Question about Janome Memory Craft 9000 Computerized Sewing Machine
Tension won't set - Janome Memory Craft 9000 Computerized Sewing Machine
    President:
  • 1,952 Answers
If it is not working, what is the machine doing? Try re-threading the machine again, check the needle to make sure that it is in correctly. There are no set numbers for tension- it is a feel, push, pull.
Posted on Sep 28, 2009
Thread setting out of wack; bobbin thread won's connect with "too loose" top thread
Your tension adjuster is either set incorrectly or needs repair. Bobbins also have a tension setting, though it is not often necessary to adjust them. If they do, it's usually done by turning a tiny screw a very tiny amount. Best to mark the original location of the screw so you can reset it if need be.
Clean out all the thread, clean the bobbin case area thoroughly, a soft brush is good for this, as lint buildup can cause jamming. Set the upper tension around 3 or 4, and try turning the hand wheel slowly to see if the upper thread picks up the bobbin thread properly. If not, adjust the tension again. If you cannot get it to make a nice even stitch, the tension adjusting mechanism may be in need of repair.
Jul 16, 2014 | Singer 6423 Sewing Machine
Tension disk on overlocker won't work
Thwere are wshops that have a sewing school as part of the service they offer to promote sales. Contact the sdhop that handles your machine and they may be able to show you how to overcome this problem
Mar 02, 2013 | Sewing Machines
Need to know what the dials are supposed to be set at. the post that the needles won't go up and down as it jams at some point
Tension dials factory setting is all at 5, stitch lenth on about 2 or 2.5 and differential on zero.
Sep 27, 2011 | Baby Lock Eclipse Serger
I am trying to saw vinyl purse with lining and the stitches are fine on the vinyl, but on the back of it are loose like in a knot. what's the problem?
It sounds like you have a tension problem. If you can test using a piece of scrap vinyl to set the tension, that would be the best. Let me give you instructions for adjusting the tension on anysewing machine. Be sure to have a scrap piece of the fabric you are using andthread the top of the machine with a different color of thread than thebobbin-it'll make it easier to see what's going on. Thread your machine with the presser foot UP. The disks that control the tension (threadgoes through them) are tightened up if the foot is down. Change the machine tension with the presser foot DOWN.Because the disks won't be engaged (see above) if the foot is up, the diskswon't move. Start at the middle setting, 3. Go up to tighten, decrease toloosen. Each machine is different, even 2 different machines of the same model.The best thing to do is start at 3 and use a different color in the top andbobbin thread so you can easily see what changes to the tension do to yourstitches. Now use a straight stitch a sew 3 or so inches. Take a lookat the top and bottom of the fabric. You don't want to see any (or at least notmuch) of the other color showing from the other side. Loops on the bottom of the fabric means you need to tighten(increase) your top tension. If you're stitches on the bottom are causingpuckering, then you need to loosen you're top tension. For the most part, youreally don't want to touch your bobbin tension-leave that to a repairtechnician. The factory setting shouldn't be touched except by someone whoreally knows what they're doing. Keep sewing a few inches at a time until you have the resultsyou want. Now you're tension is where you need it!
Jun 10, 2011 | Kenmore Sewing Machines
I need to set the thread tension well, can you tell if the number is higher does that mean the tension is tighter vice versa
Yes, if you set the number higher the tension is higher, but it's not quite as simple as that. Let me give you instructions that work for any machine. I suggest you thread the top with a different color thread than the bobbin-it's easier to see exactly what's going on that way.
Jun 02, 2011 | Brother XL3750 Mechanical Sewing Machine
Stich is loose on underside of fabric
You probably need to adjust the tension. Let me give you a general lesson in adjusting tension that works for any machine. Also, I suggest you thread the top of your machine with a different color thread than the bobbin-it makes it much easier to see what is going on.
May 18, 2011 | Toyota Sewing Machines
The tension on my Husqvarna Oscar is hard to adjust. As a result the machine is not sewing properly.
Let me give you a general lesson on adjusting tension on any machine. Make sure you thread the top with a different color thread than the bobbin so it's easy to see what's going on.
May 16, 2011 | Husqvarna Sewing Machines
What is the way to get even top and bottom thread tension. the machine is a Husqvarna 2000 6440
Let me give you a quick lesson in adjusting your tension. First, thread your bobbin and your upper thread with two different colors-it'll make it easier to see exactly what you need to adjust.
Thread your machine with the presser foot UP. The disks that control the tension (thread goes through them) are tightened up if the foot is down.
Change the machine tension with the presser foot DOWN. Because the disks won't be engaged (see above) if the foot is up, the disks won't move.
Start at the middle setting, 3. Go up to tighten, decrease to loosen. Each machine is different, even 2 different machines of the same model. The best thing to do is start at 3 and use a different color in the top and bobbin thread so you can easily see what changes to the tension do to your stitches.
Now use a straight stitch a sew 3 or so inches. Take a look at the top and bottom of the fabric. You don't want to see any (or at least not much) of the other color showing from the other side.
Loops on the bottom of the fabric means you need to tighten (increase) your top tension. If you're stitches on the bottom are causing puckering, then you need to loosen you're top tension. For the most part, you really don't want to touch your bobbin tension-leave that to a repair technician. The factory setting shouldn't be touched except by someone who really knows what they're doing.
Keep sewing a few inches at a time until you have the results you want. Now you're tension is where you need it!
May 10, 2011 | Husqvarna Sewing Machines
My zigzag stitch has loose tension
Let me give you a quick lesson in altering the tension on your machine. First, make sure you're using two different colors of thread in your bobbin and in the top of your machine (this will make it easier to see what is going on).
May 09, 2011 | Bernina Virtuosa 150
How do I change the tension
If you need any other assistance, leave me a comment. I check back daily, so I'll be sure to respond to you pretty quickly.
May 04, 2011 | Sewing Machines
Janome Memory Craft 9000 Computerized Sewing Machine Logo
48 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
