Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
My system is repeatedly restarting itself and sometimes, it does not start. Please tell me a solution for this problem.
  • 2,841 Answers
Most reboots are the result of a failing power supply. First thing to do is to clean out the computer case. Disconnect all cables, take the computer side panel off and using compressed air blow all dust from the system especially the power supply and the processor. You could also have a damaged hard drive. Boot to the recovery console and when it stops at C:\>command enter the following command CHKDSK /R This may fix the problem. If none of this fixes the problem you may need to do a repair install of XP. http://michaelstevenstech.com/XPrepairinstall.htm
Posted on Sep 28, 2009
  • 700 Answers
Your problem may be broad. But to start, check first your wiring usually the plug if that wiggle on the socket. Sometimes if that cord is plug on small AVR or some protecting device on the line.
The usual suspect could be driver, thermal and power supply problem. Next could be your RAM connection is dirty or the video card. Cleaning the edge connector slot with gel eraser would do the work. Or the motherboard is getting grounded on CPU case(desktop).
And last could be viral problem. Start on most simple and direct first.
Hope it helps.
    President:
  • 1,462 Answers
If your system overheats, it automatically restarts..
This restart is initiated by the BIOS, so try running the system in cool environment and if it works well..Just remove the Old heat sink and change that...
PLEASE RATE THIS SOLUTION
RNJ VINODKUMAR
  • 324 Answers
Windows file may be corrupted you need to reinstall the windows
My computer want start and every times I starts it it say error and please restart
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue You might use the system restore to restore your system to an earlier time click start all programs If it is a hardware issue the system restore might not work Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 04, 2013 | Computers & Internet
My sumsung sghd780 keeps restarting itself
Restarting when? While booting?
If you have having boot problems and the systemkeeps restarting, then turn off the computer, then hit the power button andimmediately start hitting the F8 key repeatedly until you see SAFE MODE. Scrolldown past Safe Mode and you will see an option to DISABLE AUTOMATIC RESTART.Take the Disable Automatic Restart option.
Mar 30, 2012 | Computers & Internet
This desktop dell vostro turns itself on and off without the button being pushed. sometimes it makes it to windows, and seems to run just fine, then it goes to shutdown by itself... then turns itself back...
Well in the system Bios or setup there are options where you can have the computer turn itself on automatically at a certain time. However, the fact that yours is turning itself on and off seems to indicate that it is either over heating or it is running into an issue when trying to boot and it keeps recycling the boot process. There is an option that you can set that will turn off automatic restart on boot. Turn off the computer and then turn it on and start hitting F8 repeatedly until you see Safe Mode as an option. Scroll down through the options and you will probably see an option that lets you stop automatic restart on boot, and take it if it is there. This will allow you to actually see the error message that is causing your computer to reboot itself.
Mar 19, 2012 | Dell Vostro 410 Desktop Computer
Windows xp tries to start in safe mode screen then as program starts gets brief blue screen then back to safe mode start selection screen once again this keeps repeating
your system will do this as it has shut itself down to protect itself, to make the blue screen stay on so you can write down the error code (e.g stop 0x0000007B),you need to choose the option of `disable automatic restart on sytem failure` (this will be on safe mode screen, reboot, then when you get the B.S.O.D it will stay on and display an error code, google it and you get the answer or post the code on here and i`ll tell you
Jan 14, 2010 | Dell Latitude D800 Notebook
Panasonic DMR-EZ47VEB stuck on self check
Check IC in primairy power supply
Aug 29, 2009 | Televison & Video
Error message ntdlr is missing running XP service pack 2
do a system restore from the system repair when you first start it up it should tell you what key to press once you get into system repair you can use system restore to fix the problem or either go to safe mode and do it from there then it will fix your problem
Aug 02, 2009 | Acer Aspire One AOA110-1588 Notebook
My Dell Dimension 8200 PC keeps re booting itself once it gets to the home page. i cant even hit the start button cause it restarts itself that fast! please help
As soon as u see the black screen...hit F8 repeatedly to get it into Safe Mode.....then go to system restore and reboot/restore system back on a saved day. Then run your virus protection and scan for malware. This should get you back online. You may need a full system scan to locate the effected DLL's anmd killl off your intruder.
Jun 23, 2009 | Dell Dimension 8200 PC Desktop
Acer 5630
reload the operating system
Nov 30, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
