SOURCE: Err message
Have you tried using a different memory card or formatting the memory card? My S1 was acting weird until I formatted the memory card using my computer.
SOURCE: flash not popping up or
The S700 does NOT have a manual release for the flash to pop up, but it DOES have a spring already. DO NOT try to force it! Set the flash to "FORCE", leave your lens cap on and waste a shot to allow the flash hood to pop up. Reset your flash to the desired setting and now the flash is already open and ready for use without the delay and the startling effect it has when your concentrating on framing your shot. As for the other problem of no flash in any setting: Check your menus to see if you have the flash totally disabled, check your batteries, does the "charge indicating light" come on at all between shots? In RARE cases, the actual bulb that flashes may be burned out, or a component in the flash circuit itself,such as the capacitor, may have gone bad. Did the flash ever work? If under warranty, return for repair or replacement. There are NO user serviceable parts in these tiny cameras
SOURCE: fuji s700 my flash is not popping up on auto and my camera is taking all dark pics
The flash on my S700 stopped popping up too. But I made a spring about 3/4 inch in diameter by 3/4 inch high with about 1 3/4 loops. I glued it right under the flash. It works quite well now.
SOURCE: Fuji finepix S700 Built in flash not working
It is a common problem. Your flash probably does not pop all the way up. I fixed mine by gluing a spring I made under the flash. The spring is about 3/4 round x 1/2 high with about 1 1/2 turn. It took me a while to get the spring tension right.
SOURCE: Flash will not pop up. Can you help?
If it releases but doesn't properly pop up then this may be the answer.
Mine did the same thing. The problem in mine after extensive disassembly was the plastic had broken inside the flash where the pop up spring attaches.
This was a pretty extensive repair with full disassembly in my case, not for most people.
A workaround is to take a small rubber band, loop it over the top of the camera from the eyepiece for the viewfinder to the lobe in front of the flash. When you need flash, release the flasy and unhook the elastic fromt he front lobe and let it go under the raised flash unit and it will keep it up. If you case lets you, you can leave it that way. Not pretty but functional.
