Question about Moultrie GameSpy 4.0 Digital Camera Deluxe
How do i hook up my moultrie 5.0 game camera to a 12 volt battery? It uses 6 D cells so that would be 9 volts.
  • 11,896 Answers
Find one wire that will go to your springs in battey compartment to negative connection on power supply. Than another wire from positive side of power supply to flat end of battery compartment. You may have to tape or hotglue the wire in place.
Posted on Sep 28, 2009
Can you use rechargeable batteries to save on the cost of the batteries
You can in several type of equipment, but be aware that AA rechargeables are 1.2 volts instead of 1.5 volt of regular alkaline batteries.
May 30, 2017 | Moultrie Cameras
Okay, I'm working on a scooter for my nephew that originally came with (2) 12 volt 12Ah batteries minus the charger. and I know I need to replace them with (2) batteries of the same 12 volts and lets
not exact, to charge apropiate needs 10% more than nominal voltage. if not, will not charge the batteries.
And the charger its very important because you can over charge the battery.An example,if you have a 12 Amps Batteries each one if you put it in series will be 24 Volts.at parallel conection will be 12 volts but the double of Amps.
At serial connection will be 12 Volts the amps will be the same but the volts will be 24.
The charger at 12 Volts must be 13.8-14.5 DC Volts and divide the Amps in Hours.
The charger at 24 Volts must be 26-28 Volts. to charge well.
The charger for 12 amps batt example must charge 2 amps per hour at 6 hours = 12 Amps.(2 Amps Charger by 6 Hours Charging= 12 Amps.(Fully Charged.
3 Amperes Charger needs 4 Hours to charge 12 amps Batt.
5 Amperes Charger needs 2 Hours charging an a quarter
All of this is at DC Current.
Luck.
Oct 18, 2014 | UPG 12V 12Ah Electra Scoot-N-Go 88615...
Give me the difference between cell and battery
These words are used interchangeably nowadays, but technically a battery is a group of cells. An AA "battery" is actually a single cell, whereas a car battery is 6 cells in one box wired in series- each cell providing 2 volts for a total of 12 volts. The 9 volt battery used in smoke alarms is also a true battery, made up of six cells packaged together, each providing 1.5 volts. Most other "batteries" are really single cells, but there is no way to make people use the correct technical terms.
Nov 16, 2010 | Cameras
In have a Moultrie game camer. Not sure of the model no. It looks like the MFH-DGS=200 but it is not infra-red, it is a flash camera. I'm trying to find an operating manual for my camera. I think the...
You can download the required manual by clicking this link:
http://images.ebsco.com/pob/Moultrie/catalog/DGS-200Instructions.pdf
To view all the available manuals, click on this link
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Oct 14, 2009 | Moultrie MFH-DGS-200 Digital Camera
John deere l11 weak battery had to jump off the last 4 or 5 times and this time hook up jumper cables and turn the key and get nothing. no lights no click just nothing. tried 2 sets of cables
Remove the old battery and clean the cables and battery posts. Hook a battery charger to it and fully charge the battery. If it will not hold a charge or the problem continues, replace the battery as it has shorted or dead cell. After replacing the battery or if the battery appears good and then runs down suspect the alternator is bad. Check the voltage at the battery with the engine running. You should have at least 13.5 volts on a 12 volt system and 7.5 volts on a 6 volt system.
Sep 12, 2009 | Garden
I need a wiring diagram for this stereo
FOR 16-PIN HARNESS
Pin Number Wire Color Function 1 White Left Front (+) 2 Green Left Rear (+) 3 Violet Right Rear (+) 4 Grey Right Front (+) 5 Blue/White Amplifier Remote 6 Blue Antenna Remote 7 Red Accessory 12 Volts 8 Black Ground 9 White/Black Left Front (-) 10 Green/Black Left Rear (-) 11 Violet/Black Right Rear (-) 12 Grey/Black Right Front (-) 13 Sky Blue Telephone Mute 14 Orange/White Illumination 15 Not Used Not Used 16 Yellow Constant 12 Volts
FOR 9-PIN HARNESS
Pin Number Wire Color Function 1 Not Used Not Used 2 Black Ground 3 Grey Right Positive 4 Grey/Black Right Negative 5 Blue/White Amplifier Remote 6 Red 12 Volt Switched 7 Yellow 12 Volt Constant 8 White Left Positive 9 White/Black Left Negative
MAY THIS HELP YOU
Jul 04, 2009 | Sony CDX-GT210 CD Player
Moultrie GameSpy 4.0 Digital Camera Deluxe Logo
151 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
