Question about Lexmark X1190 All-In-One InkJet Printer
I have a lexmark x1190 and after the last service on my computer the printer only finishes the printing to 99% and will not delete the document from the list
SOURCE: Deleting - Printed
GregoryW's solution worked on a Dell AIO A940, except when I deleted the existing print spool files, the printers disappeared from the Printers and Faxes folder. I had to undelete one of them then the rest of the solution seems to have worked.
Posted on May 25, 2007
SOURCE: document printing hangs at 99%
same problem. everytime i restarted my pc and deleted the printed files from control panel/printers/lexmark x5150.
Posted on Jan 07, 2008
RALilja
  • 381 Answers
SOURCE: i have a document that
The only way to clear a print queue when it won't really go away the right way is to be mean. By saying "mean" I would either turn off or unplug the printer itself from the ac power source and when you turn it back on and it goes back on-line it may or may not attempt to print it again or will spit out a bunch of garbage, if this happens then turn it off again. Sometimes this can take a few repeats of doing the same thing over and over again depending on the size of the document and the printer's memory capacity but the problem will clear itself eventually.
Good Luck!
Rich Lilja
Posted on Nov 26, 2008
Ryan5443
  • 336 Answers
SOURCE: error deleting document
Are you logged on as an administrator?
Ryan Frame
Creative Energy Associates Technical Center
Posted on Apr 28, 2009
techbuster
  • 5081 Answers
SOURCE: Document won't delete from printer queue after printed
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side window.
On the left side click stop the service and wait forthe process to stop .Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them depending apon how many print jobs you submitted. You will have to resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
Posted on Aug 19, 2009
Lexmark x1190 with windows 7 print queue wont clear after printing
Once you load the driver successively then don't try to fiddle with driver. Remove the printer from the system and switch on whether the printer
initialize proper, try to print one self test page.
Jul 24, 2012 | Lexmark X1190 All-In-One InkJet Printer
When i try to uninstall my lexmark x1190 it comes up printing not finished
Try to clear the Lexmark print queue from pending/stuck print jobs so you can successfully uninstall the Lexmark software/ printer driver. Here's how:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
After successfully clearing the print queue, uninstall the printer software by going to Start menu > Programs > Lexmark 1100 Series folder > Tools > Uninstall. Reboot your pc when prompted.
Hope this helps.
Apr 30, 2012 | Lexmark X1190 All-In-One InkJet Printer
Printer is not communicating with computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/u5uUiR. Select your operating system, download and execute the file.
Oct 28, 2011 | Lexmark X1190 All-In-One InkJet Printer
I've installed Microsoft Windows 7 and and now I can't install my Lexmark X1190. What ca I do?
Unplug the Lexmark printer from your computer. Uninstall any existing Lexmark X1190 driver from your computer by going to the Start menu ? Programs ? Lexmark X1100 Series ? Tools ? Uninstall. Reboot pc when prompted.
When your computer turns on, check the System Type if it's 32-bit or 64-bit by going to the Start menu ? right-click on Computer ? Properties. Take note of the System Type.
Use Vista driver in Windows 7. Click on the links below to download the Lexmark X1190 from the Lexmark website.
Download, execute the file and follow the instructions in the software. Thanks.
Nov 21, 2010 | Lexmark X1190 All-In-One InkJet Printer
Printer Lexmark Z640
yor missing some of the program.. reprogram the printer
Mar 24, 2009 | Lexmark Z640 InkJet Printer
Deleting Files from spool after they have printed
see your Spool settings, Set Print directly option and try.
Apr 09, 2008 | Lexmark X6100 Flatbed Scanner
Problems deleting printed files from the spool
Navigate
Start-> Control Panel -> Printer
Right click on printer icon and select properties
Find out Advance settings. See Spooling, Select Print Directly and try.
Although your driver looks like incompatible but above will fix your problem.
Thanks
Iqbal
Lexmark X6170 stops printing at 99%, page comes out okay but other print jobs get backed up behind this. I open the menu and cancel the first one but it won't cancel. I have to reboot, which clears the...
I found the following post on AsusForum.NET that solved the problem for me - hope it helps -
"As I had printing problems with my Lexmark X6170, which I bought at the time because it looked a good deal, I started to work on a solution.
I think this problem is also applicable for a number of other printers. The symptom is that the spooler in windows displays a progress for 99%. If you want to delete the job from the queue, you could end up restarting the print spooler.
The solution is rather simple (it took me a while to find out though).
If you go to the properties for your printer and click on the tab <advanced> and on the button <print processor>, just select the [winprint] processor instead of the manufacturer processor (in my case lexmark...). In the right pane select one of the [NT EMF...] processors and this should do the trick.
ALSO disable the bidirectional support on the <ports> tab...
As I thought the problem lies in the signal which has to be send back from the printer to the processor that the job has finished. As there is now way for the printer to send back the signal over the same printing port (RAW/9100), the spooler still thinks the job hasn't finished.
I searched the technet site and found some notes where a similar problem is described. In the case a problem like this occurs (apparently only with printers which use their own software and need bidirectional support...) they (the dark side) advises to use a Microsoft driver instead...
Hope I could help somebody with a frustrating problem.
(ps. printer works fine, the lexmark software not.)"
Dec 19, 2007 | Lexmark X6170 All-In-One InkJet Printer
Document printing hangs at 99%
Dec 18, 2007 | Lexmark X5150 All-In-One InkJet Printer
Deleting - Printed
I've also had this problem with an HP LaserJet 4650dtn printer. I've solved this by: - Stop the "Print Spooler" service. - Delete all the existing print spool files. (Stored in "C:\WINDOWS\system32\spool\PRINTERS" by default). - Start the "Print Spooler" service. - Right-click the printer's icon in the Printers and Faxes folder and choose Properties. - Click the Advanced tab. - Click the Print Processor... button. - Make a note of the existing "Print processor" selection on the left (in case you need to revert it.). Then change it to "WinPrint". Click OK. - Click OK on the printer's properties window. - Try sending a print job to see whether it persists in the print queue.
May 07, 2007 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X1190 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
