Question about Epson Stylus CX3810 All-In-One InkJet Printer
Epson Printer - Skipping When Printing Black
My Epson CX3810 Printer started skipping when printing from the black ink cartridge. It prints three or four lines of text OK, then starts to skip (leave horizontal gaps on the fifth line) on the fifth line, prints a line or two with the gaps, then starts printing OK again for another three or four lines, then start skipping again. This pattern repeats for the entire page. It only skips with black ink only. Colors seem to be printing OK.
I have tries three different black ink cartridges. Two from Epson and one from a different manufacturer with the same results.
Any suggestions for correcting this would be appreciated. Printers are relatively cheap, but I hate throwing away something that might be fixable (besides, I still have three cartridges of ink I to use up, and they're not cheap :-) ).
  • 2 more comments
  • Anonymous Mar 22, 2014
    My epson tx610fw printer does not print some lines consistently?
  • Anonymous Mar 28, 2014
    black ink is skipping lines
  • Anonymous Mar 29, 2014
    Can the printer still print if you have ink in one cartridge only?
  • Anonymous Mar 31, 2014
    what should I do to repair it. Is there a limit on number of print jobs
    Problem Solver:
  • 4 Answers
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Posted on Jan 08, 2008
  • Samah Ibraheem
    Samah Ibraheem Jan 07, 2014
    I have same problem here with EPSON TX210. Did you get solution for this!
Why is my Epson Printer not Printing Black?
Fix Your Epson Printer not Printing Black
Nowadays, Epson Printer is a widely used printing device that facilitates the easy printing services. It was coined for the next generation of printers based on the EP-101. While using the Epson printer, you may face some issues like "Epson printer is not printing black". There may be a number of reasons behind the problem. A few of them can be enlisted as follow:
  • If your Epson printer ink cartridges are empty or low on ink.
  • If the printhead of your printer is not properly cleaned.
  • If the clogs are blocked.
How to resolve if Epson Printer is not printing Black:
This is the most common issue that rises while using an Epson Printer. If you are facing this issue, you need to go through the enlisted troubleshooting steps to cure the problem:
  1. Firstly, you need to turn off your printer and unplug from the power source and t disconnect USB cables.
  2. Then reconnect your printer and plug it back in.
  3. Now, turn on your printer.
  4. Print a "Print Test Page" to check the quality.
  5. Now, check printer ink levels to double check the ink volume in your cartridges.
  6. In case of using aftermarket cartridges, it will not show ink levels. It requires an alternate method to determine whether or not your ink cartridges are at fault. If it is found faulty, replace the system for its proper functioning.
While using the Epson printer, it is necessary to check the alignment of the printhead for the proper printing alignment of the printer. If the printhead is misaligned, the printer stops releasing uniform ink.
It is also important to keep cleaning the printhead of the printer using an automated tool regularly. If the clogs of the printer get blocked then the printer causes ink related issues and unable to print black ink properly.
After going through the above-mentioned steps, you can start working with your Epson printer without any issue. If still your Epson printer not printing black then you can contact the Epson customer service to resolve your problem.
Oct 22, 2018 | Epson Office Equipment & Supplies
Will Epson Stylus CX3810 not print in black and white if just the cyan cartridge is empty?
The new printers will stop printing till the time you replace the empty cartridge with a new or filled cartridge.
Regards,
Shrey
May 30, 2011 | Epson Stylus CX3810 All-In-One InkJet...
Would a CX3810 work with only 1 black ink cartridge?
all epson type need all catridge put in a head, if you want use black only, you can buy ciss sistem
Dec 23, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Epson cx3810 printing blank copies
I had the same problem and had to clean the nozzle tubes. After cleaning the tubes, printer worked great again.
Hope this helps.
Charlene
Mar 11, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Feb 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Colors won't print
hi,i think the problem of ur printer cartridges i is'nt refill....u try to refill it....or clean up ur cartridges.
Aug 19, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Printing Question
are the epson ARC chipsets available on office depot or big retailers?
Aug 15, 2008 | Epson CX3810 Stylus Color All-In-One...
Epson Stylus CX3810 replace ink box. will not let me print.
I'm sorry to say, but I just spoke to epson and the printer will not print unless all cartridges have ink. The black ink only option is only used to extend the life of color cartriges. Just another way for them to get you to buy things you don't need.
Dec 04, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Printer skipping lines
The printer ink that you are using are genuine?
Try Genuine ink clean the head after check nozzle , print nothing spaces , test printing pictures.
Nov 27, 2007 | HP PSC 2355 All-In-One InkJet Printer
Open Questions:
See all Epson Stylus CX3810 All-In-One InkJet Printer Questions
Epson Stylus CX3810 All-In-One InkJet Printer Logo
4,679 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
