Question about Ovens
Error code on Frigidaire FEB24S2AS oven is F3. What is that?
  • Ovens Master
  • 2,605 Answers
On frigidaire manufactured ranges the fault code "F3" means the ERC/EOC (electronic control) has detected a "open" thermistor/temperature sensor.
if you feel up to it, here's what you can do.
**FIRST; unplug the unit from the wall or shut off the breaker.**
*you will also require a multi-meter or a ohm meter. a measuring device of some kind to check the value of the sensor once removed.
most sensors can be replaced without opening the back panel or sliding out the range and can be done from inside the oven, but be careful not to let the sensor connector slide back thru the opening after disconnecting it.
1) having shut off power to the unit, look into the oven and you'll see the sensor coming thru the back of the oven liner. (skinny pen like instrument) this device will be fastened to the liner by 2 screws, either philips head (star) or robertson (square). some are even small 1/4 inch nut heads, rarely.
2) remove these screws and gently pull the sensor toward you...slowly. you don't want to yank it, and you need to be sure the harness will come thru that small opening (some don't-most do, don't force it. it just means you'll have to unfasten the rear panel of the range, no big deal really). as I said before make sure the connector isn't going to fall back thru the hole when you unfasten the wires.
3) with the sensor removed, measure the ohm value between the two pins at the harness. if the sensor is truely "open" you should get a reading up around 3k ohms. replace it. possible sensor #'s are 316134900, 316217002 and 316217001. those are just the ones I'm aware of. cross reference with your model number at a local parts depot, or online supplier.
if you only get a reading around a thousand ohms, it's good. that may indicate a poor electronic control, the "watchdog" in the processor is "lieing" err, giving false readings/codes. don't worry about that right now though. my advice is for the sake of $20-$40US get a sensor and replace it first before condemning a potentially $200 to $300US control.
hope that helps,
good luck
Posted on Sep 28, 2009
How do you keep the door locked so you can use t self cleaning feature
Good Morning Friend,
I understand you want to know how to keep the door locked on your Frigidaire oven, model# FEB24S2AS, so you can use the self-clean feature. The "Door Locked" light will flash until the door locks when the self-clean cycle is in use. It glows constantly after the door locks. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Frigidaire fault code F3
Within my research I was able to locate code "F3" which indicates a possible error with the oven probe. It is recommended that a Service Specialist assist you with further diagnosing the issues.
Jan 05, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire model FEF352CATB has a F3 error code
Hi - Typically error code F3 indicates a faulty sensor probe or wiring harness between sensor probe and EOC. Try resetting the range by unplugging it or flipping the circuit breaker off for two minutes (this usually will clear most false error codes). Turn on the range and if resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 14, 2012 | Frigidaire Ovens
My frigerdaire oven heats for a while about 15-30 minutes then shuts down with a beeping noise and a f3 code.
Good Afternoon Friend,
I see that your Frigidaire double oven heats up for about 15-30 minutes, then shuts down and begins beeping while showing an F3error code. The F3 states that the oven is sensing a potential runaway temperature. This is possibly a sensor issue or it could be a false error code.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Let the oven heat up, and if you are still receiving an F3 error code, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 27, 2012 | Frigidaire 30 in. Electric Gallery Series...
My fridgidaire oven shows a f3 error code
F3 Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nov 06, 2010 | Frigidaire Ovens
Model FEB24s5abb wall oven has a F1 code. What
F0 & F1 EOC (Electronic Oven Control) failure Replace
Mar 01, 2010 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
F1 CODE ON FRIGIDAIRE STOVE
I have a F1 code on my Frigidaire convection oven and a really cool beeping sound to go with it. I turned the breaker off and turned back on---doing the same thing...????????
Aug 15, 2009 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
F1 code comes up on my oven,what does that mean
HI,. this code represents a serious issue concerning the oven control board. It requires the replacement of this board asap, if possible. This damage is not repairable.
Jul 31, 2009 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
Ovens Logo
240 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
