Question about Kenmore Washing Machines
Water doesn't stop filling the machine, kenmore 500
    President:
  • 1,185 Answers
If the machine still fills with the power turned off then the fill valve has failed and needs to be cleaned out or replaced (Quite cheap and easy to do )
If it fills with the power turned on then you need to check the pressure switch and the pipes leading to it for blockages
Posted on Sep 28, 2009
How do I find the lid sensor switch on a Kenmore 500 washing machine
If the washing machine stops in the middle of the cycle then it is very unlikely the lid switch is involved. It could be a number of reasons.
Best to drain the washing machine and repeat the cycle a few times to check if it happens at the same point. Could be a problem with the timer or pressure switch.
You can locate all the parts and their location in this site. I hope I have the correct model for your washing machine.
KENMORE Residential Washer Parts Model 11029522800
Aug 05, 2014 | Kenmore 500 3.5 cu. ft. Top-Load Washing...
Kenmore 500 washing machine fills but stops
What is the model number of your unit?
Oct 22, 2012 | Kenmore Washing Machines
Doesn't fill
Possible that the water level sensor is faulty as it tends to indicate before the level has reached thereby starting the rinse cycle.
Usually this can be due to faulty level settings or fault in the pressure switch as it can be acting too fast. It will be best to clean the inlet valve and check the flow , test the water level sensor and see if this works by blowing into the diaphragm.
Sep 04, 2012 | Kenmore 2942 400 3.2 cu. ft. Top Load...
Kenmore 70 series wont stop filling with water to start the wash cycle
Lid off, right side circular pressure switch with black hose attached. Remove end of hose, blow down to make sure not blocked and blow into switch where hose attaches. Should click twice. If doesn't click, faulty pressure switch (replace)
May 19, 2012 | Washing Machines
Washer doesn't stop filling up
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 08, 2012 | Kenmore Washing Machines
Washing machine won't stop filling the tub when I
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
May 20, 2011 | Kenmore 24042 Top Load Washer
Washing Machines Logo
51 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
