Question about Whirlpool MH1150XM Convection/Microwave Oven
I have a whirlpool model# MH2175XSS-0 that won't turn on.
One of my kids pushed in the receiver latch on the microwave side, not on the door, and the door would not latch shut so I pulled the latches back out and when I pulled the upper one out the house breaker tripped. I flipped the breaker back on and the unit won't turn on. Is there a fuse somewhere on the unit, or what do you think is wrong?
MicrowaveSvc
  • 9047 Answers
SOURCE: breaker blows
When you turn it on? You mean when you plug it in?
When a microwave blows a breaker but not the fuse, it's often a shorted monitor switch (usually the middle door switch) or one of the other two door switches, or a loose or broken door switch mount.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 17, 2007
  • 126 Answers
SOURCE: stuck door latch
no call a tech micro-waves can be dangerous to work on
Posted on Dec 22, 2007
SOURCE: No power from Whirlpool.
The problem was a defective switch. There are 3 switches on mine. 1 on the top door latch, and 2 on the bottom. one of the switches on the bottom connected the power and neutral together, unless it was activated at the same time as the other 2, causing the breaker to trip or the internal fuse to blow. When unhooking the wire going from this switch to the other switch, everything works great now. Though I still need to replace the switch.
And for Basic 1. Yes my microwave did have a fuse in it it's ceramic, I got a pack of them at Radio Shack 4 for 3$ 250V 20 Amp. There should be a wiring diagram inside the microwave, mine was inside a black bag, so it may be hard to see.
Mine was up top next to the fuse behind the Plastic Grill and then a small metal grill. Some are behind the control panel, to fix this remove the screw at the top and then slide the control panel up and it should unhinge.
Posted on Apr 01, 2008
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Microwavesvc, that's what I've had happen with my sharp also, I carved a hook out of a piece of plastic and then epoxied it in, and haven't had any more problems with that.
Another problem I've had with the sharp (that just reoccured, I'm trying to figure it out) is that the micro-switches that the door latch push have gone bad. Originally just one went bad and I replaced it, now the micro has the light and fan on, and won't recognize being closed...
Posted on Jun 11, 2008
SOURCE: Whirlpool microwave Model # MH3185XP No power?
I just had a problem with mine and took the panel off and did find a fuse on the inside on the top portion of the unit. Try changing it and see if it works. Hope it helps.....
Posted on Jan 17, 2009
Kitchenaid microwave open door switch does not work
on my microwave, the door sticks some times & I put my fingers under door on latch side & push up, & I can hear it release & open. other than that there may be a broken part. follow the link below.
KitchenAid Microwave Door Won Open
Jan 23, 2015 | KitchenAid Microwave Ovens
Sharp microwave model R-530EK won't turn on. problem in door latch?
You could download the service manual from this website and go to page 11-1 for instructions on removal of top cover.You should then be able to access the latch from the side as it is under the control panel.
The manual also provides repair procedures on different problems.
You have to be vary careful with microwave oven interior and at all times when working on it the power chord should be taken out. There area also high frequencies and precaution must be taken and never turn on without the top cover back in place.
http://031d26d.namesecurehost.com/mwd//r530ekt_r530est_r530ewt_sm.pdf
Aug 27, 2014 | Sharp R-530EK R530EKT
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Apr 02, 2013 | Microwave Ovens
Whirlpool microwave model #WMH1164XVS-2 door won't latch, what do I do?
I thought I had answered this, but here goes again: :)
First of all, you can find helpful exploded views and the parts list here.
Hopefully the issue's something you can fix yourself by checking the door (taking it apart) and checking the latches in the frame of the oven.
You have to separate the door panels as shown in the photo.
Or you can watch a
YouTube video (not a video I made) that demonstrates how it's done.
If the issue is with the door itself, and you cannot repair it, then you would have to order a whole new door since door parts are not available separately for this model.
You can order Whirlpool parts from the Pros here.
Dec 10, 2012 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Microwave won't start
I have the same problem. Is the light still on inside the microwave? Mine is on and the microwave thinks the door is not shut. I took the top off of the microwave and the latch needs to push down on a switch once shut. The latch was reaching the switch, but I think some spring in the door, pushing the latches down, has broken since it reaches the switch when closed but there isn't any downward force to flip the switch.
I am trying to figure out how to repair the latch but if your light is on when you "shut" the door, you may have the same problem.
Aug 23, 2012 | Cuisinart CWM-100 Microwave Oven
Whirlpool Microwave Oven (Model MH1140XMQ-0) interior light will not turn off
ther is only 2 causes for this. one is that the door latch has failed and the only way to repair is to get the entire door assembly. the other is a switch that is on the inide of the unit just behind the user control. i do stress that, if you pull the outer cover off to access the inner switch, you need to be very careful about what you touch, and unplug the unit. there is a capacitor inside the unit that will shock you and it does hurt. the high voltage side of your microwave is about 20,000 volts
Mar 27, 2012 | Microwave Ovens
I have a Panasonic Model #NN-S255 microwave oven. The button you push to open the door does not open the door. It's like there is no resistance when you push the button therefore it does not push up...
Hello,To get the door open and salvage your dinner, take a long thin blade ( I used a frosting spreader) and insert from the bottom between the door and the oven frame on the side with the latches (usually next to the control panel). You may have to pry the bottom of the door open just a bit. The object is to push up the lower door latch (which is connected to the upper door latch) and manually open the door. You may have to try a few times but this worked perfectly for me and saved dinner. Obviously the door latch needs to be repaired but this solves the immediate problem of dinner being held hostage by a recalcitrant microwave.
wish you good luck,
take care.
Aug 02, 2011 | Panasonic NN-S255 Microwave Oven
The door latch has been pushed in so now the door can't close.
remove the outer casing so that you can gain access to the door locking mechanism, you will then have to use common sense to decide how to repair
Feb 26, 2009 | Microwave Ovens
Stuck Microwave door
The button assembly or the arm thats attached to the push button is broken. With the unit unplugged. Carfully take off the screws from the sides and around the back of the unit around the outside of the cover. Now once apart, DO NOT TOUCH any electrical parts. Look at the mechanism and see if you can see why the buttons not activating an arm to trigger the door latch. If you think you see why, Go to http://www.repairclinic.com and enter your model #.. Answer the questions and then a bunch of parts will come up. If they dont then get the tele # from there and call them. Depending on how old the oven is, you may want to consider a newer oven??. Good luck
Jul 30, 2006 | Whirlpool MT4070SK 700 Watts Microwave...
Whirlpool MH1150XM Convection/Microwave Oven Logo
133 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
