Question about Microsoft Windows Vista Ultimate Edition
Cipherwave 3.5" external harddrive driver
Please help me, I can't find a driver for my harddrive to install! What must I do to get the thing to work?
  • Contente Jan 23, 2009
    I have the 2.5" 120Gb HDD but it is not recognised in windows xp or on my macbook. The crappy little cd that came with the pack contains no drivers so here I am trying to find a driver for this piece of s#*t. This is the last time I ever buy something originating from the CSS Africa group
    Genius:
  • 1,601 Answers
According to their website you have to contact them for advise on software for your computer.
Backup your Data
Why not make your CipherWave your Disk-to-Disk (D-2-D) backup device. Enquire with our Sales Team on the software required to make your CipherWave and cost effective and reliable backup device for your PC.
Any Queries, send them to cipherwave@cssi.co.za
Posted on Dec 18, 2007
I have a problem with my external harddrive. when plugged in it takes too long too read and when I transfer files from or too the harddrive it takes up to one day. sometimes the files is not even as b
Are you plugging directly into the computer or using a USB Hub. Cheaper USB hubs have awful data throughput. I have one that I tried to plug a sd card reader into and it would take ten minutes for a 60 megabyte file. Connect directly to a port. Or download Samsung diagnostics and make sure that the drive is in proper working order. Verifying The Hard Disk Drive Is Working Normally
Jan 10, 2015 | Samsung G2 Portable External HX-MU064DC/...
SONY VAIO PCV R53 39 DS WON'T BOOT UP
Pull the harddrive out, install in an economical external enclosure.
The external enclosure has a USB cable.
Plug the USB cable into any available USB port, on a working computer.
Go to My Computer, or Computer; and double-click on the drive letter, that corresponds with the external enclosure.
(Actually with the harddrive in that external enclosure, it is now an external harddrive)
http://esupport.sony.com/US/p/model-home.pl?mdl=PCVR539DS&LOC=3#/howtoTab
It's an IDE harddrive. Also known as a PATA harddrive.
A harddrive is measured across it's width.
2-1/2 inches across is a laptop harddrive.
3.5 inches across is a desktop harddrive. (3-1/2 inches)
So you need a 3.5 IDE (PATA) external enclosure.
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
Regards,
joecoolvette
Mar 26, 2013 | Sony VAIO Computers & Internet
My Lacie 500gb external hard disk has stopped working. it has a scratching like sound and no computer couldn't detect it. even it is not detected in device manager. when it is connected to computers it...
is the scratchy sound coming from inside your lacie or outside ??
it might be a power problem trying to connect to your lacie but unable to find the device or a dirty hard drive the reader arm skipping across the platters you could give your lacie a firm tap on the side to free up the reader arm
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Sep 15, 2011 | LaCie Computers & Internet
I have plugged my lap top power into 'my book' and yes I have cooked a component on the PSB card, is the car repairable or can it be replaced?
It would be better to remove the harddrive inside the WD My Book, and install it into an economical external enclosure.
Suggest you forget trying to repair the interface circuit board inside.
If I am all wrong, and have misread your problem, please state in a Comment.
If I am correct so far, and if memory serves, the harddrive inside is a SATA model.
I don't know however if it is a laptop sized harddrive, or a desktop sized harddrive.
A laptop sized harddrive is 2-1/2 inches across in width. (2.5 inches)
A desktop harddrive is 3-1/2 inches across in width. (3.5 inches)
Once you open the case you will know.
By using an economical external enclosure you will have a external harddrive again.
This is one example of an economical 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
This is one example of an economical 3.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
This is information that may help in opening the WD's case, and extracting the harddrive,
http://www.youtube.com/watch?v=6FlySnyJ0CQ
http://www.youtube.com/watch?v=-_2oMyoTBno&feature=related
{TIP: DO NOT work directly on a carpet floor! It is a high area of Static electricity. Work on a table}
There are other videos related to this on the right side under the Suggestions heading.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 04, 2011 | Western Digital My Book Essential Edition...
My Lacie external hard drive used to turn on when the computer using XP was turned on. It has stopped doing this. Any suggestions to solve this?
if your computer came with a motherboard disc the drivers could be on it
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems hope this helps
Jun 12, 2011 | LaCie Computers & Internet
Please help lacie 500gb harddrive worked prefect this morning switched on tonight it powered up and green light on but computer dont see it please help have to much to lose on this drive my email is...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jan 31, 2011 | LaCie External USB 2.0 500GB 7200 RPM 500...
Cipherwave 2.5 external hdd
MAC can't read NTFS. Most items are made for PC, will this work with a MAC as stated on the box?
Most external drives are usually formatted just for MAC use.
PC's and MACs don't like playing together.
Jul 21, 2009 | Microsoft Windows Vista Ultimate Edition
Transfer of old laptop's condent to external harddrive
Windows 98 don't have pre-installed drivers for mass storage, like external hdd, pen drive, flush memory etc.
So, you should install the driver for your external hdd then win 98 will recognize it. And you can use it. For you external drive driver you can surf your external manifacturer site.
If any problem Ask me.
Thanks
Iqbal
Mar 26, 2008 | Compaq Presario 700 470024-192 Notebook
Unrecognizable USB External Harddrive
dear jpaws check your computers device manager. ithink you need drivers please install a driver.
Feb 25, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
686 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
