Question about Lexmark Z1300 InkJet Photo Printer
The paper is feeding unevenly and jamming - Lexmark Z1300 InkJet Photo Printer
    Problem Solver:
  • 5 Answers
Agreed. Assume every time this happens something microscopic fell into that tiny pinch of an area. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over and shake it around til the little bugger falls out.
Posted on Oct 16, 2009
    President:
  • Lexmark Master
  • 990 Answers
Hello sir; There got to be have something drop in the paper path , please check it up!
Posted on Sep 28, 2009
Paper jams when I put it in the tray to fax (from the top tray)
your wheel on one side is impacted with small pieces of paper
this causes the paper flow to go unevenly you need to clean you wheels on both sides oil them and wipe dry with a paper towel
then do the paper feed jam clear and let a few pieces go thru to pick up any remiaining debris
Aug 22, 2012 | Brother MFC-7820N Printer
When I print, the paper gets jammed. The paper is grabbed on one side and goes in unevenly thus causing the jam.
Hello!
We must feed curved paper to our printer. To avoid paper jam let the paper be straight and dry... thanks
Sep 07, 2011 | Canon PIXMA MX310 All-In-One Printer
The printer keeps saying that there is a paper jam when there is not.. Also some times when it trys to print it will jam and the page will be torn down the middle.
Check the machine carefully, sometins a small sliver of paper is caught in a critical place in the printer and will give the paper jam message. If you paper is being torn it is most likely due to an uneven feed caused by feed wheels that are slipping on one side while the other side still feeds normally. Clean all the feed wheels in the paper path with a Q tip soaked in Isopropil Alcohol. Also make sure that your paper guides are set to the correct widths.
Jan 21, 2011 | Lexmark Office Equipment & Supplies
Lexmark 7675 paper jam
> feeds unevenly
Usually, there are two, maybe three, rollers that should _evenly_ pull the paper through the path.
Check that each roller is making good contact with the paper.
> out of paper error-message
There's a small sensor, and usually a "finger" that rises when the weight of the paper is not sufficient to hold the finger down. Check for "dust" clogging/blocking this finger.
If all else fails, it's time to take the printer to a qualified technician, for a professional cleaning & tune-up.
Apr 16, 2010 | Office Equipment & Supplies
Paper feeds crooked then jams?Used less paper different paper it just pulls the paper in unevenly the jams. Help
Check feed roller for contamination, fan the paper to seperate sheets and then make sure that you are using paper of the following standard:
Paper Type Thickness Weight Single sheets
(plain paper) 0.003 to 0.004 inch
(0.08 to 0.11 mm) 17 to 24 lb
(64 to 90 g/m²)
Make sure you are using paper supports and feed guides.
Apr 09, 2010 | Epson Stylus CX9400 Photo Printer
Uneven paper feed
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
May 02, 2009 | Office Equipment & Supplies
Canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Apr 03, 2009 | Canon PIXMA MX300 All-in-One Printer
Canon pixma ip3000 paper feed jam
try cleaning the rollers with alcohol, the tires are probably dirty and one side is not gripping the paper.
Jun 19, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Paper jamming and feeding unevenly
I have the exact same problem. Until last night it worked perfectly, and when it ran out of paper, I put more papers in the back of the printer correctly and since then it won't print, it pulls paper to the right and the paper jams. I tooked the printer to the service and they say that I'm lucky that the warranty did not expired yet, cause the problem is a "manufacturing mistake", and that they will take it to the Canon service.
I realy hope they will do the job. I'm expecting to repair be done till tomorow.
Apr 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Lexmark Z1300 InkJet Photo Printer Logo
158 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
