Question about Canon imageCLASS MF6530 All-In-One Printer
Yes, it feeds the paper right through and the printout is blank. It's not the toner.
    Guru:
  • 389 Answers
The Presence and absence of the charge on фоторецепторе in analog device is conditioned that that light reflected from original, gets on photo drum and discharges (it), accordingly from light, white, not containing scenes area, is reflected more light, than from black, containing scene area. Accordingly drum runs down where is absent the scene. The Toner has opposite drum sign of the charge, accordingly toner is carried on that area drum, on which is present the charge (the opposite charges are attracted).
More simply, in analog device toner lies on charged area drum.
In цифровом device all on the contrary. The Drum is exhibited (get lighting) by ray of the lazer i.e. there, where shines the lazer, drum runs down. The Toner in digital device has such sign of the charge, as drum so he lies on discharged area drum.
Now we shall consider the main reasons of the origin of such sort to faults, as white sheet (the absence of the scene on copies) and black sheet (potting the sheet on the whole surfaces by toner).
White sheet
1. Absence of the voltage on коротроне (roller) of the carrying (also is identified lower)
2. Does Not revolve фоторецептор (фотобарабан)
3. Absence of the earth фоторецептора (фотобарабана)
4. Problems with high-tension power supply unit (HVPS) (brings about that that is specified in p.1)
5. Is absent voltage of the offset of the magnetic gross, check contact on magnetic gross (particularly often on HP LJ1010 - break spring-contact when leading-in)
6. Distance from magnetic gross before drum more prescribed - a toner is not carried
7. Is Not exhibited drum lazer does not shine, locked шторка lazer, physical obstacle for ray, problems with lazer or management him
If you themselves will not be able to come to apply to service. If you manage, ask to note my help in Fixya Thanks Good Luck!
Posted on Sep 28, 2009
Epson DFX9000 printer is printing blank pages
On mine it was to turn off the printer. Then while holding down the paper feed button, press the power button. Let go of the paper feed right away as soon as you hear it start up. When it's done you should get a printout with a number at the top.
OR
Still Having Epson Printer Problems Then follow Us On: Epson Printer Support
Jan 27, 2014 | Epson DFX9000 9PIN WIDE 1550CPS PAR SER...
Toner is on edge of printout
clean the paper path and the drum first
Apr 16, 2013 | Brother MFC-9440CN Laser Printer
Since i install a new drum, i have smudges on my copies how do i fix
    Sir/Madam
    If you have Brother Printer print quality problems, Then I suggest You clean the Your Brother printer drum unit as follows:
    Small Spots on the printed pages:
    If your printed document has any small white or colored spots, follow the steps below.
    1.Open the manual feed slot cover.
    2. Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
    3.Using both hands, put one blank sheet of paper in the manual feed slot until the front edge of the paper touches the paper feed roller. Wait until the machine automatically feeds the paper. When you feel the machine pull in the paper, let go.
    Note
    • Make sure that the paper is straight and in the correct position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
    • Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
    • Do not put paper in the manual feed slot before the printer is in the Ready state. An error may occur and the printer will stop printing.
    4.Make sure that the printer is in the Ready state. Press + or - to choose "Color Correction". Press OK.
    5.Press + or - to choose "Drum Cleaning".
    6.Press Go. The printer will pull in the piece of paper and start cleaning the drum unit.
    7.When the printer has finished cleaning, "Completed" appears on the LCD.
    Press Cancel so that the printer returns to the Ready state.
    8.Repeat steps 3 to 7 two more times using a new blank sheet of paper each time. Upon completion, please discard the used paper. If the print problem still remains, please go to the Step 9.
    Large spots on the printed pages:
    Hint If your printed page has colored spots at 94mm (3.7 in) intervals, please follow the step below.
    1. 9.Turn off the printer power switch.
    10. Fully open the top cover by lifting up on the handle (1).
    11. See the print sample to identify the color causing the problem. The color of the spots is the color of the drum you should clean. For example, if the spots are cyan, you should clean the drum for cyan. Take out the drum unit and toner cartridge assembly of the color causing the problem.
    Caution
    • We recommend that you place the drum unit and toner cartridge assembly on a clean, flat surface with a sheet of disposable paper or cloth underneath it in case you accidentally spill or scatter toner.
