Question about Amana SCRATCH&DENT 25 Cu. Ft. French Doors Refrigerator (BLACK COLOR) AFD2535DEB
Refrig not cooling on model amana afd2535deb freezer working good
I have same peoblem sounds like small door in back of frig wants to open but doesnt help. no cooling of frig but freezer works great. thanks
catriver
  • 878 Answers
SOURCE: Freezer cool, but Frig section is not cool
Volman, take a look in the freezer section and see if you have a heavy build-up of frost on the back panel. You want to take the evap cover off and see if the evaporator is frozen up. If so, your refer did not go into defrost and cannot move the air over to the refer side. If this is the case you will have to defrost that evaporator completely. On these Amanas the culprit is usually the bi-metal which sits on the evaporator. Look at it and see if it's buldged. The part number for the bi-metal is ro131661. If you defrost the evap your refer will start cooling again normally until it freezes over again. This will give you time to replace the bimetal....Catriver...post back.
Posted on Aug 21, 2006
  • 1214 Answers
SOURCE: amana refrigerator warm
Chances are if they are getting cool but not cold-
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Posted on Jan 20, 2009
  • 20 Answers
SOURCE: amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
Posted on Jun 04, 2009
  • 52 Answers
SOURCE: JUST BOUGHT AMANA BOTTOM FREEZER, MODEL#AFD2535DEB
Sounds as if you have a bad timer or a cold control They can be replaced. Most likely it is the cold control
Posted on Jul 15, 2009
  • 239 Answers
SOURCE: amana refrig refrig wont get lower than 42 degrees
that is defrost timer every 8 hrs it turns on heater to defrost evap coils, unless there is major ice behind freezer panel after 1 day which i doubt, that would not be problem ...im trying to go through steps i would take as tech at your house
Posted on Jan 03, 2010
How do I determine and fix what is wrong with 2008 model whirlpool frig that the freezer I noticed first all food unfrozen then a couple days later refrigerator not cooling can hear running but contin
I ned more information to answer your question. What model do you have? This is very important to give you the correct information you seek. Thanks
Sep 16, 2014 | Whirlpool Refrigerators
My refrig. quit getting cold but the light works and so does the freezer area
Sounds as if a condenser fan has gone bad. Most models it is located in the top freezer section. The frig section gets it cold air from the fan.
Dec 15, 2009 | Amana AFD2535DES French Door Refrigerator
REFRIG WILL NOT GET ANYTHING COLD
make sure there is no frost buildup behinde the freezer back panal and the ducts to the frig are clear. Leaving the door open will make a lot of frost and diminish the cooling capacity.
Eric
Jun 24, 2009 | Amana ARB190ZCS Bottom Freezer...
Amana refrigerator warm
Jan 20, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana afd2535deb Frig- freezer works fine but frig doesn't cool
If the compressor didn't come on the freezer wouldn't work at all. The problem is in the inside fan on the fridge side.
Nov 09, 2017 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Amana side-by-side refrigerator/freezer
raise the front legs/rollers so unit is tipped back slightly.its ok if it opens as long as it closes.
Aug 07, 2008 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Fridge not cooling
sure is you nailed it, behind the lower crisper drawer is air retunr make sure nothing covering those. removing back panel of freezer will also show problem, id assume iceis building up on either side. remove ive and refrig is restored. make sure doors are sealong sounds like warm aire getting in somehow
Feb 07, 2008 | Amana ABB1927DE Bottom Freezer...
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Amana SCRATCH&DENT 25 Cu. Ft. French Doors Refrigerator (BLACK COLOR) AFD2535DEB Logo
59 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
