Question about HP Mini 1035NR Notebook
Can not start HP mini
Goes to HP blue screen. I select F10 and it goes to BIOS setup utility and then goes to command Reboot and select proper Boot device or insert boot media in slected boot device and press a key...then it loops and does not start
The hard disk must have gone bad, so when you go to bios go to diagnostics and run a test on hard drive, most probably if it fails , u need to replace the hard disk so call hp and u can replace the same
Posted on Oct 22, 2009
I have an HP Mini 110-3135DX. When I turn on the power all that is displayed is a blue screen and it wont boot. How do i fix it?
check you bios pages are correctly configured,,goto bios navigate with "tab" and arrow keys,,play around untill you know these pages dont change anything untill you are sure you know what you are doing..Exit and save pay attention to boot sequence if this is set up wrong it might cause failure in the way you describe,the instructions on the right hand side of the bios pages should help you---good luck --Davey
Jun 20, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
Tried F6 and F11 to reboot my compaq mini notebook, it's not working. When I turn on the notebook it shows F9 change boot device order and F10 BIOS setup options then it goes to a black screen with...
Hi
it may be worth trying the F12 key at startup it may work for you
good luck
or try the F8 key on start-up and try the back to last known good configuration
Jun 12, 2011 | Compaq Mini 110c-1001NR Notebook
I have a hp p6203w how do I enter bios
"HP
Pavilion:
Method 1
Enter the BIOS: Press F1 during the blue HP screen for setup.
In the BIOS: Advanced to Peripheral Configuration to Parallel Port Mode. Use ENTER key to open menu and select EPP. Press F10 to save changes and exit.
Method 2
Enter the BIOS: Press F1 during the HP boot-up screen for setup.
In the BIOS: Advanced to I/O Device Configuration to Parallel Port Mode. Use ENTER key to select EPP. Press F10 to save the changes and exit."
source: http://www.easeus.com/disk-copy/faq1.htm
Apr 08, 2011 | Computers & Internet
How do I fix or repair my HP mini 1000 Netbook with it being stuck in a boot loop? I am getting the "unmountable_boot_volume screen. My netbook does not have a CD ROM drive.
Check your bios to ensure its first boot option is set to the hard drive instead of CD drive or USB drive. If you have a thumb drive plugged in, unplug the USB and try again. On your boot screen there should be an option to hit a key to enter bios (Usually Esc, F2 or Del). Hit whichever key it requests and enter Bios. Once in Bios look for Boot Order and check to see where the Hard Drive is in the order. If it is not set to #1 then do as it says to set it to the first option. Once done hit F10 to save and Exit and return to boot.
Feb 04, 2011 | HP Mini 1000 Netbook
Reboot and select proper boot device or insert boot media in selected boot device and press a key message coming upon my hp mini 110
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to ......,press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
?????????????????? hope this helps
Dec 27, 2010 | HP Mini 1000 Netbook
Hp mini 110 started with a hp symble and f9=change boot device order f10 bios setup options. after a few minites screan said reboot and select proper boot device or insert boot mediain selected boot...
The hard drive is not being recognized as a bootable device- you will need to reinstall windows or replace the hard drive in order to resolve this issue
Oct 02, 2010 | HP Mini 110-1037NR Netbook
How do I reset bios on HP laptop?
To restore the BIOS default setting, open the BIOS Setup screen as follows:
(i) Turn off the computer and wait five seconds.
(ii) Turn on the computer.
(iii) When the first screen displays:
(a) Immediately press the F10 key if your computer was built in 2006 or later (came with Vista).
(b) Press the F1 key if your computer was built before 2006 (XP or earlier). Press the key once every second until a BIOS Setup utility screen opens.
NOTE: On some Compaq Presario computers (before 2002), press the F10 key at the logo screen.
(iv) After the Setup Utility screen opens, press F9 key to select and load the BIOS Setup Defaults .
(v) Press F10 to Save and Exit .
(vi) Using the arrow keys select Yes and then press Enter when asked Exit Saving Changes?.
Sep 20, 2009 | Computers & Internet
HP 1000 mini-netbook bootmgr compressed--no cd/dvd hard drive--
Why all these clueless suggestions? I came here looking for help, but it appears I'll be solving my own problem and lend a hand. First attach something bootable via USB like you already know. Change boot order and boot from some kind of XP install disk. That's where I'm at right now. I'm now in the recovery console which gives me a command line. I had JUST READ somewhere the comand line commands to restore the boot manager that we just compressed.
Hold on....OK ! Problem fixed.
Step by step:
1)Get external CD reader and plug into USB
2)Boot Mini hit F10 or F12, whatever it says to change boot order
3)Reboot and you'll see you now have option to change boot order on bootup.
4)Boot to some kind of XP start disk(stupid me never even looked at HP's recovery disk yet - I didn't want to go there!)
5)Let the startup program run til it stops asking you to select an option, and hit R for recovery console
6)You'll want option 1 for c:/windows and type your password when asked
6)type fixboot then enter
7)It will happily inform you that your boot record is repaired
There may be some warnings or statements in between. You're desperate - agree to whatever they say! ;-)
8)reboot
9)Don't worry, be happy
If you can't stand that you now have that message booting up every time and it looks weird, RIGHT click my computer, properties, advanced, startup and recovery settings, and edit ....change default operating system from ** to Microsoft Windows XPHome etc."
click edit and for good measure delete where it has WINDOWS="" as an operating system. Don't mess with this if you're not sure.
10)Now be happy!
Aug 13, 2009 | HP Mini 1000 Netbook
My brother punched my hp mini laptop and now it goes to the BIOS setup utility screen, is it broken or can i reset it and make it work again?
If laptop goes into the BIOS setup each time you turn it on, it is likely the BIOS battery is loose/dislodged and therefore cannot save and retain the BIOS configuration. Check the BIOS battery and reseat the battery.
Jun 14, 2009 | HP Mini Notebook
Recovery CD not loading onto Hard Drive.
Your optical drive is not reading the disk properly - a common issue as time goes by. Replace drive with a good known working unit and your recovery operation will take place.
Mar 27, 2017 | Itronix GoBook XR-1 Tablet PC
HP Mini 1035NR Notebook Logo
417 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
