Question about Dell 926 All-In-One InkJet Printer
Printer is unresponsive. Buttons won't push. Ink
Printer is unresponsive. Buttons won't push. Ink won't even travel to center of machine to prepare for printing. Really hoping it's fixable. ??
Hello.. Im having issues with my printer recognizing the ink cartridge.
Could be various issues. Some printer cartridges are programmed to expire so they will not be usable after a certain date. Other cartridges made or filled in foreign countries will not work. Try a brand new cartridge.
Mar 29, 2017 | The Office Equipment & Supplies
Ink cartridge in Z705 will not move to center of carriage for changing when top is lifted Even though the Belt is moving. Help !!!!!!!!!!!.. >:( :( :'(
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
I hope this helps.
Oct 24, 2011 | Lexmark PhotoJet Z705 InkJet Printer
Why will my ink cartridge not move to the center so i can tak e it out.
Sep 10, 2011 | Lexmark X2470 All-In-One InkJet Printer
My canon MX340 won't print, saying there is a printing error 5200. I tried unplugging the printer and turning it off, but it still won't work
I will advice you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see if that fix the problem.
Jul 11, 2011 | Canon PIXMA MX340 Wireless Office...
My Brother LC61, bought in Nov.2010, won't print black. Recently replaced black ink along with all color inks...replaced black ink again when it quit printing...still won't work. Machine whirs...
This is common problem with Brother Printers. I am going to assume you are using Non-Brother branded ink cartridges. Brother cartridges have a cleanser in the ink that most generic cartridges don't have. This in turn causes the jets to clog and not allow ink to pass through them. The fix is to go buy a couple of Brother cartridges and do a cleaning with those cartridges. You may spend some money doing this as a cleaning wastes a lot of ink, but it will clean the injection lines and fix the printer. You could also consider buying a new printer. I know this is not the answer you were looking for, but it is the true answer. I just bought a new printer due to this fact.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 11, 2011 | Brother Multi-Function Center MFC-240C...
How do I install the ink cartridge
You will find two buttons on your printer.
One for power and the another is a function button.
Push them together at the same time while the printer is on.
In most cases this will move the ink head to the center on the machine in order for you to remove the old ink cartridges and install the new ones. However a different button may need to be used consult the manual in this regard.
The ink cartridges are clipped in, you will need to undo the clip!
Then pull the ink cartridge out, usually upward force applies.
Now once the old cartridges are removed you can install the new cartridges.
Be sure to remove any stickers that are meant to be removed, read the sticker and if it says "remove before use" then remove it.
Insert the cartridge and push them down, then the clip is to be clipped in.
Now to get the ink head to move back to it's lair first try pushing the function button.
If nothing happens then push both buttons together again.
Please read this session a number of times to get the jist of what needs to be done.
Also I would like to ask you to please rate this session with the use of the Thumbs on the right.
Thanking you very much.
Till next time!
damnor01
Mar 20, 2011 | Canon Pixma iP2600 Photo InkJet Printer
Hi, my canon i80 printer wont feed paper through
There is only one solution to the problem with the i80. Here it is: there is nothing jammed. This problem is the result of the top of the printer being pushed down, effectively crushing the paper feed path by a sixteenth of an inch, right at the center of the machine. Likely this is the result of being carried in a travel bag full of other stuff, like the power supply, or from things being placed to rest on top of the printer. The solution is to open the two top covers, to grasp the main steel bar that runs the entire width of the printer with a pair of long-nosed pliers and to simply apply upward pressure. This will, in turn, lift a black plastic paper guide that has been pushed down into the path of the paper by the slightly bent metal. The printer will happily feed paper after this relatively simple fix. Mark the problem up to bad industrial design (though the mechanisms of the printer are otherwise ingeniously well thought out).
Sep 16, 2010 | Canon i80 InkJet Printer
Changing cartridges
1) With the power on, open the front cover. The print head should move to the center.
2) Prepare the new cartridge for installation by removing the tape(s). Do not touch the area of the ink cartridge that was protected by the tapes.
3) Insert color cartridge into the right slot, then the black into the left slot. Push up and in until the cartridge clicks into place.
4) Close the front cover. Wait until the printer finishes preparing the new cartridge(s).
Dec 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Ink module will not center itself
  1. Confirm that the printer is powered on and press the <Open> button (MP500) or manually pull open the paper output tray
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    NOTE: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains.
  5. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    CAUTION: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  6. Insert ink tanks into the print head.
    NOTE: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  7. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note : MP500 shown.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    NOTE: Click for Ink Tank Lamp indications.
  8. Close the inner cover and the scanning unit (printer cover).
    CAUTION: When closing the scanning unit (printer cover), be careful not to jam fingers.
    Memo: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
- On: The printer is ready to print.
- Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
- Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
- Off: An error has occurred and the printer is not ready to print.
Mar 28, 2008 | Canon Pixma MP500 All-In-One InkJet...
Installing new cartridge
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
Mar 25, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Dell 926 All-In-One InkJet Printer Logo
26 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
