Question about GE WSXH208A Front Load Washer
The washer will not unload the water - GE WSXH208A Front Load Washer
    President:
  • 1,185 Answers
Pump is either blocked or has failed
Dump the drain hose into a bucket till the machine is empty
You may have to take off the clips which hold it to the back
Open up the lint trap and see if there is a coin or a clip in the pump impeller.
If there is nothing in the pump then take off the back of the machine and tilt it so that the hose from the tub to the pump is visable , put some cloth under the machine and remove the hose
You can then look at the other side of the pump and also check to see if there is a small item of clothing which has gone down into the thinner part of the hose
Posted on Sep 28, 2009
Want to know what the black Knob, I think called unloader valve is used
Hubert, The unloader valve is like a by pass for the water and regulates/controls water pressure and redirects water when gun trigger is released. Check the attached links,instruction and guides to learn more about Pumps/unloader, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Pressure Washer Unloader Valve
How to replace an unloader valve on your pressure washer pump
All About Unloader Valves ePowerWash
How to Replace an Unloader Valve on Pressure Washer Repair Guide Help...
May 17, 2016 | Garden
Little plastic parts behind the six big nuts on brass end of the pump have melted.
Hi
These are the valves If they are melted this is because the washer is being left running without being triggered. I also suspect yoru unloader may be failing...your will want your unloader tested. The only way to test anything is to replace these valves first. unfortunately I would also inspect your packings as well as the pistons. when water builds up for a length of time without triggering the washer it recycles and builds up heat....this heat starts to melt your valves....this can also happen by starving your pump for water....running it without water....or by a failed unloader where it doesnt allow water to bypass...do you have to pull the trigger of your wand to start it? If so then your unloader needs work. If it has been starved for water..then your packings will show that damage as well...Usually the farthest set from the inlet having the most damage. Also, when that all get hot as soon as you trigger it and cold water is introduced into the pump, this "shocks" the pump packings and pistons. You want to check the pistons to see if they have cracked..So inspect your pump oil for water...look to see if its white-ish looking... Check your pistons for cracks...check your packings for wear. If you see wear that increasingly gets worse the farther away from your pump inlet then thats a tell tale sign of starvation. ..if your pistons are cracked you will need to replace packings as well anyway. Then replace your valves...reassemble and test your unloader. Good luck to you man. You can get all parts here Pressure washer parts catalog quick links Pressure Washers High Pressure... or FIND PARTS FAST
Aug 12, 2014 | Comet Garden
What is a bypass unloader
According to epowerwash.com:
"The unloader valve diverts water flow into bypass when the trigger gun valve is closed. Unloaders may be designed to respond to either an increase in pressure or a change in flow. The unloader valve may also be used for variable pressure adjustment."
More information here:
Jun 06, 2014 | Alfred Karcher Pressure Washer
There is water squirting out of a hole next the pressure hose connection. Is there a missing screw? Or an adjustment to the washer that can be made. There is no pressure because of this leak.
If this hole has threads then it might be the soap inlet. If water is shooting out under pressure you may have an obstruction in the hose/handle. Try removing the hose and running the washer and see if the water flows out the connection. If the hose ends up being the problem a visual inspection and cleaning of all inlets and the handle should clear it.
If the water coming out of the hole is low/tap line pressure then I think your bypass *(or unloader) valve is stuck in the bypass position.
A stuck unloader just needs to be unstuck and lightly cleaned. A light coating of silicon grease wouldnt hurt either!
Get the manual for this pump and see how to open/remove the unloader valve.
Jun 04, 2011 | Northstar Pressure Washer 3000 PSI
Pressure off and on every few seconds with my karcher 3000BH
hi there rjcomer2
here is web site for parts
http://www.ereplacementparts.com/karcher-2500-11944010-pressure-washer-parts-c-33388_33389_33973.html
sounds like you have a unloader valve problem or a crack in the pressure manifold housing between pressure outlet and unloader valve assy allowing unloader to cycle on/ off
or some dirt trapped in the unloader valve seat , make sure you have good supply of water - ie good flow from tap to pump
try cleaning unloader 1st and fitting in line tap filter
hope it helps
pauly46
May 20, 2011 | Karcher 2500 PSI Pressure Washer
Not sprayer engine stop
This is an indication that the unloader not working properly. When you release the trigger the unloader senses the increase in pressure and bypasses the water into the water inlet. When the unloader is not working and you release the trigger, the water pressure builds quickly and overcomes the power of the engine shutting it down. Here is the manual for your machine, http://www.pressurewashersdirect.com/manuals/Simpson_WaterBlaster%20manual_2.pdf
and some information about troubleshooting from the manual.
"Not Unloading. Leak in Gunvalve or Hose. Repair gun leak . Replace leaking or broken hoses. Debris or wear in Check Valve. Remove Check Valve parts and clean. Check O-Ring. Reface with emery cloth, or replace checkvalve. Damaged Piston U-Cup. Rebuild Unloader Valve (Service Center)."
Usually when the unloader fails the pressure regulator will most likely need to be replaced as the unloader is usually incorporated within. For now try lowering the pressure some and just tie the trigger open untill you can service. Good luck.
Jul 14, 2010 | Simpson WS4050V Water Shotgun 4000 Psi...
K5.140 makes a revving noise when releasing the
Before you do the below steps check the water supply inlet screen for obstructions where the water hose connects to the unit. If you notice debris remove and clean the screen under running water with a small NYLON brush.
The bypass unloader valve is triggering earlier than it should. You can lubricate this by adding oil to the water supply inlet (at least 3 oz.) and very briefly switching the unit on then off 0.5 seconds. Then let is sit overnight. The next day connect power briefly and again cycle the unit on then off for 0.5 seconds. Connect the water supply and then purge the water wand hose into a bucket to catch the oil before use. After this restart the unit and operate the wand trigger under full pressure at 0.5 second intervals to ;scycle the bypass / unloader valve inside the pump. This method has worked in about 95\0 % of the machines I have worked on. The oil lubricates and fattens the seals in the bypass / unloader valve. It eihter works the first time or the seals are torn in the unloader valve and must be replaced. With only 3 uses I think your pretty much in the clear and will not need new seals.
Thanks for using FixYa.
Kelly
May 16, 2010 | Alfred Karcher K 5.93 M Electric Pressure...
Can't get water to come threw nozzel
Sounds like you may have some calcium buildup in the hose, gun or unloader. Take the unloader (where the hoses hookup) apart and clean away the deposits. This should solve your problem.
Apr 21, 2010 | Honda Maxus Pressure Washer MX5222
PWER WASHER RUNS PERFECT, WHEN WATER COMES ON, IT STALLS. BUT IF YOU PULL TRIGGER BACK ON WAND, THEN SPRAYER WORKS. THE MINUTE YOU LET GO OF TRIGGER, IT STALLS OUT.
hi you have got a fault with the unloader it's not unloading so its going a bove the 13amps and knocking the thermol overload out or blowing a fuse you could cable tie the trigger open or get a new unloader kit costing about £70.00 regards
Feb 17, 2010 | RTO 1800 PSI Pressure Washer
I have a pressure washer with a faip 3 piston pump. the other day i was using it and it stopped unloading. i cleaned the unloader and it didn't help. I bought a new one and it still won't work. I e-mailed...
I think your main problem is that the unloader valve needs to be lubricated. Use the very best water resistant bearing grease you can find. If you can e-mail me a pic of your unloader assembly I can try to explain how to set it up. firehead@roges.com
Sep 14, 2009 | Honda Garden
GE WSXH208A Front Load Washer Logo
59 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
