Question about Samsung Jet S8000 Cell Phone
I cannot close applications on the main screen of the samsung s80
I can only close applications by going into the widget menu and removing them. Is there an easier way to do this?
Just drag and drop the applications in the widget bar to the left
Posted on Oct 03, 2009
I have a Samsung Duos B7722 and I have a problem with a message that appears whenever I open pictures. The message is as follows: "Not Enough Resources. Close some applications and try again."...
it may solve through widget setting just remove some widgets from the widget tab on the screen 1 of ur duos phn and it can be done in the just go in display and light setting in the phone stteing menu thn widget n thn jus unmark the not reqired widget its like Setting>display and light>widget>unmark unnessary widget.....thts it hopefully it will work jus try......
Jul 29, 2011 | Cell Phones
Tip
How to set up internet on Samsung Jet
Ensure that you have the appropriate network key code needed to enable you to access a secure Wi-Fi network.
If you are connecting to a secure Wi-Fi network with MAC address restrictions, you will require pre-authorisation for the router. You will need to find your Samsung Jet's MAC (Media Access Control) address. This is a 12-character code which may be needed by the network controller to enable the phone to connect. See Getting the Samsung Jet's MAC address below.
You can get to the Wi-Fi application either via the main menu or using a homescreen Wi-Fi Widget.
  1. To get to the Wi-Fi application via the main menu, press the MENU button (either on the home screen or the hexagonal button beneath)
  2. In the main menu, swipe your finger sideways to go through the menu pages until you see the Wi-Fi icon. Press to select.
  3. The Wi-Fi application opens.
  4. Alternatively, to use the Wi-Fi Widget, from standby, press the home screen. The Widget toolbar opens up.
  5. Scroll down to find the Wi-Fi Widget icon. Press the Wi-Fi Widget. The Wi-Fi Widget will pop up on the main screen.
  6. Press the Wi-Fi Widget on the main part of the display to launch the Wi-Fi application. The Wi-Fi application opens.
  7. Once in the Wi-Fi screen, press the large Wi-Fi button in the middle of the screen to turn it on. Wi-Fi is activated and the button turns blue.
  8. Press SEARCH Nearby Wi-Fi access points (APs) will appear as small circles on the display, with their names next to them.
  9. Press the circle representing the Wi-Fi Netowrk you want to connect to. An options panel appears.
  10. You can press CONNECT to connect to the network or press ADD if you want to add it to a list of preferred networks for easy access later.
  11. You are taken into a settings menu for the Wi-Fi access point. If the Wi-Fi access point requires a network key code, scroll down to the Network Key panel. Press to select.
  12. The numberpad appears. Type in the network key code and press DONE. You are returned to the previous settings screen. Press SAVE
  13. A list of connections appears. Press the back arrow button
  14. If you initially pressed CONNECT, the phone will connect to the selected Wi-Fi network and a confirmation message will appear. The display now shows the new connection, illustrated by blue dots linking the circles onscreen (Figure 15).
  15. If you initially pressed ADD, you will be returned to the Wi-Fi screen. Press the circle representing the Wi-Fi network you want to connect to. A pop up panel appears.
  16. Press CONNECT. You will be connected and the connection illustrated onscreen.
Press the back button to return to the home screen.
  1. From the home screen press MENU to enter the main menu (Figure 1).
  2. In the main menu, press INTERNET
  3. Choose which browser option you want (Home, Enter URL, Bookmarks, etc.) (Figure 18) and press to select. If you press Home you will be taken to the pre-loaded home page.
  4. If required, use the numberpad to type in an URL or scroll a list to select bookmarks. When an URL is completed press GO. Alternatively press the bookmark you wish to access. You will taken to the web page requested.
  1. Activate Wi-Fi and press SEARCH, as before.
  2. When the Wi-Fi access point you want to connect to appears on the display (Figure 8), press it to select.
  3. A pop up options panel appears (Figure 9). Press DETAILS
  4. Details of the Wi-Fi access point appear onscreen.
  5. Scroll down by dragging your finger up the screen. Towards the bottom of the settings list, DEVICE MAC appears, with a string of 12 charactesr beneath (Figure 21). Each handset has an individual MAC address, and this panel will display your Samsung Jet's unique Mac address.
Make a note of the MAC address. You will need it if you want to use the Samsung Jet's Wi-Fi to access a secure Wi-Fi network using MAC address restrictions. This can be added into the wireless router settings access list.
on Apr 17, 2010 | Samsung Jet S8000 Cell Phone
How to download themes in samsung wave s8500 how to download applications in samsung wave s8500
If your country is supported (USA is not), then there are 2 ways to access from your phone. If the Samsung Apps widget is still on your homescreen, then simply tap on it to launch the app store. If the widget is not there, go into main menu and find and tap on the Samsung Apps icon to launch the app store. Once in the app store, go to categories and select themes to view themes for your phone. Enjoy!
Mar 07, 2011 | Samsung Wave S8500 Smartphone
I have a new samsung wave 533 mobile handset.Please let me know how to get rid of widget 10 application items(they are making the screen opech) display on my mobile screen.
Hi! To remove widgets, just long press the central button between the "accept call" n "reject call" buttons under the screen. It will show u options to end all applications or particular applications. Just press the "End all applications" button and all ur widgets will shut.
Jan 03, 2011 | Samsung Cell Phones
Alarm icon is displayed in the center of the screen no matter what I do. All alarms are turned off. I've rebooted the phone several times including removing the battery. What else can I do?
I've had this same weird problem today but I think that I may have solved it.
1. Go to "Menu"
2. Go to "Settings"
3. Go to "Display and Light"
4. Go to "Widget". Among your widgets is one called "Analog Clock". Un-check it and Save the widget screen.
5. Go out of the Menu to the top screen (that has "dial", "contacts" and "menu" at the bottom.) Hopefully, the alarm icon is gone. However, the "Analog Clock" that displays the time in the widgets (opened by the small arrow on the left side of the screen) is also gone. Simply go back through steps 1-4 to get to the "Widgets" screen and check the "Analog Clock". Your Analog Clock should display and the Alarm icon should still be gone.
I know that this solution doesn't seem to make much sense because what does an Analog Clock have to do with an Alarm icon? It just seems to be a software glitch of Samsung.
Try it out and see if it works.
Aug 14, 2010 | Samsung Solstice SGHa887
How can i move all my widget to the main menu
Samsung for that Model doesn't give you the option of moving your widgets to main Menu.
Oct 26, 2009 | Samsung SGH-S5230 Cell Phone
How do i close applications on the main page on a samsung jet mobile?
Basically to get rid of any reminiscent widgets (like if you were playing music and the widget still is in your desktop), just drag the widget you want to get rid off into the sidebar (the side bar will automatically expand when you drag the widget into it, and your widget will minimize and insert itself into the side bar).
Now the widget is officially closed .
Enjoy :) Ed
Sep 26, 2009 | Samsung Jet S8000 Cell Phone
Applications won't close
The applications that stay open are likely to be widgets. Just open the widget side bar and then drag the home page widgets back to the bar where they stay until next time you want them :)
Aug 10, 2009 | Samsung Jet S8000 Cell Phone
The media player stuck on main screen
Open up the Widget bar and drag the media player back into it, then close the widget scroll bar.
Jul 17, 2009 | Samsung S8300 Ultra Touch platinium-red...
Cant get rid of the widget
theres a little toolbar on the main screen click the arrow and drag your music player into it
May 06, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Samsung Jet S8000  Cell Phone Logo
290 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