    • To prevent damage to the printer from static electricity, DO NOT touch the electrodes shown in the illustration.
    12.Push down the green-labeled lock lever (1) and take the toner cartridge out of the drum unit.
    Caution
    1. Handle the toner cartridge carefully. If toner scatters on your hands or clothes, wipe or wash it off with cold water at once.
13.Put the print sample in front of the drum unit, and find the exact position of the poor print.
14.Turn the drum unit gear by hand while looking at the surface of the OPC drum (1).
15.When you have found the mark on the drum that matches the print sample, wipe the surface of the OPC drum with a dry cotton swab until the dust or glue on the surface comes off.
DO NOT clean the surface of the photosensitive drum with a sharp object.
Note Make sure that you put in the toner cartridge properly or it may separate from the drum unit.
17.Slide each drum unit and toner cartridge assembly into the printer. Make sure that you match the toner cartridge color to the same color label on the printer.
C- Cyan, M- magenta, Y- Yellow, K- Black
18.Close the top cover of the printer.
19.Turn the printer power switch back on.
If your question was not answered, please check...
Clean the drum unit Brother
Or
If You still need Brother Printer Help I suggest You follow Us On for :
Brother Printer Support
Nov 07, 2012 | Brother Dr420 Black Drum Unit Cartridge
How to solve paper jam problem in samsung scx 4300 printer
This is the problem with the paper feed mechanism. make sure nothing obstructs the paper path. also, check the feed roller - this is the rubber thingy that picks up the paper, make sure it is clean and not gummy.
if the paper does not enter the printer squarely, then the printout will be crooked. if it is severely misaligned, the you will have a paper jam.
OR
the fuser gets too hot which causes problems with the paper or the toner.
hope this helps..
Jan 06, 2011 | Samsung Office Equipment & Supplies
HP laserjet P2015 is printing blank
Are you getting toner on the paper? To find out, print a test page. When you judge that the paper is under the toner cartridge, turn the printer off and look at the toner cartridge. Is your document displayed on the toner drum in toner? Is there toner on the paper?
No No Replace the toner cartridge. If that doesn't work you have more serious problems.
Yes No Replace the transfer roller.
Yes Yes If toner is smeared on the paper, replace the fuser.
Jan 08, 2010 | HP LaserJet P2015dn Printer
Hp 4300 laserjet. All printouts have a blank space
Remove the toner and wipe the small window that's above where the drum unit sits inside. That window gets covered with toner and makes light prints and blank areas.
Nov 18, 2009 | Office Equipment & Supplies
Lazer not scanner
If I am not mistaken you are getting blank paper when you give printing command am I right if yes........
every laser printer has one data scanning and transferring data to toner drum unit in it.
BLANK PAPER PRINTING PROBLEM ONLY LINKED WITH
1. TONER CARTRIDGE PROBLEM OR
2. SCANNING UNIT OF YOUR LASER PRINTER PART OF YOUR LASER PRINTER.
CHANGE TONER IF PROMLEM IS SAME THEN IT IS CONNECTEE TO SCANNER OF YOUR LASER
IF NOT SOLVED MAIL ME TO inkcity@rediffmail.com
Jun 01, 2008 | HP LaserJet 1012 Printer
Canon imageclass mf6550
If the paper feeds through but nothing is on it, it indicates that the toner is not being properly fed. Go to this link, type "printout is blank" in the Search window and click the search button. Next, click on the "Printout is blank" line, and review the document. Especially check that you have removed the seals from the toner cartridge (see steps 7 and 9 on the second part).
May 06, 2008 | Canon imageCLASS® MF6550 Laser Printer
INK ON SIDE OF PAPER
i would replace the toner cartridge first.
Feb 11, 2008 | HP 4250 Monochrome LaserJet Printer
Blank papers
Try again the old toner cartridge if you still have it. Even though the print quality might be bad, see if there is a printout. If the page is not blank like the others, that is an indication that the new cartridge is defective and has to be replaced.
Sep 05, 2007 | HP LaserJet 2420 Printer
Canon imageCLASS  MF6530 All-In-One Printer Logo
54 people viewed this question
old marine
old marine
