Question about NHJ Limited V@mp VP-208 (128 MB) MP3 Player
V@mp VP-308 I search firmware for this model of a player. Does not work. On the screen writes "Error Formatet"
3 Suggested Answers
Dr_Joseph
  • 86 Answers
SOURCE: NO data/ formate error on NHJ limited audio player
probably you didnt stop the device before removing it. now it is stuck in read only mode. you cannot format.
if it-s inside warranty get the unit replaced.
Posted on Feb 02, 2009
albumflaps
  • 16 Answers
SOURCE: I lost firmware my mp3 player
NHJ no longer exist. It is impossible to find any firmware online.
Posted on Feb 13, 2009
My windows was restoreted so i lost my MP620-4G software that was downloaded. Please help so I can sync music again
Look i had the same problem last year i went to this link http://www.cobyusa.com/ and search mp-610 finally download MP610 Firmware Update for File Sys Error and run that zip file and your done.
Sep 15, 2010 | Coby MP-610 MP3 Player
Ilo Mp3 player
Remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted. On the iLO, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the iLO will remain off during this time, making the screen appear to be blank. An hourglass should appear on you computer and Windows should say, "Found new Hardware 'SMTP3500". Launch the Rave-MP firmware update program (Start>Programs>Rave-MP> Firmware) Click "Get Firmware". Select "iLO256" and let it download new firmware. Click "OK" when prompted. Click "Update Firmware". It will now search for the iLO. This may take a while depending on how corrupted the firmware is, so be patient. After it has found the iLO, it will say, "A device has been detected in recovery mode and is being initialized. Please wait." The iLO should come back to life and start showing it's glorious "USB Connected" screen. The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start". It can take anywhere from 2 to 4 minutes to re-flash the iLO and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the iLO! Why are you still reading this? Great, did something happen? Well, If the program fails to find the iLO and gives you an error like, "Device Timeout" or something similar, you need to reinstall the iLO drivers. This can be done by inserting the iLO cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again). Plugging it into a new USB port is the fastest and easiest option though. Also check the following link for there FAQ: http://www.uiss.6x.to/ Good Luck
Sep 18, 2007 | iLO MP3 Player
Tip
COBY MP-610 File System Error
COBY MP-610 Digital Media Player File System Error Solution
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the archive from the Coby Website will give you a PDF file with instructions, and a program file to run.
Your music will be erased when you run this firmware update. The instructions suggest that even if your mp3 player won't startup properly, if you plug it into your computer you should be able to access it as a removable disk, and copy all your music to a temporary folder on your computer.
Here are the steps:
  1. Plug your MP610 into your computer.
  2. Copy all your music to a temporary folder.
  3. Disconnect your MP610 from your computer.
  4. Disconnect as many USB devices as possible from your computer (to simplify identifying the MP610 at a later step, and avoid damaging other devices by trying to load the MP610 firmware into them by mistake.)
  5. Run the Firmware Update program 'MP610 T LCD Firmware Update for file sys err.exe'
  6. You will see a screen with up to 24 numbered, empty boxes.
  7. Connect the MP610 to your computer. It will show up in one of the boxes.
  8. Once the MP3 player shows up, click on the Firmware Feature icon to start the firmware upgrade.
  9. After the firmware update is complete, you will receive a checkmark in the firmware box.
  10. Disconnect the MP610.
  11. Close the firmware update software.
  12. Turn on the 610 to confirm it starts up and the display reads 'COBY'.
  13. Plug it back into your computer and copy your music back on to it.
on Mar 29, 2010 | Coby MP-610 MP3 Player
Format error Coby mp3 mp610
Coby has released a firmware upgrade for the MP-610 MP3 Player. I recommend you download it and run it to fix your device. You can find the download and installation instructions on the Tip I posted on the FixYa Website.
I hope that helps.
Dec 26, 2009 | Coby MP-610 MP3 Player
Feb 13, 2009 | NHJ Limited VP408 MP3 Player
Feb 02, 2009 | NHJ Limited VP408 MP3 Player
V@mp VP-408 not working
just conect to the pc then goto my computer then rigth click on mp3 icon then chose format itl wil delete al the files on you mp3 but its the only way to fix
plese rate like very helpful and vote me
thanks
Coby MP-C756 Firmware upgrade issue
Screen blurs after showing name , when being turned on
Mar 07, 2007 | Coby MP-C941 MP3 Player
NHJ Limited V@mp VP-208 (128 MB) MP3 Player Logo
50 people viewed this question
Top NHJ Limited Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NHJ Limited Audio Player and Recorder Expert? Answer questions, earn points and help others
