while lowering the new tube in the chassis there is a good chance you will crack the tube's neck, and that tube will be useless too.
Jul 30, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Mitsubishi VS-60705 60" Rear Projection Television Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
