Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Kenmore wall oven model 911.4088816
Oven comes up to temp, but elements shut down periodically while cooking. Thermostat reads the set point/ oven temp, untill setpoint is readjusted. There appears to be power coming from the relays,but elements won't heat up when this occurs. Is there a thermal cut-out that could be possibly acting up, possibly need a new control pannel, or relay board?
  • ketsugo31 Dec 18, 2007
    When this occurs, the elements will not come on regardless of temp setting.
  • 231 Answers
I believe this oven was designed to reach a set temp and then interm shutdown to keep that set temp..If oven elements turn back on when temp is raised higher than previous temp ..then there is a good chance its working properly.this is a saftey feature to keep elements on stove from overheating..
Posted on Dec 18, 2007
I have a smooth top kenmore oven model #92172300 when you use the oven it gets to the temperature but then its shuts the heat off i had heating element tested and its good please help
The thermostat controls the heating element. If it comes to temp you know the element is OK. The thermostat can be tested. or just replace it.
Nov 18, 2016 | Kenmore Ovens
I have a GE 24 inch wall oven model number JRS04B0W5BB that when bake is selected the broiler element comes on and then after awhile it looses temp and does not cook anything.
Ovens often use broiler element to preheat, then shut off when set temp is reached. Check fuses for and bake element itself.
Dec 01, 2014 | Ovens
Simpson Harmony Nova electric oven heating problems (oven heats but no fan and light)
The Fan has ,in most cases, two functions - to maintain the oven temp and to clear any condensate or smoke coming from items being cooked. If your oven is over heating it could be the thermostat sensor faulty and giving a faulty reading to the fan. If you set you oven at 350F then sensors control the heat by kicking the heating elements off and in some models and makes the fan aids cool down. Make sure it is at a temperature that would trigger the fan to cool it down. It mostly relies on the regulation of the heating elements to control the temp. Only if it were to get hotter than the elements kicking off can control should the fan kick on. Not being at the site and actually seeing the stove it is hard to determine but if the fan is working every where else it should work when the oven is heating. Again check and see if there is a seperate sensor that monitors the temp of the over and triggers the fan. Not much help but that's where I would look first. Hope this was of some help.
Col. Dana Gillespie
May 11, 2014 | Ovens
I have a new GE Covection Toaster Oven model 169127/169140. My question is should this oven's heating elements shut off periodically when the set temperature has been reached?
YES this is normal it is how it regulates temp by cycleing the elements ......................Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 01, 2009 | GE 168947 Toaster Oven with Convection...
Kenmore oven does not seem to be turning off.
if the broil element was on and the door closed then the oven may have encountered an over temperature issue. i would need your model number and the error code
Nov 26, 2008 | Ovens
Try to identify which oven you have and try to get a manual from the same source
Feb 03, 2008 | Ovens
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
267 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
