Question about Christie Vivid LX20 Multimedia Projector
When you turn on the projector it begins to warm up and count down as usual. Then the light goes off. The fan will run for a while then it goes back to a ready light.
  • 2,236 Answers
It's overheating. check the fans and blow out the dust with canned air. try it again.
Posted on Jan 06, 2010
It stays on for 15 or 20 mins then light goes out but sound still plays with light out,then 4mins later it comes back on
Sounds likely that the projector is overheating. Try removing and carefully cleaning the filters over the air inlets. Carefully washing them in warm water and squeezing dry is usually satisfactory, but DO NOT replace in the projector and turn on until the filters have had at least 10 - 12 hours to thoroughly dry out.
Mar 29, 2014 | Christie DS+60 Multimedia Projector
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
My benq projector turns on for a few minutes (light and fan going strong), then it shuts down.
if it goes through shut down mode (lamp first and fans run a while), reset the settings to factory default. while you're in the menu, check the lamp hours (under settings). if they're close to 2000 hours, replace the lamp. if the projector shuts down immediately, fans and all, you have a power supply problem. you'll need to replace it.
Nov 30, 2009 | BenQ Office Equipment & Supplies
Projector turns on the power light flashing and lamp light solid
Here's the fix: Take off the top cover of the projector. Unplug the wire leading from the two fans in the back of the unit to one of the circuit boards in front of you. Just trace one wire from fan to board. Unplug at board. Turn unit on and it will again turn on, show HP splash screen and then shut down, like it should, because the fans are now disabled. After it completly shuts down, plug the fan wire back into the board. Turn the unit back on and, presto, its working again. It will not turn off.
Try it!
Jun 12, 2009 | HP Digital Projector Vp6120 Multimedia...
Eiki LC-XG110 lamp going off
Lamp is near end of life. Try reseting lamp timer and order new lamp if unit stays on
May 13, 2009 | Eiki LC-XG110 Multimedia Projector
Color
Hi, If you have tried other video sources & still get the same results. It sounds like the motor that turns the color wheel is going bad, These motor's run from 5,000 to 10,000 rpm depending on model & are usually the first point of failure in a color wheel based DLP projector, If you don't count the lamp.
Overtime it may begin to make a squealing noise. Usually you can find replacement motors on the internet by searching the part number printed on the motor google is great for searching part numbers.
Feb 19, 2008 | Optoma H31 WVGA 480P Native EDTV DLP...
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
Lightware vp800
blow out the dust, check the fans, and then replace the thermo sensor if necessary
Sep 08, 2007 | Office Equipment & Supplies
Christie Vivid LX20 Multimedia Projector Logo
93 people viewed this question
Top Christie Office Equipment & Supplies Experts
Lawrence Oravetz
Lampdeng.com
Lampdeng.com
Are you a Christie Office Equipment and Supply Expert? Answer questions, earn points and help others
